I don't trust a GPS reading further than I can throw it but would love the option to fly against it's readings with a few other variables thrown in with it. |
Joined Aug 2005
Po73,
I think for this to be meaningful, you probably want power/distance rather than power/speed. Speed is instantaneous and if that's what you want, the current drawn rather than mAh would be more useful. So, you either want:- (instantaneous power)/(instantaneous air speed) or (cumulative power)/(distance travelled) or the above over a limited time period. Using GPS speed or distance for this is quite useless so if you want to, you'd need to integrate air speed to get "air" distance. I'm not sure if this has been tested and/or how well it would work. Daniel |
It would be a formula to displayed for distance travel. I think the sporting thing would be:
Display one. Mah consumed vs speed in unit of measure(take you pick of speed sensor elasped over 30 seconds?) Display two. Airspeed differential GPS vs pitot tube + or - unit of measure It's not a perfect method from GPS standpoint and battery/ESC/motor efficiency, but it IS an interesting tool if you understand the variables. |
This is merely a suggestion, I obviously haven't thought anything through, I'm happy that you are at least toying with the idea. ![]() I just thought having airspeed versus ground speed calculated output on the screen would be an awesome feature as no matter how you measure wind speed and direction it's never the same at different altitudes or over different geological features. Having this would be innovative. I remember you saying that you would rather not add power consumption versus speed/distance as it can be rather misleading if there were some fictitious theoretical "range left" that would be displayed. I say don't worry about trying to show any kind of range based on capacity and speed, just give us a couple tools that will give the user an idea of how things are going up there like headwind/tailwind in a +/-KPH\MPH format and 200Mah/KM. If I were doing a long range flight I would really be watching the output on both of those displays. |
| Thread Tools | |
| Question OSD Pro, eLogger V3, GPS V4 problems updating firmware in OSD Pro | jbfoamy | Eagle Tree Systems | 23 | Jun 02, 2012 02:59 PM |
| Question OSD Text GPS Coordinate | EugeneFlorida | Eagle Tree Systems | 4 | Nov 03, 2010 08:21 AM |
| Sold Eagle Tree v3 OSD Pro, v3 E-Logger, Altimeter, Airspeed, 10Hz GPS $220 Shipped | cbcalhoun | FPV/RPV - Equipment and Vehicles (FS/W) | 1 | Nov 01, 2010 11:03 AM |
| For Sale Eagle Tree v3 OSD Pro, v3 E-Logger, Altimeter, Airspeed, 10Hz GPS $220 Shipped | cbcalhoun | Aircraft - General - Miscellaneous (FS/W) | 0 | Oct 30, 2010 09:06 PM |
| Sold FY21AP II Flight Stabilizer, GPS, OSD, Autopilot, Return Home | lafuerza | FPV/RPV - Equipment and Vehicles (FS/W) | 0 | Oct 29, 2010 09:08 PM |
