Old Jul 21, 2012, 09:00 PM
Defender of the park sky
Ispintechno's Avatar
London, ON Canada
Joined Nov 2009
Starting to paint. Love this bird.
Ispintechno is offline Find More Posts by Ispintechno
Old Jul 22, 2012, 10:40 AM
Blasturbator's Avatar
United States, FL, Sarasota
Joined May 2011
Maiden flight was aborted today because the plastic connectors that rotate the main retracts stripped/broke in half.
anyone know where to get those pieces?
Blasturbator is offline Find More Posts by Blasturbator
Old Jul 22, 2012, 11:18 AM
fredmdbud's Avatar
USA, MD, Frederick
Joined Jan 2010
450-sized heli ball links.
fredmdbud is offline Find More Posts by fredmdbud
Old Jul 22, 2012, 12:18 PM
Joined May 2011
Thank you sir
Old Jul 22, 2012, 12:25 PM
Never Trade Luck for Skill
MERLIN V16's Avatar
United States, FL, North Port
Joined Jan 2005
Welcome to the Club!
MERLIN V16 is offline Find More Posts by MERLIN V16
Old Jul 22, 2012, 10:10 PM
Mankato MN
United States, MN, Mankato
Joined Jun 2011
What kind of junk does nitroplanes sell?....i just got my replacement retracts...2 of the 3 quit working....again....i am done....never again will i buy a plane loaded with that junk again.....love the airframes but will not waste my time.....i never even got to see the retracts cycle in the air on this bird....
Patriot2373 is offline Find More Posts by Patriot2373
Old Jul 22, 2012, 10:52 PM
advanced n00b
xfatdannx's Avatar
United States, NE, Omaha
Joined Feb 2012
sucks dude. sorry to hear.
xfatdannx is offline Find More Posts by xfatdannx
Old Jul 22, 2012, 11:09 PM
Joined Nov 2005
is ur esc < 5.5 volts?
erh7771 is offline Find More Posts by erh7771
Old Jul 23, 2012, 12:01 AM
fredmdbud's Avatar
USA, MD, Frederick
Joined Jan 2010
I imagine he is using the stock ESC/BEC ... ?
The retracts have an sensing circuit to stop the motor if something is blocking the plate on the actuaing screw. Do you hear any sounds when you attempt to activate the retracts, either up or down? If so, maybe open up the servo an see if something is catching in there. Nothing to lose, since you already have your original servos and replacements. I had a similar issue with one that came with a Freewing Su-35 jet, and it's working fine now.
Old Jul 23, 2012, 12:35 AM
advanced n00b
xfatdannx's Avatar
Joined Feb 2012
Well i got all my servos. Just need to get my power system tested then everything is going together! Hopefully get to maiden in the next couple weeks.
Old Jul 23, 2012, 08:47 PM
Mankato MN
Joined Jun 2011
Did a little experiment with these junk retracts to see what the heck is going on....
pulled one apart.... seems that the bar that goes up and down the jackscrew is getting hung up sometimes on maybe a bad thread or something.... i worked it back and forth with my fingers until it got smooth... put some highspeed bearing grease on it...so far so good... but i am not using them anyway.... just wanted to see why they would hang up... so 2 out of the 3 replacements work but the one has a bad motor or something
Old Jul 24, 2012, 01:12 AM
advanced n00b
xfatdannx's Avatar
Joined Feb 2012
started building today in anticipation for the arrival of my new RX.
Old Jul 24, 2012, 04:21 PM
Progress with the process...
M3ATpl0w's Avatar
NE Alabama
Joined Feb 2011
Lookin good Dan. What power setup are you gonna put in her?
M3ATpl0w is offline Find More Posts by M3ATpl0w
Old Jul 24, 2012, 07:08 PM
advanced n00b
xfatdannx's Avatar
Joined Feb 2012
i have two options to go with on hand now. I really wanted to use the CS so i bought that fan ahead of time. But then i realized i would have to balance it and i am no good at that. So i god a used BL15 3200 w/ Delta V fan already balance. Then i picked up a HK 2855 2100 kv to test on the CS. I have an 80amp E-Flite Pro esc and would prefer to run on 4s.
Old Jul 25, 2012, 12:59 AM
advanced n00b
xfatdannx's Avatar
Joined Feb 2012
Here are some more pics from the further build.
I am leaving the nose cone off for now. b/c it is hollow i am gonna keep it off until i balance it, if i need more nose weight i can add epoxy to the nose cone then attach it permanently.
Edit: Can't believe how bad pics turn out on my ipod...it captures video in 720p
Discussion New! $129 Nitro Planes Rc Landers 70MM F-16D EDF Jet With Retracts FlyBoyTha1 Foamy EDFs 49 Jun 20, 2009 04:58 PM
Discussion Starmax/Exceed RC/Topgun F18-C 70mm what Fan does it use? Stuart B Foamy EDFs 0 May 16, 2009 11:39 AM
New Product New!!! Exceed RC F-22 Raptor 70mm Ducted Fan RC Jet nitroplanes Nitro Planes 9 Apr 19, 2009 07:06 AM
Cool *** UPDATE *** New Version 2 70mm Exceed RC F/A-18C EDF Jet + NEW MOD VIDEO nitroplanes Nitro Planes 2 Mar 20, 2009 04:57 PM
