Old Nov 27, 2011, 10:24 PM
Ispintechno is offline
Find More Posts by Ispintechno
Defender of the park sky
Ispintechno's Avatar
London, ON Canada
Joined Nov 2009
$5 fix for better high speed flight control
Hey guys, just want to throw my 2 cents in a cheap upgrade that takes all the flex out of the controls linkages to the ailerons and especially the elevator.
The new Parkzone F-27Q Striker linkages bolt on nicely to this F-18 and are waaaaaaaaay less flimsy. The tail linkages in this F-18 I found particularly alarming and probably prone to tail flutter under stress. (at my flying level I'm being somewhat gentle still)
Did a change-over and took some snap shots.
I bought a second set as I plan on changing out the servos to something better next.
Ispintechno is offline Find More Posts by Ispintechno
Old Nov 28, 2011, 12:43 PM
London, ON Canada
Joined Nov 2009
I'm actually not that happy with how little thread is left for the elevator adjuster. I think I'll take carbon tube and put it over the original F-18 elevator rod to take the flex out. Should work...
Old Nov 28, 2011, 02:12 PM
Pilot in MO is offline
Find More Posts by Pilot in MO
Plane and Heli Abuser
Pilot in MO's Avatar
United States, MO, St Louis
Joined Aug 2010
I just started assembly of mine, during testing, the nose retract began sticking in the "down" position. It will go back up if you tap on it several times. Has anyone had issues with defective e-tracts on this model?
Anyone dealt with Nitroplanes dealing with defects? I tried calling them, phone would just ring about 20 times then disconnect me. Sent them an e-mail, waiting for response.....not good.
Ron
Pilot in MO is offline Find More Posts by Pilot in MO
Old Nov 28, 2011, 05:30 PM
jjh24 is offline
Find More Posts by jjh24
jjh24's Avatar
soKali, Chino
Joined Mar 2010
Ron
try the live chat..or find them on this forum under vendors or try there forum from there website..at the bottom..it sucks that we have to go through all these changes..but live chat or the forums have worked great for me..lol..once you get through they can be very helpful..just try and stay calm..in this business they get alot of rude people and it only back fires..
jjh24 is offline Find More Posts by jjh24
Old Dec 01, 2011, 01:57 AM
jk671 is offline
Find More Posts by jk671
John
jk671's Avatar
United States, NV, Las Vegas
Joined Mar 2011
Since there aren't enough videos of this plane... enjoy!
Exceed RC F/A-18 70mm edf jet close call landing (5 min 57 sec)
Exceed R/C F/A-18 edf jet 70mm smooth flying! (12 min 3 sec)
jk671 is offline Find More Posts by jk671
Old Dec 01, 2011, 01:44 PM
HardAbz is offline
Find More Posts by HardAbz
HardAbz's Avatar
Texas
Joined Jul 2001
Originally Posted by jk671 View Post
Wow! That was a close call landing! Nice last second save!
HardAbz is offline Find More Posts by HardAbz
Old Dec 01, 2011, 02:52 PM
jk671 is offline
John
jk671's Avatar
Joined Mar 2011
thanks
Old Dec 01, 2011, 05:48 PM
jk671 is offline
John
jk671's Avatar
Joined Mar 2011
I know this is a little off topic... but not all my flights yesterday went well.... just thought i'd share...
T-50 Aftermath! (2 min 31 sec)
Old Dec 04, 2011, 08:38 PM
jjh24 is offline
jjh24's Avatar
soKali, Chino
Joined Mar 2010
wow
http://www.youtube.com/watch?v=fqTTTWnRmRA&hd=1
wow...what a bummer...those darn poles!!!!...sorry to see that..thanks for sharing.
Old Dec 16, 2011, 03:19 PM
Aero D is offline
Find More Posts by Aero D
Joined Jan 2009
Any advice appreciated
Greetings,
Just received my new Exceed 70mm F18 ARF. I haven't opened the box yet because it's apresent from my wife for Christmas. Gotta wait another week. It apparently comes with a KV2750 motor and a 45A ESC. Can anyone attest to the quality of the ESC? Does this ESC come with a BEC?? Should I bypass the BEC and go with a seperate battery for the electronics???
What would be the recommended battery for this configuration?
How about the stock servos, will they hold up??
Any advice would be appreciated.
Aero D is offline Find More Posts by Aero D
Old Dec 17, 2011, 12:02 AM
will3kgt is offline
Find More Posts by will3kgt
will3kgt's Avatar
Grand Blanc, MI
Joined Jan 2007
Originally Posted by Aero D View Post
Greetings,
Congrats on your Christmas gift. Hope you enjoy it. You should be alright with the stock esc and you won't have to buy a BEC. My F-18 has been quite happy with it's 4s 3000Mah pack. If you upgreade the motor you'll want to upgrade to a 60 amp ESC.
will3kgt is offline Find More Posts by will3kgt
Old Dec 19, 2011, 03:00 PM
gioial is offline
Find More Posts by gioial
Joined Feb 2008
Lander fan/motor
Just purchased the kit. After reading through much of the forum it seems the majority feel this is a fun stable jet. I yanked my 70mm RC Lander fan/motor combo from a Lander F16 and plan to install it in the F18. Any thoughts on this choice would be appreciated. Also have a 65A HET and 4s 3300mah battery to complete the power setup.
gioial is offline Find More Posts by gioial
Old Dec 19, 2011, 05:32 PM
erh7771 is offline
Find More Posts by erh7771
Joined Nov 2005
I've an MB1 and SAPAC knock off fan and feel it's a tad tail heavy but there's PLENTY enough room in the bat tray for even a 5s 3300mah.
Some tips maybe not in the thread
Use heavier gauge steering wire and secure steering servo well to prevent bending of front landing gear strut wire. I use the round servo arm cause it's always been the toughest and doesn't break on "aggressive landings"
Clear tape the rudders and lending edges of wing, it'll toughen them up 3 fold and wont add too much extra weight or hide the looks of the plane any. I did this to my Windrider F35 which is a low density light EPS and they haven't snapped once even though I've flipped it a couple of times.
erh7771 is offline Find More Posts by erh7771
Old Dec 19, 2011, 07:56 PM
gioial is offline
Joined Feb 2008
Thanks for the information. I was a little worried about the heavier Lander setup, but suppose I could balance it out with the appropriate bat. UPS status shows they received a shipping label. I don't believe it will arrive before Xmas using ground shipping...
Old Dec 20, 2011, 05:16 AM
ApexAero is online now
Find More Posts by ApexAero
Aka: Tom Jenkins
ApexAero's Avatar
United States, FL, West Palm Beach
Joined Aug 2008
Sullivan products
No. S527 Bulk 2-56 w/Clips (12)
No. S501 2-56 Assorted double end thread 8 rods
No. S528 Bulk 4-40 w/Clips (12)
S494 4-40 Assorted double end thread 10 rods
Don't forget Robart hinge pins to replace the cheesie fall apart hinges
JK are you keeping the sun to your back and your car out of the flight path now?
ApexAero is online now Find More Posts by ApexAero
Discussion New! $129 Nitro Planes Rc Landers 70MM F-16D EDF Jet With Retracts FlyBoyTha1 Foamy EDFs 49 Jun 20, 2009 04:58 PM
Discussion Starmax/Exceed RC/Topgun F18-C 70mm what Fan does it use? Stuart B Foamy EDFs 0 May 16, 2009 11:39 AM
New Product New!!! Exceed RC F-22 Raptor 70mm Ducted Fan RC Jet nitroplanes Nitro Planes 9 Apr 19, 2009 07:06 AM
Cool *** UPDATE *** New Version 2 70mm Exceed RC F/A-18C EDF Jet + NEW MOD VIDEO nitroplanes Nitro Planes 2 Mar 20, 2009 04:57 PM
