Nice job, and I'm glad to see that the E-flite unit can be fit in there without too drastic surgery. So the stock servo position was not workable?
I think I'm going to borrow your cooling vent idea too (inlet holes tucked out of sight under the leading edge extensions). Except I'm going to locate them farther forward so that the incoming air will pass over the whole battery, for where I'm situating my batteries. And I'll tack on some plastic scoops, to scoop in more air. I'm using 2650 and 3300 size 4S batteries. The 2650 was getting especially hot. |
United States, TX, Arlington
Joined Jul 2012
Herk1- that's a good point on moving the vents forward. In retrospect, I wish I had made them about one inch forward. I'm using 2800's as far back as they'll go but if I use anything larger, the vents won't fully cover the larger battery.
Yeah the stock servo location was no good for getting much throw. Would be limited severely by the arm length. |
Interesting point about the battery cooling. My Zippy 2800's get warm, not puffy warm but clearly not much air movement is happening there. I'm adding two Turnigy nanotechs into the mix though, much higher discharge and will be running a few more watts through this thing too soon. I wonder if turning the nose gun into a couple cooling holes would be enough or do much. Exiting air shouldn't be a problem, there is a huge exit where all the servo wires run back, it's getting air from the nose I think.
Dan, testing the Turnigy L2855-2800 on 4S hooked up to the CS10 70mm, probably on Sunday or Monday. Just need some connectors for my 80amp ESC. Might grab those today at the LHS. |
awesome man. let me know what you get. i am thinking with mine i am gonna have to go 5s to get anyhting out of it. I really don't want to cuz that would render my pretty much brand new batteries useless, and i would need a new charger that can do 5s. The point of staying 4s for me was to do 2s batteries so my 2/3s charger could handle it without a new one. ALTHOUGH!!! i am thinking of getting a second so i can charge my batteries faster. I guess i will just have to play it by ear.
I swapped over the stock power system to my HET fan+motor+ESC (HET 6904 fan, 2W-20 motor, HET 75A ESC w/switchmode BEC). It was nearly a drop-in fit....just a little sanding and trimming. I was surprised when I took out the stock ESC that there are slots under the ESC that open to the interior intake area, I presume for cooling the ESC. So they mounted the stock ESC with the heatsink facing the inside. I'm not sure how effective that will be for cooling though, since they made the slots perpendicular to the airflow instead of parallel, and the foam is pretty deep there. But I followed suit and put the HET ESC's heatsink to the inside too. I made the plastic cover for the ESC and wiring removable with four screws...so after my first test flight I will take that off and check the temp of the ESC. It got pretty hot when I used the same power system in my Habu.
http://www.hobbypartz.com/thac6smbachw.html http://www.hobbyking.com/hobbyking/s...dProduct=10621 http://www.hobbyking.com/hobbyking/s...apter_Set.html What ever brain is in this charger in balance mode I have found it to even fix some turnigy 3 cells that had off balance cells. After many cycles later those batteries are still good after almost throwing a couple away. Anywho, just my 2 cents there. Herk, sounds like a great set-up. Those HET parts seem to be top quality. Wouldn't mind seeing a pic of how you are mounting that ESC cover too. I figure I'll get one more flight off with mine stock than rip it apart after I get a motor/esc combo to work right on the bench. I need a new soldering iron. It's really crapping out. Just need to add motor connectors to my Turnigy superbrain ESC without heating up the whole damn thing. |
To make the belly cover removeable, I cut four small rectangles of 1/8" plywood measuring 7mm X 14mm. Then with a #1 x-acto knife I carved out corresponding chunks in the EPO to fit the wood pieces at the spots shown in the photo...and for extra security, part of that cut goes underneath the "lip" in the EPO at that curved part (about 3mm of the wood piece slides under the "lip"). I then Gorilla-glued in the wood pieces. Then I punched four holes for the screws in the plastic cover using the punch attachment of a pin vise, then put the cover in place and poked thru those holes into the wood pieces to make starter holes for the screws. Photo attached...which also shows numerous other mods I've done so far (and I'm not finished)...including the pass-thru connecting skewer spar, CF tube sleeves for the elevator pushrods, better control horns with screw-down backplates, twin battery compartment inlet cooling vents with air scoops, and a more secure battery tie-down that loops around the outside.
Well today was a mixed bag. Got my LED system working but I broke the CS10 fan... on my hand
![]() Thought I had those 4 little screws on tight to the shaft but the fan flew out the front sideways hitting me in the hand. Lost a little blood. Well this sets me back a few weeks... ![]() Well at least I still have fancy afterburners... |
![]() It kinda flew off the motor shaft before I could detect any vibration lololol I ended up using just a tiny bit of CA, I really couldn't find much wrong with this rotor which bums me out even more as I destroyed it. I did use a simple trick, found this on you-tube:
Joined Nov 2005
I use the 2500kv CP 480 motor and fly mine on 4, 5 and 6s... |
I got a couple of flights in this morning with the HET power system that I just installed. Wow it really woke this plane up! Better speed, better vertical, and it has a great "whoosh" sound that is very reminiscent of a real jet (simultaneous with the usual annoying EDF "whine" sound). The Habu didn't make that "whoosh" sound with the same power system, so it must be something about the ducting on this plane. With all the changes I've made, I'm starting to like this plane now...
Flight times were a little disappointing though. The 3300 battery was almost sucked dry on a 3-minutes-and-50-seconds flight (I think this plane is draggier than the Habu). So I ordered some 3600 batteries to bump up the time a little. It should still work out OK for CG, since the HET fan/motor is heavier than the stock one (I had to move the 3300 about an inch forward of full aft to restore the CG). |
| Thread Tools | |
| Discussion New! $129 Nitro Planes Rc Landers 70MM F-16D EDF Jet With Retracts | FlyBoyTha1 | Foamy EDFs | 49 | Jun 20, 2009 04:58 PM |
| Discussion Starmax/Exceed RC/Topgun F18-C 70mm what Fan does it use? | Stuart B | Foamy EDFs | 0 | May 16, 2009 11:39 AM |
| New Product New!!! Exceed RC F-22 Raptor 70mm Ducted Fan RC Jet | nitroplanes | Nitro Planes | 9 | Apr 19, 2009 07:06 AM |
| Cool *** UPDATE *** New Version 2 70mm Exceed RC F/A-18C EDF Jet + NEW MOD VIDEO | nitroplanes | Nitro Planes | 2 | Mar 20, 2009 04:57 PM |
