There's another thread on here about the RC Castle version. I do believe it is the same model. When left stock and using the recommended 4S 2200mah or 4S 2650mah battery, she will fly fine. You won't have unlimited vetical, but it will perform well. Leave off all the missles and fuel tanks to reduce drag. With the stock motor, an 80A ESC, and a 4S 3000mah 40C lipo mine flew very well, even with the added weight of the bigger battery and 20 mph winds.
No I understand what y'all mean it's just kinda sad to hear of the few crashes with the wing folding up and then yours with the battery, but yes I did see how sensitive this jet can be when the cg is even perfectly level, but on your battery did you remove any of the foam to make you battery fit or did it slide in nicely, Becuse in mine you really have to force it in there wondering if I should do something there with mine |
In almost all my planes, whether that be EDF's, pylons, etc, I cut out a small rectangle shape foam piece in front of and in back of the battery while it's at it's correct CG. I just hot glue these pieces in and there is no possible movement for the battery. I also use Velcro straps in addition to the foam stoppers. I can take a picture of what I'm describing if you would like.
No problem at all. Here's some pics of one of my foam pylon racers. This plane has two foam holders hot glued in, but only one (the orange one) is visible, as the other is right up next to the firewall. It just happened to work out that way. As you can see, I also left just enough room to route the wires where I wanted them and they are very snug when in place. I hope this helps a bit.
Another thing that can be done is to make a battery tray out of light ply, attach some sticky back velcro to it, glue down a regular velcro strap, and then glue the tray down inside the battery compartment. Then attach the other part of the sticky velcro to the battery. When the battery is mounted, the battery is then velcroed to the tray and then the strap is tightened down over it. This is how we secure our batteries in our helicopters and I have yet to throw a battery during very rapid pirouettes or during a crash. This is how I'm going to secure the battery on the next build! |
![]() When I get to that area of the build, I'll take some pics of the battery compartment and post it here. |
| Thread Tools | |
| Discussion New! $129 Nitro Planes Rc Landers 70MM F-16D EDF Jet With Retracts | FlyBoyTha1 | Foamy EDFs | 49 | Jun 20, 2009 04:58 PM |
| Discussion Starmax/Exceed RC/Topgun F18-C 70mm what Fan does it use? | Stuart B | Foamy EDFs | 0 | May 16, 2009 11:39 AM |
| New Product New!!! Exceed RC F-22 Raptor 70mm Ducted Fan RC Jet | nitroplanes | Nitro Planes | 9 | Apr 19, 2009 07:06 AM |
| Cool *** UPDATE *** New Version 2 70mm Exceed RC F/A-18C EDF Jet + NEW MOD VIDEO | nitroplanes | Nitro Planes | 2 | Mar 20, 2009 04:57 PM |
