Old Oct 29, 2011, 08:32 PM
wow1 is offline
Find More Posts by wow1
wow1's Avatar
upstate NY
Joined Jan 2010
Yes I do!! Really good stuff. Balance your EDF with a cell phone
http://www.rcgroups.com/forums/showthread.php?t=1267814
wow1 is offline Find More Posts by wow1
Old Oct 29, 2011, 09:24 PM
wow1 is offline
wow1's Avatar
upstate NY
Joined Jan 2010
JK about your five cell mishap I wonder if it over revved because of no load.
Karl
Old Oct 29, 2011, 11:20 PM
erh7771 is offline
Find More Posts by erh7771
Joined Nov 2005
Do not spin your motors up unloaded....bad wear on bearings just like a car motor
erh7771 is offline Find More Posts by erh7771
Old Oct 30, 2011, 07:59 AM
jk671 is offline
Find More Posts by jk671
John
jk671's Avatar
United States, NV, Las Vegas
Joined Mar 2011
That makes a lot of sense! Maybe I will try again... right now I am concerned that my motor is now unbalanced
jk671 is offline Find More Posts by jk671
Old Oct 30, 2011, 09:16 AM
jk671 is offline
John
jk671's Avatar
Joined Mar 2011
Nitroplanes Exceed RC F/A-18 70mm edf jet with e-r (10 min 9 sec)
Ok guys here she is sorry if I tend to talk too much... hopefully I get to fly her today!
Old Oct 30, 2011, 01:19 PM
wow1 is offline
wow1's Avatar
upstate NY
Joined Jan 2010
Pulled my fan assembly out today and discovered that the spinner cap and screw are causing most of the vibration. After playing with adding weight its better. How important is the spinner cap? I get less vibration with it removed.
Old Oct 30, 2011, 01:35 PM
wow1 is offline
wow1's Avatar
upstate NY
Joined Jan 2010
JK what motor,bat, fan combo did you end up using?
Karl
Old Oct 30, 2011, 04:57 PM
jk671 is offline
John
jk671's Avatar
Joined Mar 2011
Karl
I am using the sapac mb-1 and sapac fan... I put it in the stock housing so that I didn't have to carve out any foam... but I screwed the housing into the balsa plywood and reinforced it with a few drops of CA.
Old Oct 30, 2011, 07:36 PM
wow1 is offline
wow1's Avatar
upstate NY
Joined Jan 2010
Is that on four cells?
Old Oct 30, 2011, 10:32 PM
jk671 is offline
John
jk671's Avatar
Joined Mar 2011
I am running on 5S. Here's some pics... she's so nice!
Old Oct 30, 2011, 10:34 PM
jk671 is offline
John
jk671's Avatar
Joined Mar 2011
Exceed RC F/A-18 70mm EDF Jet Maiden Flight (4 min 12 sec)
Exceed RC F/A-18 70mm edf jet maiden flight hat cam (5 min 17 sec)
Here are some videos of my maiden flight! one is a hat cam the other a handheld camera.
Old Oct 31, 2011, 08:02 AM
wow1 is offline
wow1's Avatar
upstate NY
Joined Jan 2010
JK it sounds and performs great!! Nice job. Changed out the collet and just put a plastic cover on the fan hub much smoother now. After seeing your video I'm double glad I ordered that sapac MB1 combo. My cyclone motor is not butter smooth either. Did you have to balance the fan or anything or did it run that smooth out of the box? I'm sure there's a good reason for the spinner cone and aluminum screw holding it in place but with this combo it's so much smoother without out I just have to try it. Thanks for the great video.
Karl
How big is the battery, mah and c rating? And while I'm picking your brain clean how big is the esc?!!!
Old Oct 31, 2011, 08:21 AM
jk671 is offline
John
jk671's Avatar
Joined Mar 2011
Karl
the fan needed no balancing for me.. its still important to make sure! i was running a 5S 3000mah 40-80C skylipo battery!
Old Oct 31, 2011, 12:11 PM
wow1 is offline
wow1's Avatar
upstate NY
Joined Jan 2010
Thanks JK, I'm putting an order in. I fly with no landing gear and no brass reinforcment and your plane is still way out performing mine!! Wish I had spoke with you before I ordered the other stuff!! My only worry now is the Hobby Dream's Sapac 3200KV won't be exactly the same as the MB1 all the specs are the same but my luck usually runs in the other direction!! They don't call it an MB1 but the numbers match! Flew mine with no spinner cap screw at lunch sounds much better but still not as good as yours, I think its that cyclone motor.
Thanks again,
Karl
Hey how many amps are you seeing? and what size esc?
Old Oct 31, 2011, 12:28 PM
FoamJunkE is offline
Find More Posts by FoamJunkE
EDF Junkie
FoamJunkE's Avatar
San Antonio, TX
Joined Jul 2010
jk,
That sounds so sweeeet! Ive yet to order one of these F-18 but it is on my wish list. I have two MB1 fan/motor combos on the way already, one for my Meteor and the other for my future F-18.
Im using Sky Lipo 5S 4000 30c batteries in my Meteor so Im hopeing these will fit in the F-18 as well.
FoamJunkE is offline Find More Posts by FoamJunkE
Discussion New! $129 Nitro Planes Rc Landers 70MM F-16D EDF Jet With Retracts FlyBoyTha1 Foamy EDFs 49 Jun 20, 2009 04:58 PM
Discussion Starmax/Exceed RC/Topgun F18-C 70mm what Fan does it use? Stuart B Foamy EDFs 0 May 16, 2009 11:39 AM
New Product New!!! Exceed RC F-22 Raptor 70mm Ducted Fan RC Jet nitroplanes Nitro Planes 9 Apr 19, 2009 07:06 AM
Cool *** UPDATE *** New Version 2 70mm Exceed RC F/A-18C EDF Jet + NEW MOD VIDEO nitroplanes Nitro Planes 2 Mar 20, 2009 04:57 PM
