Old Aug 14, 2012, 10:25 PM
xfatdannx is offline
Find More Posts by xfatdannx
advanced n00b
xfatdannx's Avatar
United States, NE, Omaha
Joined Feb 2012
Is there a way to calculate thrust or do i need to have the plane attached to some kind og scale to get that measurement
xfatdannx is offline Find More Posts by xfatdannx
Old Aug 14, 2012, 10:34 PM
Ispintechno is offline
Find More Posts by Ispintechno
Defender of the park sky
Ispintechno's Avatar
London, ON Canada
Joined Nov 2009
Originally Posted by M3ATpl0w View Post
Here is a link to the known test results...
http://www.rcgroups.com/forums/showthread.php?t=1601868
I think Ispintechno is right about your esc...
Turnigy L2855 – 2800KV
4S 4000 40C
Vm 14.36
Ap 63.47
Wp 950.0
Thrust(Kg) 1.6
g/w: 1.67
Perhaps a 2300kv motor would be safe for the exceed ESC.
I think I saw a video on youtube with a de havilland vampire 70mm EDF on 4S 2300kv CS10 and it flew pretty darn well.
Seems to me 2300kv with a CS10 would be comparable to a 2800kv 5 blade rotor like our stock set-ups. Be around the same amps/watts/efflux speed but get the sound your after.
Ispintechno is offline Find More Posts by Ispintechno
Old Aug 14, 2012, 10:41 PM
London, ON Canada
Joined Nov 2009
I've only seen video on scales, like the scale on it's side with the nose of the airplane against it. However that way would probably lose some thrust to friction due to the landing gear.
Maybe scoop out some Styrofoam with a nose shape indent, scale on the ground, jet straight up and down nose first on the scale in the styrofoam (to not compress or damage nose tip), tear scale to zero and throttle up!
Old Aug 15, 2012, 07:20 AM
advanced n00b
xfatdannx's Avatar
Joined Feb 2012
i remember someone asking about using the rudder as a kind of air brake...never even thought it was a real thing just something they wanted to try...check this out..
They really do that...
Old Aug 15, 2012, 08:52 AM
carlcorn is offline
Find More Posts by carlcorn
Joined Apr 2009
Originally Posted by Ispintechno View Post
I think you're going to need a new ESC for that motor and fan, the stock exceed ESC is only 50amps I think. I'm in the same boat, going to try a 2800kv motor with the CS fan. The stock motor and fan pulls around 41 amps as is, with a CS10 load at around the same KV I suspect it might surpass 60amps on high timing.
The only way to know for sure I guess is the ole' bench test with a watt meter, but I imagine CS10 and 2800kv on 4S will cook the exceed ESC.
I'm going to try a Turnigy plush 60amp ESC, if it's over taxed I`ll grab a 80 amp one eventially. For a few bucks they come with a programming card that is super easy to change the settings without fiddling with transmitter, from ESC timing to what kind of song the airplane starts up with when you plug in the battery lol
Thanks to those that responded. I have a Turnigy 80 amp ESC still in the wrapper waiting for another plane. I'll give that a try and see what happens. Maybe someone in my club has a programming card I can use to check and set the timing on this ESC. That way I won't have to wait for an order from HK.
Also. On the subject of testing. I tested the stock fan against the CS10 with Turnigy 2800kv motor by setting the plane on the bench with the noise pointing at a small scale against the waill. This seemed to produce some reasonable numbers for comparing the two. I expected a small to moderate increase with the new setup but the difference was very small. I don't think the limiting factor was the battery so I'm thinking ESC or ESC timing. Since the ESC did not heat up noticably I'm leaning toward timing.
carlcorn is offline Find More Posts by carlcorn
Old Aug 15, 2012, 03:31 PM
advanced n00b
xfatdannx's Avatar
Joined Feb 2012
ok so i got almost everything done on my plane...a few small things that i was at least able to set on the plane while on the scale. Came out to 1451g. What do you guys think? Running on Bl15 3200kv w/ eflite dv fan on 4s 3300mah 35c. Think i should do okay? Kinda scared of the weight, i didn't put any ordinances or gear door. I think it will be ready to maiden this weekend if weather cooperates.
p.s. 80 amp esc so i don't THINK that will be an issue...i could be wrong though!
Old Aug 15, 2012, 05:49 PM
MERLIN V16 is offline
Find More Posts by MERLIN V16
Never Trade Luck for Skill
MERLIN V16's Avatar
United States, FL, North Port
Joined Jan 2005
If the CG is right Fly it!
MERLIN V16 is offline Find More Posts by MERLIN V16
Old Aug 15, 2012, 07:33 PM
London, ON Canada
Joined Nov 2009
Heck ya! And vid or it didn't happen!
Old Aug 15, 2012, 08:32 PM
AirChime is offline
Find More Posts by AirChime
AirChime's Avatar
Joined Jul 2009
What battery did you use (mah and C rating) for your test and what was your voltage sag at? How many amps did it pull? I've got this combo on order and from what I've read the 4S setup demands a lot of power and I'm not exactly sure what C rating and mah size battery will be needed to not eat up batteries.
AirChime is offline Find More Posts by AirChime
Old Aug 16, 2012, 01:15 AM
advanced n00b
xfatdannx's Avatar
Joined Feb 2012
It might not "happen" then haha. I don't have a decent camera. I will see if i can borrow my moms flip. hoping i can have someone there to film or at the least photograph.
Old Aug 16, 2012, 08:18 AM
carlcorn is offline
Joined Apr 2009
Unfortunately I don't have a proper meeter to measure amps or voltage. Something I will be ordering soon. I tried with a 4S 2200mAh 30C and it seemed to run OK. I also tried with a 4S 3000mAh 30C and it ran essentiall the same (same sound and thrust). That is why I want to try a different timing setting on the ESC. It will be a week or more before I can try again. I may order a proper watt meeter and ESC programmer to see if I can get more from this setup. This seems to be what I'll need to work with power systems like this. From what others are saying this fan/motor combo may work well on 5 or 6 cell packs. Unfortunately I don't have that option at the moment.
Old Aug 16, 2012, 10:29 AM
MERLIN V16's Avatar
Joined Jan 2005
I will have Numbers for the Stock setup using a 3300 40C 4S with an Eagle tree Data logger as soon as my friend sends them. Turns out it is faster than my Micro Corsair.
MERLIN
Old Aug 16, 2012, 03:26 PM
MERLIN V16's Avatar
Joined Jan 2005
Eagle Tree Data
Totally stock Plane with a 4S 40C 4S. Fixed gear hanging in the breeze.
MERLIN
Old Aug 16, 2012, 04:26 PM
reno4sure is offline
Find More Posts by reno4sure
No worries, I've got your six
reno4sure's Avatar
Joined May 2011
Merlin,
Thanks for posting. I purchased this jet a couple of weeks ago and it is resting nicely just waiting for it's maiden. I also have stock set up as I wanted to see how it flys before replacing items and I have plenty of the same batteries on hand that you used. Those numbers seem fine to me. But I'm a prop warbird pilot just getting introduced to jets. So what do I know? As I don't have an asphalt runway near by I will be hand launching on a great grass field. Hope it goes well Any one with help on how to hand launch this bird will be appreciated. Is it similar to launch as the PZ-51 etc.
reno4sure is offline Find More Posts by reno4sure
Old Aug 16, 2012, 04:38 PM
M3ATpl0w is offline
Find More Posts by M3ATpl0w
Progress with the process...
M3ATpl0w's Avatar
NE Alabama
Joined Feb 2011
MERLIN
I think with some thrust tubes you could pick that # up quite a bit. After discussing this briefly with 3rd-dem back a few pages, I broke my kit out and carefully measured my exhaust. Both are quite elliptical and together add up to 101% FSA. Had to delay my build a few weeks, so Im having to get my jetfix via videos and these forums.
M3ATpl0w is offline Find More Posts by M3ATpl0w
Discussion New! $129 Nitro Planes Rc Landers 70MM F-16D EDF Jet With Retracts FlyBoyTha1 Foamy EDFs 49 Jun 20, 2009 04:58 PM
Discussion Starmax/Exceed RC/Topgun F18-C 70mm what Fan does it use? Stuart B Foamy EDFs 0 May 16, 2009 11:39 AM
New Product New!!! Exceed RC F-22 Raptor 70mm Ducted Fan RC Jet nitroplanes Nitro Planes 9 Apr 19, 2009 07:06 AM
Cool *** UPDATE *** New Version 2 70mm Exceed RC F/A-18C EDF Jet + NEW MOD VIDEO nitroplanes Nitro Planes 2 Mar 20, 2009 04:57 PM
