Old Oct 21, 2012, 07:47 AM
Rangerfan is offline
Find More Posts by Rangerfan
Rangerfan's Avatar
United States, TX, Grapevine
Joined Jul 2012
Originally Posted by BlackBeast View Post
Hi all,
I would like to know something before buying the kit version.
Do the holes for the landing gears/servos less retracts are already pre cutted? Or no holes at all?
Thx!
Yes. They are precut.
Rangerfan is offline Find More Posts by Rangerfan
Site Sponsor
Old Oct 21, 2012, 08:13 AM
herk1 is offline
Find More Posts by herk1
Trash Hauler emeritus
herk1's Avatar
Maryland, USA
Joined Oct 2006
Originally Posted by Rangerfan View Post
Herk- nice work. You'll enjoy the peace of mind knowing that the retracts are as solid as they can be now. I've only got a few flights in on mine so far but its proven (to me) to be much improved.
Also, are yours much quieter than the stock ones were? Mine are nearly silent.
No, of the retracts that I have, the E-flite retracts are actually a little louder than the Exceed ones. I have another set of E-flite 10-15 tricycle retracts in another plane, and I did a YouTube video showing them in action. This is what they sound like:
Chuck glider transformed to RC plane with retractable landing gear (5 min 12 sec)
The set of E-flite retracts that I put in my F/A-18 sound the same as the set in that video.
herk1 is offline Find More Posts by herk1
Old Oct 21, 2012, 08:39 AM
will3kgt is offline
Find More Posts by will3kgt
will3kgt's Avatar
Grand Blanc, MI
Joined Jan 2007
Originally Posted by herk1 View Post
Finally installed the E-flite nose retract in my F/A-18. I shouldn't have put it off so long. This morning, the wobbly/dodgy stock nose strut sent my model suddenly careening off the runway on takeoff roll, and when it hit the edge of the grass at almost takeoff speed, it not only tore out the nose retract (well, that kind of did me a favor...), but it broke the nose of the jet clean off, near the front of the retract well.
To prep for installing the E-flite nose retract, I dremeled down the foam underneath where the torn-out plywood mounts were....excavating all the way down to the "floor" (where the center of the old retract sat). Then I dremeled down another 1/8" to make room for the 1/8"-thick, one-piece plywood mount that I cut.
I found that the stock servo pocket for the nosewheel steering worked perfect. I hot-glued an HS-45 servo in there (my favorite servo to use for nosewheel steering) and hooked it up to the retract's steering linkage using one of the pushrod/clevis parts supplied with the F/A-18 kit for the optional rudders...which was the perfect length (photo).
I just came back from a test flight (actually I flew two flights). Everything worked perfectly. Nice to finally have rock-solid retracts all around. And steady/reliable ground steering.
Excellent work on the nosegear, I
did the same to my F4 and will install a pushrod on my F-18 as well.
will3kgt is offline Find More Posts by will3kgt
Old Oct 21, 2012, 09:07 AM
xfatdannx is offline
Find More Posts by xfatdannx
advanced n00b
xfatdannx's Avatar
United States, NE, Omaha
Joined Feb 2012
can a push rod be used with the stock nose gear or is it just how the eflite branded one is made?
xfatdannx is offline Find More Posts by xfatdannx
Old Oct 21, 2012, 09:12 AM
herk1 is offline
herk1's Avatar
Maryland, USA
Joined Oct 2006
No, you can't use a pushrod with the stock nose gear, because it doesn't have that sliding mechanism that the E-flite unit has to prevent compressing force against the rod. So it depends on the flex of the pull-pull wire.
Old Oct 21, 2012, 09:51 AM
Rangerfan's Avatar
Joined Jul 2012
Kinda odd the amount of noise in them. The set I put in the f18 are new so I figured that eflite replaced something to make them quieter. My older e flites are quite noisy too.
Site Sponsor
Old Oct 24, 2012, 08:06 AM
Drahcir is offline
Find More Posts by Drahcir
United States, FL, Orlando
Joined Jun 2009
Hey Rangerfan, are you talking about the kit version without the retracts or the one with the retracts? I've been looking at this plane for a while.
Drahcir is offline Find More Posts by Drahcir
Old Oct 24, 2012, 08:27 AM
Rangerfan's Avatar
Joined Jul 2012
Both versions should have the retract mounts and bays pre-cut.
Site Sponsor
Old Oct 24, 2012, 08:41 AM
Rangerfan's Avatar
Joined Jul 2012
You'll get probably a 50/50 opinion split on the stock retracts from those that have tried them. IMHO, I think they are too flimsy for the weight of this plane. Once I put a better power system in, naturally a bigger battery is needed. The increased weight is just too much for these retracts (IMHO).
Herk1 and I (and probably some others) both put the eflites in and I personally think they're a much better option. Much more solid (strength) and the quality of the electronics are superior. It was fairly simple to do. Not much modification is needed.
From Nitroplanes, I think the kit is around $80 and the kit with retracts is around $150? The eflites are about $120. So, about $50 more to go with the eflites from the beginning.
Just my opinion. I'm sure others are using the stock retracts. Some without problems. Some with.
Site Sponsor
Old Oct 24, 2012, 08:56 AM
advanced n00b
xfatdannx's Avatar
Joined Feb 2012
i think flaps would help alleviate some of the gear issue i have had. plane moving slower would have less energy therefor less stress on touch down.
Old Oct 24, 2012, 09:08 AM
Rangerfan's Avatar
Joined Jul 2012
Certainly would agree with that.
Site Sponsor
Old Oct 24, 2012, 09:21 AM
advanced n00b
xfatdannx's Avatar
Joined Feb 2012
do you guys have troubles with the eflite retracts with the wheels being closer together.
Old Oct 24, 2012, 11:08 AM
Rangerfan's Avatar
Joined Jul 2012
I haven't. I mod'd them a bit to push them out a bit. I used the wheels that were included for the fixed gear.
Unless you move the mains to the wings, you'll always have a narrow stance. I figured I would just have to teach myself to land with both mains touching down at the same time (which actually is what you want to do anyway, I just need to improve) .
Flaps certainly do help with this.
Site Sponsor
Old Oct 24, 2012, 03:03 PM
advanced n00b
xfatdannx's Avatar
Joined Feb 2012
cool thanks for the tip. i really want the eflite nose gear but i am not sure if i want the whole set.
Old Oct 24, 2012, 03:21 PM
Rangerfan's Avatar
Joined Jul 2012
The other advantage that the eflite nose gear has is that it steers with a pushrod instead of the "always sloppy" (always for me) pull-pull wire arrangement. I found that the ground handling is improved with the better steering set-up. Still have to taxi slowly as the mains are still pretty narrow.
Site Sponsor
Discussion New! $129 Nitro Planes Rc Landers 70MM F-16D EDF Jet With Retracts FlyBoyTha1 Foamy EDFs 49 Jun 20, 2009 04:58 PM
Discussion Starmax/Exceed RC/Topgun F18-C 70mm what Fan does it use? Stuart B Foamy EDFs 0 May 16, 2009 11:39 AM
New Product New!!! Exceed RC F-22 Raptor 70mm Ducted Fan RC Jet nitroplanes Nitro Planes 9 Apr 19, 2009 07:06 AM
Cool *** UPDATE *** New Version 2 70mm Exceed RC F/A-18C EDF Jet + NEW MOD VIDEO nitroplanes Nitro Planes 2 Mar 20, 2009 04:57 PM
