Old Mar 13, 2011, 03:03 AM
ez2bgman is offline
Find More Posts by ez2bgman
ez2bgman's Avatar
Joined Jun 2006
Originally Posted by Goody63 View Post
Hi All
I'm looking at the 'Kit' version of the F/A-18 (can't afford the ARF atm) to replace my recently demolished Freewing SU-34 (may that most magnificent flyer RIP ).
I'm probably initially just planning on even using one of the Freewing motors and esc's on the 70mm fan (I presume that will work ok).
Anyway I was wondering if the Kit version has the mouldings etc to be easily set up wuth retracts later on?
Also has anyone set up retracts on one of these using a cheaper system than the Exceed/Arc system (e.g. something from Hobby City).
I appologise in advance if these questions have been answered somewhere else in the thread but I couldn't find them.
Cheers for any help or advice!!
If you get the retract version of the kit, it will have everything you need to set it up (i.e. the retracts, gear doors, hinges, etc.). It should also come with all the necessary hardware to convert from retracts to fixed gear if you want to go that route.
I haven't seen anyone try different retracts yet. If you plan on using other retracts, be sure that that the main gears rotate 90 degrees as they retract into the wheel wells.
One of the coolest features of the included retracts is the semi-scale appearance of the main gears. They pivot and have some shock absorbtion, very similar to the real Super Hornets landing gear.
ez2bgman is offline Find More Posts by ez2bgman
Old Mar 13, 2011, 09:54 AM
john_53_70 is offline
Find More Posts by john_53_70
john_53_70's Avatar
south alabama
Joined Dec 2010
KIT Retract Readiness
Hi All
The edf unit out of you su will not work the motor is to small of diameter to screw into a 70mm fan and the 64mm will not fit to well or put out that much thrust Becuse to much air leakes around the fan, I have the same motors and tryied it while I was waiting on my 70mm to come in, take a look at the jettech f-15 every thing you got for your su will slide right over to the f-15, and it fiberglass. About $200 tho, but don't let that you stop you for getting the f-18 Becuse it is a great flying jet
john_53_70 is offline Find More Posts by john_53_70
Old Mar 13, 2011, 08:55 PM
toughitaliankid is offline
Find More Posts by toughitaliankid
Joined Feb 2007
I have not taken mine out yet due to the poor weather her in NY. Does this plane have any noteable differances in flying habits when the gear is up or down?
toughitaliankid is offline Find More Posts by toughitaliankid
Old Mar 13, 2011, 09:32 PM
john_53_70's Avatar
south alabama
Joined Dec 2010
Can't speak for every on but I notice some noticeable pitch changes and it's a good bit slower with them down too
Old Mar 14, 2011, 07:39 AM
Goody63 is online now
Find More Posts by Goody63
How close are those trees?
Goody63's Avatar
Perth, Western Australia
Joined Apr 2008
Cheers for the advice guys!
Goody63 is online now Find More Posts by Goody63
Old Mar 30, 2011, 09:33 PM
dmoreira is offline
Find More Posts by dmoreira
Joined Oct 2010
Rudders
Hi all, i just bought the Jolly Roger from Nitroplanes and would like some directions on how install the rudders.. can i use 2 9gr servos? I search for all this thread but can't find any directions on that. Thanks
dmoreira is offline Find More Posts by dmoreira
Old Mar 30, 2011, 09:41 PM
j3tman is offline
Find More Posts by j3tman
Were..is..my..Super..Suit ..
j3tman's Avatar
United States, NE, Papillion
Joined Sep 2009
I dont have rudders on mine but they go either above or below where the elevator servos are, hope that makes sense
j3tman,
j3tman is offline Find More Posts by j3tman
Old Mar 30, 2011, 10:05 PM
fredmdbud is offline
Find More Posts by fredmdbud
fredmdbud's Avatar
USA, MD, Frederick
Joined Jan 2010
Similar to this:
You could cut off the rudder tabs, then use the remaining cut-outs in the fuselage for the rudder servos.
fredmdbud is offline Find More Posts by fredmdbud
Old Mar 31, 2011, 11:14 AM
dmoreira is offline
Joined Oct 2010
Rudders
Thanks a lot j3tman and fredmdbud for the tips.
Old Mar 31, 2011, 07:52 PM
j3tman is offline
j3tman's Avatar
Joined Sep 2009
Thanks for posting that, it is a perfect example to go off from.
j3tman,
Old Mar 31, 2011, 08:21 PM
dmoreira is offline
Joined Oct 2010
Battery Bay Area
I planning to buy 2 or 3 more batteries for my new F-18 before it arrives (1 month) and would like to know if someone could help on the measures of the battery bay area. i'm planning buy this one http://www.hobbyking.com/hobbyking/s...idProduct=9364 but i'm not sure if it will fit or if it's too much heavy. Any advice will be very welcome.
Thanks in advance.
Old Mar 31, 2011, 08:48 PM
j3tman is offline
j3tman's Avatar
Joined Sep 2009
Those should fit just fine but I would go for something with a higher "C" rating (30C+), just because you get a lot more punch with your batteries.
j3tman,
Old Mar 31, 2011, 09:14 PM
dmoreira is offline
Joined Oct 2010
j3tman,
Thanks a lot... j3tman Your help make my final decision... going to HK checkout
Old Mar 31, 2011, 10:04 PM
john_53_70's Avatar
south alabama
Joined Dec 2010
Check out hobby lobby rc they have a 4s 3200 mAh 20c that works great I got one for mine and I get about 4 min. Out of mine pluse there like 40 bucks http://www.hobby-lobby.com/4_cell_14...33773_prd1.htm
Old Apr 02, 2011, 03:00 AM
ColoradoHeliNut is offline
Find More Posts by ColoradoHeliNut
United States, CO, Lakewood
Joined Mar 2007
You should be getting at least 5 minutes out of that battey. Especially if it's the stock power system. I get almost 4 minutes out of a 2200 45c in my T-50 with a Sapac MB-1 combo. It's very close to the same size & weght as your F/A-18
How much do you have left after 4 minutes?
ColoradoHeliNut is offline Find More Posts by ColoradoHeliNut
Discussion New! $129 Nitro Planes Rc Landers 70MM F-16D EDF Jet With Retracts FlyBoyTha1 Foamy EDFs 49 Jun 20, 2009 04:58 PM
Discussion Starmax/Exceed RC/Topgun F18-C 70mm what Fan does it use? Stuart B Foamy EDFs 0 May 16, 2009 11:39 AM
New Product New!!! Exceed RC F-22 Raptor 70mm Ducted Fan RC Jet nitroplanes Nitro Planes 9 Apr 19, 2009 07:06 AM
Cool *** UPDATE *** New Version 2 70mm Exceed RC F/A-18C EDF Jet + NEW MOD VIDEO nitroplanes Nitro Planes 2 Mar 20, 2009 04:57 PM
