Old Apr 02, 2011, 01:50 PM
john_53_70 is offline
Find More Posts by john_53_70
john_53_70's Avatar
south alabama
Joined Dec 2010
Well I'm flying mine with a lander 68mm unit on high timing so at 4 min that gives me a enough time for a gear pass and a go around if I need to
john_53_70 is offline Find More Posts by john_53_70
Old Apr 02, 2011, 08:15 PM
john_53_70's Avatar
south alabama
Joined Dec 2010
So just a tip guys on my jet it snaps to the right on a power off stall so for those putting bigger edf units beware of it but you can use that to do some cool maneuvers
Old Apr 02, 2011, 10:10 PM
fredmdbud is offline
Find More Posts by fredmdbud
fredmdbud's Avatar
USA, MD, Frederick
Joined Jan 2010
Is the ESC braking function turned on? Sounds like when you abruptly throttle down, the motor and fan halt, and conservation of momentum imparts a rolling impulse force. To avoid this, you can either reprogram the ESC to turn braking off, or just throttle down slower.
fredmdbud is offline Find More Posts by fredmdbud
Old Apr 02, 2011, 10:25 PM
john_53_70's Avatar
south alabama
Joined Dec 2010
Never thought about that I guess I'll have to check it out thanks Tho
Old Apr 04, 2011, 08:23 PM
toughitaliankid is offline
Find More Posts by toughitaliankid
Joined Feb 2007
Took mine out for the first time tonight. I took off for the infield of a local softball field. She got up quick but was initially sluggish in the air. I think it was because I pulled it up to early.
My gear doors got suck to the up position on rotation so I could not pull the gears up. I guess I will lengthen the strings to open the doors more.
On my final approach, I flared to a nice high aoa and greased her in along the 2nd base line. after opening the gear doors by hand and flipping the switch....the gears went up and would not go into the well. The shafts on the main gears bent!
I took it home and got all the kinks straightened out. Has anybody else had this issue. I put her down pretty smooth and did not expct to bend anything.
toughitaliankid is offline Find More Posts by toughitaliankid
Old Apr 06, 2011, 10:25 PM
john_53_70's Avatar
south alabama
Joined Dec 2010
Yes I've had that problem just about every time I land the thing I've found that a fast smooth landing on pavment helps with the issue. but I made my rear wheel whales bigger with a dermal tool. And other then that I just bend the things back but there are some what of a pain and save your self the time on the gear doors they will not work unless
You use a servo
Old Apr 06, 2011, 11:21 PM
ez2bgman is offline
Find More Posts by ez2bgman
ez2bgman's Avatar
Joined Jun 2006
You use a servo
Like John said, I too just enlarged the wheel wells a bit with my dremel. I too would remove the main gear doors. Both John and I messed with ours for hours to get them working right on the bench, but once your airborne they don't work worth a darn.
Hopefully I can get my next kit soon so that I can have her ready for the Airshow at our Naval Base next month. Our club flies early in the morning every time the Airshow comes down here. I may build a Blue Angel version, since they will be performing.
ez2bgman is offline Find More Posts by ez2bgman
Old Apr 07, 2011, 09:41 PM
Joined Feb 2007
Has anybody gotten the rear doors to work ? I may plug the wheel wells so it does not create the cheater hole/vacuum effect that sucks the doors up. I will cut some 6mm depron discs and glue them in.
Old Apr 07, 2011, 09:56 PM
j3tman is offline
Find More Posts by j3tman
Were..is..my..Super..Suit ..
j3tman's Avatar
United States, NE, Papillion
Joined Sep 2009
I gave up on mine, but if you can get yours to work please share
j3tman,
j3tman is offline Find More Posts by j3tman
Old Apr 08, 2011, 04:17 PM
john_53_70's Avatar
south alabama
Joined Dec 2010
Have you flown yours yet jetman
Old Apr 08, 2011, 09:37 PM
j3tman is offline
j3tman's Avatar
Joined Sep 2009
Nooooooooooooooooo but trust me once I get the chance I will let the whole world know lol
j3tman,
Old Apr 08, 2011, 10:38 PM
john_53_70's Avatar
south alabama
Joined Dec 2010
Don't fell bad I only got about 7 flights on mine, so much flying to do and so little time since I'm started my next edf project already
Old Apr 08, 2011, 10:57 PM
j3tman is offline
j3tman's Avatar
Joined Sep 2009
If only I did not have to sleep then I would have a lot more time to fly.
j3tman,
Old Apr 09, 2011, 06:56 AM
Joined Feb 2007
Took her out again last night. The doors are almost impossible to operate with the strings. Upon rotation the slipstream pushes them shut. I did several goes at it and no luck. Back to the drawing board.
Old Apr 09, 2011, 09:31 AM
j3tman is offline
j3tman's Avatar
Joined Sep 2009
Maybe one could get a very small servo like a 2.5g servo and use that to operate the gear doors, it might be an idea worth messing with I think.
j3tman,
Discussion New! $129 Nitro Planes Rc Landers 70MM F-16D EDF Jet With Retracts FlyBoyTha1 Foamy EDFs 49 Jun 20, 2009 04:58 PM
Discussion Starmax/Exceed RC/Topgun F18-C 70mm what Fan does it use? Stuart B Foamy EDFs 0 May 16, 2009 11:39 AM
New Product New!!! Exceed RC F-22 Raptor 70mm Ducted Fan RC Jet nitroplanes Nitro Planes 9 Apr 19, 2009 07:06 AM
Cool *** UPDATE *** New Version 2 70mm Exceed RC F/A-18C EDF Jet + NEW MOD VIDEO nitroplanes Nitro Planes 2 Mar 20, 2009 04:57 PM
