Old Dec 04, 2012, 11:42 AM
Rangerfan is offline
Find More Posts by Rangerfan
Rangerfan's Avatar
United States, TX, Grapevine
Joined Jul 2012
Originally Posted by washab View Post
Expecting delivery of this bird in the next couple of days.
Hope someone can help/clarify...
Assuming that the esc-battery leads need to be extended so the esc can sit in the "vented" location under the fuse. Will the extended run from esc to battery be short enough not to cause added ripple voltage or is the addition of capacitors needed?
In other words - can I just extend the leads and get on with life?
I don't see why not. I added length to my esc leads to get from battery compartment to the belly cooling vents. No problems that I'm aware of.
Rangerfan is offline Find More Posts by Rangerfan
Site Sponsor
Old Dec 04, 2012, 11:45 AM
washab is offline
Find More Posts by washab
ROLL, PITCH, YAW
washab's Avatar
Joined Jan 2011
Ranger
Thanks. Just had some curiosity about it. Maybe over-thinking the process...
washab is offline Find More Posts by washab
Old Dec 04, 2012, 11:51 AM
Rangerfan's Avatar
Joined Jul 2012
Washab- What set up do you have planned for yours?
Site Sponsor
Old Dec 05, 2012, 12:14 AM
xfatdannx is offline
Find More Posts by xfatdannx
advanced n00b
xfatdannx's Avatar
United States, NE, Omaha
Joined Feb 2012
Washab, part of the reason inwent with 2 2s batteries was bc i needed an extension for the leads coming off the ESC. This meant i had to make a connector to hook 2 batteries up in series and gave me the added length of lead wire needed to make it from battery to ESC. I have had no issues with ith either. I dont think there would be any problem adding a little bit of length to the ESC leads.
xfatdannx is offline Find More Posts by xfatdannx
Old Dec 05, 2012, 07:28 AM
washab is offline
ROLL, PITCH, YAW
washab's Avatar
Joined Jan 2011
I have a 10 blade aluminum alloy fan unit from HK already sitting around:
http://www.hobbyking.com/hobbyking/s..._1200watt.html
Hobbywing 100A ESC
3300 4S 40C bat
TP mg servos already in my stock as well.
I ran this up on the bench. It was putting out 1040 watts, pulling 77 amps.
I don't care much for having a rocket but figured since I already have these components I'll give it a try. Going to reinforce the heck out of everything as I've read here that some have lost wings.
I'll just fly it 1/2 to 3/4 throttle all the time but nice to know you have that extra punch.
Should have that nice wooosh sound at least.
Old Dec 05, 2012, 07:30 AM
washab is offline
ROLL, PITCH, YAW
washab's Avatar
Joined Jan 2011
thanks for the input. i'll take all into consideration. scheduled delivery for tomorrow
Old Dec 05, 2012, 06:28 PM
Rangerfan's Avatar
Joined Jul 2012
Hobbywing 100A ESC
3300 4S 40C bat
That should rock. I think you'll probably like it
Site Sponsor
Old Dec 07, 2012, 07:58 PM
Ispintechno is offline
Find More Posts by Ispintechno
Defender of the park sky
Ispintechno's Avatar
London, ON Canada
Joined Nov 2009
January is my build month, taking some time off work to raise babies. Shot a quick vid of the immediate mods but I've done lots of drawings and mulled over full flying stabs and have the parts too. That will be after.
Exceed F-18E Super Hornet LED Afterburner/Motor Fan change part 1 (2 min 39 sec)
Ispintechno is offline Find More Posts by Ispintechno
Old Dec 08, 2012, 08:37 PM
Rangerfan's Avatar
Joined Jul 2012
Has anyone put retracts directly onto the wing on this one? I know it would be the furthest thing from scale but I'm guessing it would greatly improve ground handling. Perhaps you could hide them with ordanance or drop tanks?
Just a thought.
Site Sponsor
Old Dec 08, 2012, 08:40 PM
Rangerfan's Avatar
Joined Jul 2012
http://www.youtube.com/watch?v=Sl4-lcQcTFY
Keep us posted on how this turns out. Interested in the full stabs idea!
And good luck with the babies! Future RC pilots!
Site Sponsor
Old Dec 08, 2012, 09:24 PM
London, ON Canada
Joined Nov 2009
Will do! And thanks!
Old Dec 10, 2012, 10:19 AM
advanced n00b
xfatdannx's Avatar
Joined Feb 2012
Started getting cold and windy here lately. haven't gone out in two weeks
Old Dec 10, 2012, 11:06 AM
will3kgt is offline
Find More Posts by will3kgt
will3kgt's Avatar
Grand Blanc, MI
Joined Jan 2007
Good luck with the builds. The CS fan will serve you well defending your side of the lake.
will3kgt is offline Find More Posts by will3kgt
Old Dec 10, 2012, 01:42 PM
washab is offline
ROLL, PITCH, YAW
washab's Avatar
Joined Jan 2011
Exceed F-18 Delivered
So I got a delivery of this plane the other day ($80 kit version):
1. I did not luck up and get the retracts as a couple here said they did with the $80 kit. No biggie, got what I paid for anyway.
2. This kit version's fuse was already glued-up. Will save me on some glue efforts but now I need to engineer getting a reinforcement CF rod in the correct place for the wings.
3. Didn't see any wing tip rails??? Should I have gotten some
I do like the workmanship on this bird. Can't beat it for an $80 airframe. I'm sure I'll enjoy this one.
Old Dec 10, 2012, 01:49 PM
Rangerfan's Avatar
Joined Jul 2012
I think the wing tip rails have the sidewinder missles on them. If you want rails without missles, I think you'll have to fabricate some from ply or balsa.
You gonna go with landing gear or go football style?
Site Sponsor
Discussion New! $129 Nitro Planes Rc Landers 70MM F-16D EDF Jet With Retracts FlyBoyTha1 Foamy EDFs 49 Jun 20, 2009 04:58 PM
Discussion Starmax/Exceed RC/Topgun F18-C 70mm what Fan does it use? Stuart B Foamy EDFs 0 May 16, 2009 11:39 AM
New Product New!!! Exceed RC F-22 Raptor 70mm Ducted Fan RC Jet nitroplanes Nitro Planes 9 Apr 19, 2009 07:06 AM
Cool *** UPDATE *** New Version 2 70mm Exceed RC F/A-18C EDF Jet + NEW MOD VIDEO nitroplanes Nitro Planes 2 Mar 20, 2009 04:57 PM
