Old Sep 17, 2012, 04:47 PM
United States, TX, El Paso
Joined May 2011
Originally Posted by fredmdbud View Post
Use contact foam adhesive like foam tac or uhu por. Or rubber cement. Something that doesn't get brittle over time.
This foam adhesive or rubber cement you speak of, will it allow easy removal of the plastic cover? I would like to remove the cover when necessary without pliers, hammer, saw and chiesel.
reno4sure is offline Find More Posts by reno4sure
Old Sep 17, 2012, 04:56 PM
fredmdbud's Avatar
USA, MD, Frederick
Joined Jan 2010
If your going to do that, might as well use micro screws. Or clips.
fredmdbud is offline Find More Posts by fredmdbud
Old Sep 17, 2012, 05:07 PM
Joined May 2011
I may try screws. I guess I would need to glue a plywood or similar strip to the fuse to screw the screws into. It just seems that I need to get into this area often.
Old Sep 17, 2012, 05:11 PM
advanced n00b
xfatdannx's Avatar
United States, NE, Omaha
Joined Feb 2012
Or again, canopy glue. Looks like elmars glue, dries clear, and is a more rubbery texture.
xfatdannx is offline Find More Posts by xfatdannx
Old Sep 17, 2012, 05:16 PM
Joined May 2011
May try that too. Less weight.
Old Sep 17, 2012, 05:58 PM
Never Trade Luck for Skill
MERLIN V16's Avatar
United States, FL, North Port
Joined Jan 2005
Well I hate to say i left my cover because I have a weight problem LOL. If i were to try to secure it again I would use the Loc-Tite no mess adhesive (or now called "Stick N Seal" )outdoor no mess water clean up. I know it is a mouth full but it works as a Canopy Glue,Servo setting glue. Glues plastic to foam and other crap. Try it and you just might like it.
MERLIN
MERLIN V16 is offline Find More Posts by MERLIN V16
Old Sep 17, 2012, 07:16 PM
advanced n00b
xfatdannx's Avatar
Joined Feb 2012
Anyone get their plane with retracts but doesn't use them? What i am looking for is the cable that was used for the pull-pull system. I want to use that for my gear doors. I used a rubber band the first time i set it up but when the wind catches it they flap open. I think my guitar string idea for the pull-pull will be fine but too think for the doors. Thanks in advance guys.
p.s. if you use guitar string for your pull-pull. Use the High - e string (.09 or .10 thickness)
Old Sep 17, 2012, 08:05 PM
Joined May 2011
Merlin, you need to put your plane on a diet! Ok, with all the glue ideas, can I easily remove the plastic cover with these suggested glues? I have been using a hot glue gun. That sh@$t sticks good when u don't want it to.
Xfatdannx. Is that your post about the string . Use fishing line. You can buy cable fishing line of various sizes. Including steel, braided line will work great.
Old Sep 17, 2012, 08:45 PM
MERLIN V16's Avatar
Joined Jan 2005
the glue I listed is like a silicon glue when it dries. You can peel off the cover or pry out a servo.
Old Sep 17, 2012, 09:31 PM
Joined May 2011
Thanks Merlin. What size are the servos on this plane? Are they 6g 7g 7.5g?
Old Sep 18, 2012, 06:06 AM
MERLIN V16's Avatar
Joined Jan 2005
I thought they were 9g. That is what I used for the Rudders.
Old Sep 18, 2012, 02:54 PM
advanced n00b
xfatdannx's Avatar
Joined Feb 2012
Crazy day at the field...1st attempt...Perfect, 100%, beautiful take off, flight, landing, you know, the works. 2nd attempt. pffft! Steers off course at full speed, hits the grass BOOM! all 3 retracts ripped out!!! Nothing broke, all three had the wood mounts rip from the foam/adhesive, easy fix (if i so choose to). Was about to pack up and leave after picking everything up and some guy i never met before showed up with a Habu, Stryker, and a tiny 4s powered T-28! (CRAZY fast!!!! he clocked it at 125 before!!!!) Anyway, i talked him in to hand launching for me and i flew one flight as a belly lander, 3rd attempt, perfect also! all in all good day. 2 battery packs and 2 successful flights...some minor damages to wings. But nothing that bad really. I will update with pics later if anyone wants to see em
Old Sep 18, 2012, 04:41 PM
Joined May 2011
Sorry about the mishap. Things can go crazy very quickly in our world. At least she is repairable. How did you like flying without the retracts? Was the e-flite 3200kv and fan an easy upgrade?
I couldn't help it. The devil made me do it. At least that is what I am telling my wife when the big brown box shows up tomorrow! I ordered a kit only version of this plane last week.
Reno
Old Sep 18, 2012, 05:01 PM
MERLIN V16's Avatar
Joined Jan 2005
Reno!
You are a Bad Boy!
Old Sep 18, 2012, 05:07 PM
Joined May 2011
Me when I get home tomorrow
My wife
I wish I had asked you about what we discussed in the PM today, last week. I better not make another order yet
Discussion New! $129 Nitro Planes Rc Landers 70MM F-16D EDF Jet With Retracts FlyBoyTha1 Foamy EDFs 49 Jun 20, 2009 04:58 PM
Discussion Starmax/Exceed RC/Topgun F18-C 70mm what Fan does it use? Stuart B Foamy EDFs 0 May 16, 2009 11:39 AM
New Product New!!! Exceed RC F-22 Raptor 70mm Ducted Fan RC Jet nitroplanes Nitro Planes 9 Apr 19, 2009 07:06 AM
Cool *** UPDATE *** New Version 2 70mm Exceed RC F/A-18C EDF Jet + NEW MOD VIDEO nitroplanes Nitro Planes 2 Mar 20, 2009 04:57 PM
