Old Aug 02, 2012, 11:00 PM
Blasturbator is offline
Find More Posts by Blasturbator
Blasturbator's Avatar
United States, FL, Sarasota
Joined May 2011
will a 3000mah mess with the cg alot? (stock)
Blasturbator is offline Find More Posts by Blasturbator
Old Aug 03, 2012, 04:36 AM
3rd-dem is offline
Find More Posts by 3rd-dem
United States, FL, Orange Park
Joined Jul 2010
Originally Posted by M3ATpl0w View Post
Ever put a watt meter on it?
I will this weekend and post results. I use a 3000mah 4s and a 450mah for the bec with no trouble!
3rd-dem is offline Find More Posts by 3rd-dem
Old Aug 03, 2012, 05:57 AM
MERLIN V16 is offline
Find More Posts by MERLIN V16
Never Trade Luck for Skill
MERLIN V16's Avatar
United States, FL, North Port
Joined Jan 2005
I'm using a 3300 4S 40C. There is room to move the battery forward (or in my case) back to the CG where you want it.
MERLIN V16 is offline Find More Posts by MERLIN V16
Old Aug 03, 2012, 07:01 AM
xfatdannx is offline
Find More Posts by xfatdannx
advanced n00b
xfatdannx's Avatar
United States, NE, Omaha
Joined Feb 2012
did you have to do some cutting to make it fit or is the battery space large enough already?
xfatdannx is offline Find More Posts by xfatdannx
Old Aug 03, 2012, 07:15 AM
MERLIN V16's Avatar
Joined Jan 2005
Very very slight trim of the foam in the battery bay. Just the rib parts that stick out 2/3 rds of the way forward otherwise plenty of height and withe. It sits low enough that the canopy/Batt hatch needs no work.
I still only get a little over 4 Min.s to land at 50% though.
MERLIN
Old Aug 03, 2012, 07:32 AM
advanced n00b
xfatdannx's Avatar
Joined Feb 2012
im more worried about the amp draw that i am gonna have...the battery i bought to run my static tests i think is gonna be too small so hopefully i can sell it on here for close to what i got it for, i mean i have only run the motor up twice on it.
Old Aug 03, 2012, 06:19 PM
Joined May 2011
OK so i have a quiestion for the power pros do you think this system will work?
ChangeSun 70mm 10 Blade EDF (Balanced)
Turnigy 2800kv Brushless Outrunner
Turnigy Trust 70a ESC
Old Aug 03, 2012, 06:31 PM
3rd-dem is offline
Joined Jul 2010
Looks doable, are you thinking 4s or 5s? I would probably go for a higher amp esc though, here's a link to just about every combo that's been tried;
' http://www.rcgroups.com/forums/showthread.php?t=1521248
Old Aug 03, 2012, 06:34 PM
Joined May 2011
planning to run in 4S
Old Aug 03, 2012, 06:35 PM
fredmdbud is online now
Find More Posts by fredmdbud
fredmdbud's Avatar
USA, MD, Frederick
Joined Jan 2010
What's the rated power of the motor? Is the motor the HK2839 EDF Outrunner 2800kv for 70mm? That particular one is rated at 550W, 36A. Might get hot from the current draw required for a 10-bladed fan.
I installed a Cyclone Power 3700kV motor, rated at 1000+ watts, and the armature extends beyond the inner housing so it gets cooled in the airflow.
You don't want to run a motor above its power rating - it might cause the windings to heat up and fail, and/or demagnetize the magnets.
fredmdbud is online now Find More Posts by fredmdbud
Old Aug 03, 2012, 06:55 PM
Joined May 2011
i believe its the L2855-2800Kv, on that forum link above it says it pulls around 60amps
Old Aug 03, 2012, 07:35 PM
3rd-dem is offline
Joined Jul 2010
you are correct! seems you'd be fine!
Old Aug 03, 2012, 07:44 PM
Joined May 2011
Awesome! thanks 4S 3000mah should be enough for it?
Old Aug 03, 2012, 07:59 PM
fredmdbud's Avatar
USA, MD, Frederick
Joined Jan 2010
Turnigy L2855-2800 EDF Outrunner (630w)
Spec.
Kv: 2800 rpm/v
Voltage: 14.8(4s)
No load Current: 2.8A
Max Current: 43A
Max Power: 630W
Shaft Size : 4mm
Shaft Length: 16mm
Dimension: 34mm x 28mm
Thrust: 1200g
Weight: 97g
Here's a datapoint from another thread:
" Change Sun 70mm 10 Blade EDF with an installed Eflite BL15 3200kv motor ... It pulled a 50.1a draw at 782 watts without the intake ring for a 2sec burst full throttle on a nanotech 4s 3300mah 30-70c pack. I tested it on my eflite meter."
And another guy was selling a similar setup as yours, probably measured with a 5S: http://www.rcgroups.com/forums/showp...30&postcount=5
"1000 watts+ depending on lipo... "
4S will get your less amps and power, but the trade-off is less thrust. 2800kV motors are usually run off 5S.
Old Aug 03, 2012, 08:19 PM
3rd-dem is offline
Joined Jul 2010
I believe a 2800kv is a good 5s motor for most any fan other than the CS! From what I understand the blade count of the CS (10) requires stronger/lower kv motors to be efficient. I have test flown mine (Het 2W-25 2720kv) on 4s and it's a "pleasure".
Discussion New! $129 Nitro Planes Rc Landers 70MM F-16D EDF Jet With Retracts FlyBoyTha1 Foamy EDFs 49 Jun 20, 2009 04:58 PM
Discussion Starmax/Exceed RC/Topgun F18-C 70mm what Fan does it use? Stuart B Foamy EDFs 0 May 16, 2009 11:39 AM
New Product New!!! Exceed RC F-22 Raptor 70mm Ducted Fan RC Jet nitroplanes Nitro Planes 9 Apr 19, 2009 07:06 AM
Cool *** UPDATE *** New Version 2 70mm Exceed RC F/A-18C EDF Jet + NEW MOD VIDEO nitroplanes Nitro Planes 2 Mar 20, 2009 04:57 PM
