Old Jan 11, 2011, 07:19 PM
john_53_70 is offline
Find More Posts by john_53_70
john_53_70's Avatar
south alabama
Joined Dec 2010
I plan on just using duel rates with low at 40% and high at 100% but that's what I'm planing on starting out with I'll have to fine tune it once I get mine in the air
john_53_70 is offline Find More Posts by john_53_70
Old Jan 11, 2011, 07:26 PM
mavdriver is offline
Find More Posts by mavdriver
mavdriver's Avatar
United States, CA, Apple Valley
Joined May 2002
Originally Posted by john_53_70 View Post
I plane on just using duel rates with low at 40% and high at 100% but that's what I'm planing on starting out with I'll have to fine tune it once I get mine in the air
Use Expo start at 50 % then go from there , add less or more if you need it forget the the dual rates once you use expo you will never use dual rates yes you can lessen the throws by using the ATV also , but expo all the way .
mavdriver is offline Find More Posts by mavdriver
Old Jan 11, 2011, 10:25 PM
john_53_70's Avatar
south alabama
Joined Dec 2010
Got question for those of you have your planes already, but one thing that concerns me is when tony crashed his on the high Alfa pass was due to lack of ruder , but I think if he had more aileron control he could have saved it to. So what I’m thinking about doing his hooking one elevator servo to the correct spot on the receiver and hooking up the other on to the aux spot then use my mixing on my dx7 to have the elevator work that way eliminating the need for a y harness then use a second mixing activated by my flap switch to mix the ailerons with the elevators to make elevons what do yall think?
Old Jan 11, 2011, 10:41 PM
j3tman is offline
Find More Posts by j3tman
Were..is..my..Super..Suit ..
j3tman's Avatar
United States, NE, Papillion
Joined Sep 2009
I think an elevon setup would work, because if you look at the f22, f35, and the f16 all of them can fly on an elevon setup, since the F18 kind of has the same setup it would probably work just fine.
j3tman,
j3tman is offline Find More Posts by j3tman
Old Jan 11, 2011, 10:56 PM
fredmdbud is online now
Find More Posts by fredmdbud
fredmdbud's Avatar
USA, MD, Frederick
Joined Jan 2010
Looks like when he stalled, the only thing that would have saved him was altitude to gain enough speed for lift and control authority. Control surfaces on a stalled wing do nothing.
fredmdbud is online now Find More Posts by fredmdbud
Old Jan 12, 2011, 07:26 PM
john_53_70's Avatar
south alabama
Joined Dec 2010
Finally got mine, got the right gear doors as well! But on the control horns are y'all just glueing them on or are y'all using screws as well
Old Jan 12, 2011, 07:50 PM
j3tman is offline
j3tman's Avatar
Joined Sep 2009
I just glued mine didn't really think about doing that, maybe I should.
j3tman,
Old Jan 12, 2011, 08:11 PM
T-CAT is offline
Find More Posts by T-CAT
Loves Lasagna
T-CAT's Avatar
Joined Aug 2008
I always use a dab of hot glue AND screw them in. It gives a little extra security.
T-CAT is offline Find More Posts by T-CAT
Old Jan 12, 2011, 08:44 PM
demattos62 is offline
Find More Posts by demattos62
Joined Oct 2010
Thank for the reply but what are the throws at 100% and 40% and what holes in the servo arms and control arms should use because that would affect the throws also? Sorry but my plane didnt come with a book just a sheet that only shows the CG
demattos62 is offline Find More Posts by demattos62
Old Jan 12, 2011, 08:52 PM
j3tman is offline
j3tman's Avatar
Joined Sep 2009
First what radio are you using? second the farther away the control rod is from the center the less through it will have but for most radios you can control the amount of through on your radio. Third you might of said this already but do you have this plane?
j3tman,
Old Jan 12, 2011, 08:56 PM
DProseus is online now
Find More Posts by DProseus
Wilson, NC
Joined Jun 2006
it arrived!!
Got my Jolly Roger today. All looks great except the nose gear was loose. Was going to attach with epoxy anyhow.
Bought the PNP version. Noticed on the vid on page 1 of this thread the install of a carbon rod connecting both wings thru the fuse. Since tubes are already in the wings and the fuse is buttoned up, couldn't you just get a rod to sleeve inside the existing tubes and put it thru the fuse for support?
Wife is out of town this weekend. Wonder what I will do to fill the time
Dick
DProseus is online now Find More Posts by DProseus
Old Jan 12, 2011, 08:59 PM
j3tman is offline
j3tman's Avatar
Joined Sep 2009
Welcome to the club!!!!
I don't know if i really understand what you are saying about the CF rods?
j3tman,
Old Jan 12, 2011, 09:14 PM
Joined Oct 2010
Yes I bought it last weekend at the AMA show. I have a DX7 I'm just use to plan telling me throws like 1/2" at low rates 3/4" at high rates etc. I really want to fly this one this weekend, I fly a habu now.
Old Jan 12, 2011, 09:37 PM
j3tman is offline
j3tman's Avatar
Joined Sep 2009
Ok what I would do if attach the control rods to the outermost hole, then on your radio for your ailerons your plane is longer then it is wider so it will role fast so set them at like 50-60%, and your elevator set it at like 60-70%. That is just what I would do for your maiden flight and then after that you can fine tune your control setup.
j3tman,
Old Jan 12, 2011, 11:47 PM
Joined Oct 2010
Ok thanks, I'll let you know how it goes
Discussion New! $129 Nitro Planes Rc Landers 70MM F-16D EDF Jet With Retracts FlyBoyTha1 Foamy EDFs 49 Jun 20, 2009 04:58 PM
Discussion Starmax/Exceed RC/Topgun F18-C 70mm what Fan does it use? Stuart B Foamy EDFs 0 May 16, 2009 11:39 AM
New Product New!!! Exceed RC F-22 Raptor 70mm Ducted Fan RC Jet nitroplanes Nitro Planes 9 Apr 19, 2009 07:06 AM
Cool *** UPDATE *** New Version 2 70mm Exceed RC F/A-18C EDF Jet + NEW MOD VIDEO nitroplanes Nitro Planes 2 Mar 20, 2009 04:57 PM
