Old Feb 14, 2013, 05:50 PM
WTN
Joined Jan 2013
This is a newbie question. I will add rudders to my plane. When you guys (that have rudders) are steering the plane, do you use both ailerons and a mix of rudders? (This is when you are in the air)
How about for landing? I would think just rudders?
Since the channel controls the front gear. Like in the middle.
WTN
WTN is offline Find More Posts by WTN
Old Feb 14, 2013, 05:57 PM
foam jet driver
United States, TX, Arlington
Joined Jul 2012
WTN
Rudders on F18s tend to induce a roll. You'll need to give some opposite aileron input to make level turns using rudders.
Suggest practicing on the sim using a jet that rolls on the rudder.
Rangerfan is offline Find More Posts by Rangerfan
Old Feb 14, 2013, 10:35 PM
Joined Jun 2005
3rd-dem,
I was just wondering what kind of speed/vertical and flight time you were getting with your power set up? Thanks for your help!
ndfanatix
ndfanatix is offline Find More Posts by ndfanatix
Old Feb 14, 2013, 11:48 PM
Nova Scotia, Canada
Joined Jun 2006
Roger on that induced "roll effect"; I built the much threaded 70mm Starmax F-18 indeed very similar to this one last year. Most left rudders out but those that did complained of rapid rolls and even several lost the jet due to incorporating rudders. Now perhaps they put throws to much but just letting you know its not really needed for the Exceed version either.
"TIMBITS" is offline Find More Posts by "TIMBITS"
Old Feb 15, 2013, 12:30 AM
advanced n00b
xfatdannx's Avatar
United States, NE, Omaha
Joined Feb 2012
Rudder will induce a pitch down on any plane if there is not opposite aileron input. I was taught the scale way to make turns is to turn the rudder the way you want to turn and correct with the aileron. on a full scale plane this keeps the whole plane on the turning line and prevents "slip" (where the nose and tail are not on the same turn line, lowing actual control through the turn). from the planes i have flown since being in the hobby though, it doesn't seem to have a huge affect on them. Most of my planes were sold as crank and yank (no rudder). I have just added it later.
xfatdannx is offline Find More Posts by xfatdannx
Old Feb 15, 2013, 10:05 AM
foam jet driver
Joined Jul 2012
I had the same bird. I set her up as a hand launch and then turned the rudders into an airbrake. Gave it a great nose up attitude when deployed.
The only jet I've found to turn well with rudder only (no or little aileron input) is the f4 and a4.
I didn't do rudders on this one because of my lack of enjoyment with them on the starmax f18.
Old Feb 15, 2013, 10:36 PM
Nova Scotia, Canada
Joined Jun 2006
[QUOTE=Rangerfan;24143447]I had the same bird.
Not great luck with mine "Ranger" - used a 3000 mah batt and found the hand tosses "iffy" at times - hoping better launches with this one as I'll try the same battery. The Starmax version had a smaller kv motor in it compared to this Exceed one so hoping I won't have trouble getting it up on step after "the chuck"
Old Feb 16, 2013, 02:43 AM
Joined Nov 2005
Same with F14...I'm thinking it's twin rudder thang...
I have the rudder expos on that jet set really really high
erh7771 is offline Find More Posts by erh7771
Old Feb 16, 2013, 05:18 AM
Joined Apr 2012
sharing the onboard flight and the landing strip at the park...nerve wrecking landing....
Select HD 1080 in youtube while watching for better resolution!
http://www.youtube.com/watch?v=bNMRD5JDYIs
viperviper is online now Find More Posts by viperviper
Old Feb 16, 2013, 06:37 AM
Joined Apr 2012
deleted.. double posting.
Old Feb 16, 2013, 09:04 PM
Joined Apr 2012
Another F-18 70mm flight with low altitude passes not speed passes as i forgotten to change the wording in the video. Watch for the landing too!!!
Set video quality to HD in Youtube!
cheers!
F 18 JR 3D 70mm flight (3 min 59 sec)
Old Feb 16, 2013, 09:45 PM
BlackBeast's Avatar
Canada, QC, Témiscouata-sur-le-Lac
Joined Dec 2008
Originally Posted by viperviper View Post
Another F-18 70mm flight with low altitude passes. Watch for the landing too!!!
cheers!
http://www.youtube.com/watch?v=ygIrYz4Uth0
Nice landing!!!!
Which lipo do you use? Three minutes on your timer? Ten blades fan?
BlackBeast is offline Find More Posts by BlackBeast
Old Feb 16, 2013, 09:59 PM
Flying from Vic Park
Australia, SA, Adelaide
Joined May 2011
Nice flying.
Great_Goose is offline Find More Posts by Great_Goose
Old Feb 16, 2013, 11:01 PM
Joined Apr 2012
Originally Posted by BlackBeast View Post
Nice landing!!!!
i'm using 4S 4000mah 45-90C lipo. 3mins on timer, normally i will allow it to beep and then i will line up to land. Yes, 10 blades fan.
Old Feb 16, 2013, 11:03 PM
Joined Apr 2012
Originally Posted by Great_Goose View Post
Nice flying.
tks!
Discussion New! $129 Nitro Planes Rc Landers 70MM F-16D EDF Jet With Retracts FlyBoyTha1 Foamy EDFs 49 Jun 20, 2009 04:58 PM
Discussion Starmax/Exceed RC/Topgun F18-C 70mm what Fan does it use? Stuart B Foamy EDFs 0 May 16, 2009 11:39 AM
New Product New!!! Exceed RC F-22 Raptor 70mm Ducted Fan RC Jet nitroplanes Nitro Planes 9 Apr 19, 2009 07:06 AM
Cool *** UPDATE *** New Version 2 70mm Exceed RC F/A-18C EDF Jet + NEW MOD VIDEO nitroplanes Nitro Planes 2 Mar 20, 2009 04:57 PM
