Old Jan 16, 2013, 08:57 AM
xfatdannx is offline
Find More Posts by xfatdannx
advanced n00b
xfatdannx's Avatar
United States, NE, Omaha
Joined Feb 2012
Originally Posted by sheerkon View Post
Does this mean you are going to sell the airframe? I'd be interested in buying that from you. I live on the east coast usa.
Thx for your time.
honestly i would be willing too but its just too big to ship..in the end you would prolly be better off getting the kit from NP, unless you were looking for the blue angel scheme. then still get one from NP and paint it
xfatdannx is offline Find More Posts by xfatdannx
Old Jan 16, 2013, 09:57 AM
WTN is offline
WTN
Find More Posts by WTN
WTN
Joined Jan 2013
Originally Posted by WTN View Post
Well,
Just spent one hour with a follow up post .
And there it goes.
Been a few days, but I was so disgusted, I set the build project aside and went to other projects. While I was gluing the main wings on, the aileron on the left wing fell off. Just great. I was thinking about hinges, but I just went and ordered a new wing from Nitro. Now I am thinking, are these that fragile? Should I back them up with hinges, or maybe they are not designed to be hinged? Of course the left wing is now firmly glued on, so I will have to cut it out - plus I have the CF rod to contend with. Gee, this is fun.
WTN
WTN is offline Find More Posts by WTN
Old Jan 16, 2013, 11:35 AM
advanced n00b
xfatdannx's Avatar
Joined Feb 2012
i never had problems with my foam pressed hinges but if i were you i would just go with plastic hinges. would be way easier and more reliable.
Old Jan 17, 2013, 01:45 AM
advanced n00b
xfatdannx's Avatar
Joined Feb 2012
I was looking at this pic and thinking, if they would mount the retracts at a 30*-40* angle they may be able to pull of a more scale look and a WAY more reliable gear in general. Notice in this pic the wheels are wider than the vertical stabs, where as in our model, the gear are about as wide as the stabs if not a little more narrow. Also i think a scale model would sit a little lower to the ground than our model. Just an observation i made.
Old Jan 17, 2013, 08:44 AM
WTN is offline
WTN
WTN
Joined Jan 2013
So, this is doable? I have seen some small plastic hinges at the LHS.
Two per side? Screw and glue?
WTN
Old Jan 17, 2013, 11:18 AM
erh7771 is offline
Find More Posts by erh7771
Joined Nov 2005
you're right on the gear...
Makes me think we can put a shim on one side of the gear for a wider stance and it'll still fold up into the wheel spaces.
erh7771 is offline Find More Posts by erh7771
Old Jan 17, 2013, 04:38 PM
advanced n00b
xfatdannx's Avatar
Joined Feb 2012
WTN
Easy to do actually. I did it on a few planes bc their foam hinges looked no good. I also did it for the rudder on this plane. On this plane i would go 3 each side just bc there is more force exerted on it than a slower prop plane.
possible, but you would probably have to shave the wheel wells a little bit. not a huge deal. The other thing that comes to mind is the shaft that connects the strut to the retract, thats the part on mine that had the most issue. May not be strong enough if not vertical, but that comes down to your planes weight.
Old Jan 17, 2013, 08:41 PM
Mesher is offline
Find More Posts by Mesher
Mesher's Avatar
Joined Apr 2012
Can you buy this plane anywhere other than nitroplanes? NP just has ridiculous shipping costs to Australia.
Mesher is offline Find More Posts by Mesher
Old Jan 18, 2013, 02:03 AM
Great_Goose is offline
Find More Posts by Great_Goose
An aspirational fast jet pilot
Great_Goose's Avatar
Australia, SA, Adelaide
Joined May 2011
Try; www.x-flight.com.hk
Great_Goose is offline Find More Posts by Great_Goose
Old Jan 18, 2013, 02:12 AM
fredmdbud is online now
Find More Posts by fredmdbud
fredmdbud's Avatar
USA, MD, Frederick
Joined Jan 2010
Would Hong Kong be any better?
http://www.x-flight.com.hk/index.php...=1&new=&more=&
fredmdbud is online now Find More Posts by fredmdbud
Old Jan 18, 2013, 02:24 AM
Joined May 2011
I am yet to pull the trigger on the F-18 70mm but when I looked at the shipping it was only about $30.00.
Old Jan 18, 2013, 06:33 AM
Mesher is offline
Mesher's Avatar
Joined Apr 2012
Cool thx I'll have a look!
Old Jan 19, 2013, 08:15 AM
gilera180 is offline
Find More Posts by gilera180
gilera180's Avatar
Singapore, Singapore
Joined Oct 2007
Agreed totally, ridiculous shipping charge and took 3 weeks to arrived.
gilera180 is offline Find More Posts by gilera180
Old Jan 21, 2013, 12:10 PM
Roen is offline
Find More Posts by Roen
United States, VA, Norfolk
Joined Oct 2006
I just thought I'd share a couple of pictures of my Exceed RC F/A-18F Super Hornet while I'm at work on a 12 hour "watch" at my US Navy squadron VFA-87.
Specs for my jet:
>RCLander 68mm DPS 2200KV 6S EDF unit
>80A Detrum ESC with 5A BEC
>Turnigy nano-tech 3300mah 6S battery
>2 RCLander LS-2 metal gear servos for elevators, 2 Detrum 9g standard servos for ailerons, and 2 stock old plane servos for rudders
>Maxilights custom lights kit
More information in my blog. Hope you like!
Roen is offline Find More Posts by Roen
Old Jan 21, 2013, 01:29 PM
Coot83 is offline
Find More Posts by Coot83
You haz hurricane?
Coot83's Avatar
United States, VA, Alexandria
Joined Jun 2012
Good Ol' Oceana.
Coot
Coot83 is offline Find More Posts by Coot83
Discussion New! $129 Nitro Planes Rc Landers 70MM F-16D EDF Jet With Retracts FlyBoyTha1 Foamy EDFs 49 Jun 20, 2009 04:58 PM
Discussion Starmax/Exceed RC/Topgun F18-C 70mm what Fan does it use? Stuart B Foamy EDFs 0 May 16, 2009 11:39 AM
New Product New!!! Exceed RC F-22 Raptor 70mm Ducted Fan RC Jet nitroplanes Nitro Planes 9 Apr 19, 2009 07:06 AM
Cool *** UPDATE *** New Version 2 70mm Exceed RC F/A-18C EDF Jet + NEW MOD VIDEO nitroplanes Nitro Planes 2 Mar 20, 2009 04:57 PM
