Aug 18, 2012, 08:45 AM
United States, NE, Omaha
Joined Feb 2012
im trying the guitar string idea. I am making a small loop through the horn hole and since the string is too thick to tie, i am using a tiny bead of epoxy to hold it shut. My dad said i could use solder for it but i already started and in the end, its the same idea. I will take a pic when its done.
update:
Seems to be working. a lot less slack here to my hand. I am taking it out for a taxi test in a bit. - **Complete**
i just wanted to take off but its a little windy today. I adjusted travel in the programming to keep from tipping during turns. Works great as long as i am not going fast. I wish i had a wheel brake mechanism. With time we will see. below is a close up of the A-string push rod. (left it full res so you can zoom in and get a closer look.)
