Old Aug 26, 2011, 07:24 AM
RCflyerCT is offline
Find More Posts by RCflyerCT
RCflyerCT's Avatar
United States, CT, Southbury
Joined Aug 2011
Hey fellas...does your mains have little c-clips holding in the little rod that the metal landing gear connects to? Out of the box, mine did not. I have sense added them when I replaced the retracts but they are hard to get off to fix the little rod if it gets bent. I am thinking about not using them with future retract replacements as the rotation tie bar and clips can hold them in. Any thoughts?
Wes
RCflyerCT is offline Find More Posts by RCflyerCT
Old Sep 09, 2011, 08:39 AM
gpraceman is offline
Find More Posts by gpraceman
gpraceman's Avatar
Highlands Ranch, CO
Joined Nov 2010
I was trying to buy a Sapac MB-1 for my son's F-18, but it seems everyone is out of stock and Sapac America is closing its doors at the end of this month. So, what is a reasonably priced comparable motor to the MB-1? We are not looking to break any speed records, just give much better performance than the anemic stock motor (even more anemic at 6100ft ASL).
gpraceman is offline Find More Posts by gpraceman
Old Sep 09, 2011, 07:07 PM
bolibruch1 is offline
Find More Posts by bolibruch1
Totally!!
bolibruch1's Avatar
USA, AZ, Tempe
Joined Jan 2009
I paid 75$ for mine, I think the website was called edfhobbies.com??
bolibruch1 is offline Find More Posts by bolibruch1
Old Sep 09, 2011, 08:01 PM
gpraceman's Avatar
Highlands Ranch, CO
Joined Nov 2010
Sold out. Same with the few other US sources that I have found.
Old Sep 09, 2011, 09:54 PM
fredmdbud is online now
Find More Posts by fredmdbud
fredmdbud's Avatar
USA, MD, Frederick
Joined Jan 2010
It is? Their website doesn't say anything about it.
fredmdbud is online now Find More Posts by fredmdbud
Old Sep 10, 2011, 12:36 AM
gpraceman's Avatar
Highlands Ranch, CO
Joined Nov 2010
Here's from an email that I received from Sapac when trying to order the MB-1 from their website.
Just to clear up things. SAPAC the company, as owned by Mike Fallon is closing because he is retiring. SAPAC the brand will be carried through by other members including myself. That is, all products and parts will be supported in the future. SAPAC will become a legacy brand as the new company and label will not only carry parts, the airframes will be updated and refined.
The new company is called Alert5 RC and will be announce shortly. thanks for your support and understanding.
See also http://www.rcgroups.com/forums/showthread.php?t=1502354
Old Sep 15, 2011, 05:13 PM
ColoradoHeliNut is offline
Find More Posts by ColoradoHeliNut
United States, CO, Lakewood
Joined Mar 2007
Very sad to see Sapac closing up shop. I hope the new company will dso well. Not sure why they would want to loose the name Sapac though.
Sure hope they keep the MB-1 combo going.
ColoradoHeliNut is offline Find More Posts by ColoradoHeliNut
Old Sep 15, 2011, 07:02 PM
fredmdbud's Avatar
USA, MD, Frederick
Joined Jan 2010
Could be a licensing issue, or they plan on offering products from several other manufacturers, too.
Old Sep 22, 2011, 09:33 AM
wow1 is offline
Find More Posts by wow1
wow1's Avatar
upstate NY
Joined Jan 2010
Is the CG listed in the manual good on this one? measured off the nose as in the diagram then measured off wing as in diagram came up with two different locations! maybe its just me.
Thanks, Karl
wow1 is offline Find More Posts by wow1
Old Sep 23, 2011, 05:52 AM
RCflyerCT's Avatar
Joined Aug 2011
Karl,
I measured from the nose on mine. The CG was perfect for me. I love this airplane.
Wes
Old Sep 23, 2011, 08:32 AM
Bajora is online now
Find More Posts by Bajora
AA6JB
Bajora's Avatar
Joined Sep 2004
Originally Posted by RCflyerCT View Post
Thanks again..the fix worked perfectly...4 great flights on Friday. I absolutely LOVE how this jet flies!
I agree...I had mine out for the first time in a few months. What a sweet flyer!
Bajora is online now Find More Posts by Bajora
Old Sep 26, 2011, 01:10 PM
wow1 is offline
wow1's Avatar
upstate NY
Joined Jan 2010
Thanks for the reply. This plane is easier to fly than the BH f18 more surface area I'm guessing, however it is a little slower. As far as durability goes I really gave that a test yesterday doing an inverted pass pulled back on the stick and slammed it into the ground HARD!!!! After a few hours and a bunch of Epoxy she not only flies good but looks good as well. Having had this type of brain failure in the past I can tell you without out a doubt that the BH planes do not return from such an impact different type of foam for sure. I'm giving this plane a 9.5 and have ordered a more powerful motor 3400kv I believe making this a ten plus plane for sure! For those wondering hand launches are no trouble I don't install the landing gear or armorment but can see no problem hand launching with gear installed.
Karl
Old Sep 28, 2011, 12:19 AM
will3kgt is offline
Find More Posts by will3kgt
will3kgt's Avatar
Grand Blanc, MI
Joined Jan 2007
This tends to be a slower plane than most this size. I just fly mine scale.
will3kgt is offline Find More Posts by will3kgt
Old Sep 29, 2011, 09:02 PM
Totally!!
bolibruch1's Avatar
USA, AZ, Tempe
Joined Jan 2009
Mine moves pretty good with a sapac 70mm in it. And also with foam you should use foam safe super glue because the exopy will eventually get brittle, I have seen wings fall off foam planes because of this. Thin c.a sorta creates a chemical reaction where it gets into both sides and creates a better bond, but use thin c.a
Old Sep 30, 2011, 03:37 AM
Joined Mar 2007
Well the main thing is to ad a CF rod through the whole thing. Why Andy didn't at least use Rods from the wings into the fuse is beyond me.
I'll bet Andy's new 90mm F-18 is just like this one when it comes to the design of the wing to the fuse as strength goes.
So sad Sapac is gone now. I hope the New company continues to market the Combo under a new name. The MB-1 is one of the best COST EDF combos out there. I have it in both my T-50's & Venom F-86.
Discussion New! $129 Nitro Planes Rc Landers 70MM F-16D EDF Jet With Retracts FlyBoyTha1 Foamy EDFs 49 Jun 20, 2009 04:58 PM
Discussion Starmax/Exceed RC/Topgun F18-C 70mm what Fan does it use? Stuart B Foamy EDFs 0 May 16, 2009 11:39 AM
New Product New!!! Exceed RC F-22 Raptor 70mm Ducted Fan RC Jet nitroplanes Nitro Planes 9 Apr 19, 2009 07:06 AM
Cool *** UPDATE *** New Version 2 70mm Exceed RC F/A-18C EDF Jet + NEW MOD VIDEO nitroplanes Nitro Planes 2 Mar 20, 2009 04:57 PM
