Old Jul 17, 2012, 04:52 AM
United States, FL, Orange Park
Joined Jul 2010
Originally Posted by savall21 View Post
Nice! What is your setup in that?
Thanks, HET 2W-20/ stock fan in a Skyworld metal shroud/ Hobbywing 80amp pentium esc/ Sky lipo 40c-4s-3000mah battery.I'm also using a BEC with 450mah 3s for the electronics.
3rd-dem is online now Find More Posts by 3rd-dem
Old Jul 17, 2012, 05:20 PM
will3kgt's Avatar
Grand Blanc, MI
Joined Jan 2007
Put my RC Lander fan back in, went up for a flight and the motor shut off. Used a SkyLipo 4000 30c. Picked up the plane and the motor was HOT! Just the motor. Battery was fine, ESC was fairly warm but the motor stayed hot for about 10 minutes. Went to throttle back up and it was cogging. Don't know what's wrong. Hope I didn't kill the motor.
will3kgt is offline Find More Posts by will3kgt
Old Jul 17, 2012, 05:48 PM
Progress with the process...
M3ATpl0w's Avatar
NE Alabama
Joined Feb 2011
Nice flying Walt!! Looks awesome in the air. Did you reinforce your wing, or just prep and glue? TIA
M3ATpl0w is offline Find More Posts by M3ATpl0w
Old Jul 17, 2012, 06:01 PM
Joined Jul 2010
Thanks, Just removed the paint, poked some holes anywhere two parts meet and used 15 min epoxy. Will3kgt my friend had a similar issue after one flight and sent it back to Lander and they replaced it for him. Something to consider, he has since removed the lander motor and installed it to the stock fan in his F-18 and loves it! It is performing far better than the complete Metal Lander setup, His is the 3575 kv version.
Old Jul 17, 2012, 06:04 PM
Joined Jul 2010
Maybe check that the timing is set right for the motor?
Old Jul 17, 2012, 06:36 PM
will3kgt's Avatar
Grand Blanc, MI
Joined Jan 2007
Thankyou very much for the advice , I should also mention that I had the same issue with my 90mm fan as well.
Old Jul 17, 2012, 07:19 PM
M3ATpl0w's Avatar
NE Alabama
Joined Feb 2011
Thanks for the reply. I have watched all your vids, and you yank on her pretty good, so I think a properly prepped and glued joint is good to go. Have any of you guys tried thrust tubes? My F18 exhaust measured 108% FSA. I would think about 1.52" per exhaust (for those running stock 6 blade fan) would wake her up a bit?
Old Jul 17, 2012, 07:48 PM
Joined Jul 2010
I never did the calcs for the stock fan but have for the CS 10 blade ( My next F-18 I'm working on) and get 93% FSA ( 2 x 45mm)so that's good for that fan, it doesn't like a tight exhaust! My friends and I have discussed thrust tube options for this bird but the degree of complexity ( Bifurcated) vs net gain has yet to yield a tube/tubes.
Old Jul 19, 2012, 11:45 PM
advanced n00b
xfatdannx's Avatar
United States, NE, Omaha
Joined Feb 2012
Well boys, I got a package from nitroplanes today. They sent my new gear since mine were kind of a QA issue. They sent them free of charge. I was hoping i would get the full retract but they sent just the struts, with wheels and everything. So i do have a set of backup. Probably gonna hold on to em for now and see how this thing flies before i get rid of them then screw something up. Came in a neat little box made of balsa and has exceeds logo on it so that a cool little bonus.
anyone ever switch from EC5 to EC3? is there any restriction in current to be worried about? Like to keep all my plugs the same is all.
xfatdannx is online now Find More Posts by xfatdannx
Old Jul 20, 2012, 10:45 AM
Defender of the park sky
Ispintechno's Avatar
London, ON Canada
Joined Nov 2009
I run EC3 for everything as I was a parkzone guy. I like those connectors, they can spark a little when connecting but everything I've thrown at them through the watt meter checks out.
Ispintechno is offline Find More Posts by Ispintechno
Old Jul 21, 2012, 05:56 AM
advanced n00b
xfatdannx's Avatar
Joined Feb 2012
cool man thanks for the heads up.
Old Jul 21, 2012, 01:06 PM
Blasturbator's Avatar
United States, FL, Sarasota
Joined May 2011
Whats a good maiden dualrate expo for this bird?
I usually use 75%dual- 30% expo
Blasturbator is offline Find More Posts by Blasturbator
Old Jul 21, 2012, 02:57 PM
Never Trade Luck for Skill
MERLIN V16's Avatar
United States, FL, North Port
Joined Jan 2005
30% Expo was not enough for me but than again I'm not used to a Plane that reacts this fast.
Dial in more than you would think (like 50%) and you can always adjust after the maiden.
This plane reacts very quick (but Nice) on the sticks. I am about 75% throws on low and 100% on high Rates . I used 85% expo on the nose gear to take some slop out of it.
It lands like a trainer. Nice flying plane.I think you will like it.
__________________________________________________ ______________________
For those that care about such things out of nowhere my Plane with the stock setup seems to have broken in.
I still only get about 4 minuets but it seems much faster than it was. 60 MPH maybe?
The ESC is cool and the battery warm on landing after a lot of WOT passes. It will also stand on it's tail at about 200 Feet AGL.
My friend will setup his Eagle Tree logger and than we will know for sure .He says it is faster than 60 MPH.
MERLIN
BTW
This is Clean still with no Armament.
MERLIN V16 is offline Find More Posts by MERLIN V16
Old Jul 21, 2012, 05:31 PM
will3kgt's Avatar
Grand Blanc, MI
Joined Jan 2007
Flew mine the other day with the stock fan & motor and it ran great. Used a 4000Mah 30c battery and flew for about 8min.
Old Jul 21, 2012, 06:12 PM
London, ON Canada
Joined Nov 2009
MERLIN
BTW
I still don't understand expo, even for fast reacting control surfaces. My EDFs can roll about a zillion times a second but when I tried expo it lead to over control as the zone in the stick I'm used to normal operation felt sluggish and unresponsive. I guess we all are different. I like 0 expo across the board, although nose gear I can understand. I must have dainty fingers or something.
Awesome news about the stock set-up Merlin! Yeah, it's not crazy fast but it's probably the airframe. I have the same power consumption in my F-4 and it is at least 10mph faster, maybe 15. I find when I fly in the wind vs. no wind there is a dramatic change in top speed too for this F-18, also revealing I think a very draggy airframe. Sure does make it easy to land though.
Discussion New! $129 Nitro Planes Rc Landers 70MM F-16D EDF Jet With Retracts FlyBoyTha1 Foamy EDFs 49 Jun 20, 2009 04:58 PM
Discussion Starmax/Exceed RC/Topgun F18-C 70mm what Fan does it use? Stuart B Foamy EDFs 0 May 16, 2009 11:39 AM
New Product New!!! Exceed RC F-22 Raptor 70mm Ducted Fan RC Jet nitroplanes Nitro Planes 9 Apr 19, 2009 07:06 AM
Cool *** UPDATE *** New Version 2 70mm Exceed RC F/A-18C EDF Jet + NEW MOD VIDEO nitroplanes Nitro Planes 2 Mar 20, 2009 04:57 PM
