Old Nov 18, 2010, 11:28 AM
Chuck 'Em and Chase 'Em
Fly2High's Avatar
Long Island, NY
Joined Aug 2005
Harbor Freight workbench - how bad is it?
guys,
Anyone have any experience withthis bench?
http://www.harborfreight.com/60-inch...nch-93454.html
Can it be used for building or if it cannot as is, what needs to eb done to it to make it useable (besides throwing it away and gettting a real bench !)
any input pros/ cons would be appreciated.
thanks
Frank
Fly2High is offline Find More Posts by Fly2High
Old Nov 18, 2010, 12:53 PM
Joined Jul 2006
Originally Posted by Fly2High View Post
guys,
thanks
Frank
Hi Frank,
It's hard to tell from just a picture whether it would work in your application or not. Most important is a true, flat, top that will resist warping. As for strength of the piece, it can always be fortified to make it stronger.
NoFlyZone is offline Find More Posts by NoFlyZone
Reply With Quote  (Disabled)
Old Nov 18, 2010, 03:05 PM
USA, GA, Carrollton
It will be a good woodbench, but you won't be able to stick pins in it. They say it weighs 121 lbs so it should be plenty stable.
TFM70 is offline Find More Posts by TFM70
Old Nov 18, 2010, 03:06 PM
B for Bruce
BMatthews's Avatar
The 'Wack, BC, Canada
Joined Oct 2002
It's too small a top surface for building anything but the smallest of models and too small, flimsy and light to serve well as a proper heavy wood working bench. Look at the top size. It's only 60 x 20 inches.
If you wanted this as a "work island" to complement a kitchen counter style wall bench for model building then fine. But as it sits now I'd suggest that it's too small a work top.
If you have nothing at all at the moment I'd suggest you go around to a supplier of used construction materials. They all have collections of old kitchen cabinets and counters. Make a deal on a few cabinet lower drawer units and a few uppers depending on what your shop area can use. Get a damaged "second" of pre finished counter top. When you install the cabinet lowers pay particular attention to shimming them all up to level and matching. Leave a 30 inch leg well so you can sit at the bench at one spot. This will all fit against a wall and serve well since it'll be a much more useable size and provides far more storage. Upper cupboard units provide more storage and a place to mount the bench working lights and valence to avoid blinding yourself.
A setup such as that would run you about double or perhaps triple the cost of that HF bench but it would be a Cadalac solution that would last you for years instead of a Yogo used bucket of bolts solution that you'll outgrow or find inadequite within weeks.
I know you didn't want an alternate but really the size of this thing makes it more a "scale model" of what a real proper wood working bench truly is. And as for a model building bench it's a disaster that can't be modified to be even passingly adequite unless you only build a few extra small models a year or perhaps if it would be an island workplace addon to an existing shop.
BMatthews is offline Find More Posts by BMatthews
Old Nov 18, 2010, 03:22 PM
Marion
USA, NC, Hillsborough
Joined Oct 2003
I use an old drafting table -- from the days before computers were king. Flat, stable, big enough -- and inexpensive.
I agree with Bruce, the HF one is too small.
Good luck
Marion is offline Find More Posts by Marion
Old Nov 18, 2010, 10:55 PM
Buran's Avatar
Huntington Beach
Joined Aug 2000
Try starting with a solid core door.
Buran is offline Find More Posts by Buran
Old Nov 19, 2010, 01:12 AM
USA, CA, Selma
Joined Sep 2004
Fly2High:
Have you seen the Harbor Freight bench in person, I've seen them in the store, the top looks solid but it is only about 3/4"thick with a 3/4" thick border. The bench is made of some type of wood that looks relatively soft. I don't know how long it would stay true. The term "hardwood" can be a little bit misleading, Keep in mind that Balsa is botanically a hardwood! Personally, after seeing one, I would pass on that one.
I agree with Buran, a solid core door is the way to go. Sturdy, stable, flat, and heavy. You can put it on a two by four framework or do like BMathews said and use cabinet modules for a base. Just make sure the base is shimmed so that the door is not stressed or it will eventually warp. Make sure the door is flat to start with. Used doors from a re-model can be had for next to nothing or even free.
I found my two doors when they were left out on the street for the annual city "Big trash day" pickup.
Now if you are really serious about a true stable building surface......
I heard Eugene Verbitsky, (A gentleman who has been flying for the former Soviet Union and now Ukrainian FAI free flight teams since the sixties) explaining how he built such true, warp free wings. Seems he sometimes uses a large machinists "proofing" table. Something like a six foot long very thick granite block with a surface finished flat to within "Zillionths" of an inch.
John
Oian is offline Find More Posts by Oian
Old Nov 19, 2010, 09:29 PM
Aurora Municipal, Illinois, United States
Joined Jul 2002
I'd pass on this one too. For some reason my father felt compelled to buy one. It looks nice but as the others said it's not really a hardwood bench and wouldn't stand up to the abuse that oak would.
I used to have a piece of slate from an old pool table. Works really well. Had to get rid of it because it was too expensive to move. I bought myself a 72" Gorilla workbench and replaced the 3/8" particle board top with a 2" Formica covered particle board top. Very heavy and very stable. I glued ceiling tiles that are smooth on both sides with spray adhesive. I think the style was called Stonebridge. I want to replace them but can't seem to find them around here. I really want to try magnets so I may strip the tiles off and glue a piece of sheet steel to the top of my bench with contact adhesive. IIRC I paid less for the Gorilla bench than my father paid for the HF bench. That was about 10 years ago though.
bullseye000 is offline Find More Posts by bullseye000
Old Nov 19, 2010, 11:16 PM
Foam Av8r
RogueTitan's Avatar
In Teh Garage (Rossville, GA. USA)
Joined Sep 2008
guys,
Anyone have any experience with this bench?
thanks
Frank
IT IS A REAL BENCH!!
I have had this bench for a few years now (got it on sale for 139.95) and I love mine! It is very high quality work bench made from white oak heavy and stable and nothing flimsy about it as other posters who have commented that apparently don't own one otherwise they would know how heavy duty it is actually is.
Grizzly has the exact same bench at double the price.
I use it as is to build from except I have a piece of 10 Ga metal I use as a magnetic building board sitting on top but ya it can be used as is for building R/C airplanes or guitars
I am building 5' and 6' wing span planes on this bench.
RogueTitan is offline Find More Posts by RogueTitan
Old Nov 20, 2010, 05:05 AM
Will fly for food
Maryland
Joined Sep 2004
I have one of them and it works OK. Yes, it is small, but I don't build large models.
The big complaint I have is, it is fairly low (as work working benches typically are) so I have a couple of pieces of 4x4 under the legs to raise it up. The drawers don't open as far as they should.
But, I got mine on sale, and for the money, it was a quick bench to put into use.
Pinecone is offline Find More Posts by Pinecone
Old Nov 20, 2010, 09:53 AM
United States, NC, Charlotte
Joined Aug 2006
Few things to consider:
-How much room do you have for your bench in the room. (width, depth)
-How many tools/equipment do you have/use/need to have on or near the bench and a means to keep them out of the way and organized (easy to find at need).
-Are you able to expand the work area around it. (pegboard on the wall, place to stage parts/items as u build or glued parts setting up, storage of materials like foam sheets, etc)
-Size of your items being built.
Finally, will it meet your needs now and going forward, how much money do you want to put into it and/or are you willing to put time into construction. Having something that is Heavy, Solid and Hugh, is nice but for RC craft builds... is not really required.
Using a solid door is an great idea, can also go with one of those folding tables from an office supply store (come in diff sizes).
Sandray is offline Find More Posts by Sandray
Old Nov 20, 2010, 09:58 AM
Foam Av8r
RogueTitan's Avatar
Joined Sep 2008
Pinecone
I agree the drawers need to come out farther
however the height is just right for me since I sit down when I am building.
Old Nov 20, 2010, 10:31 AM
United States, PA, Telford
Joined Jun 2006
I got an old metal desk at a garage sale for about $10.00.(the same kind they used to have in some schools for the teachers) I put it up on large cinder blocks to get the height I wanted, then put on a solid wood door with ceiling tiles on top. The nice thing about the desk is it has drawers for storage and adjustable metal feet for leveling.If you have room you may want to consider a Island style bench that you can walk around. I am considering this because I tend to build bigger kits(60-120size) and maybe scratch build some day.
dderst is offline Find More Posts by dderst
Old Nov 20, 2010, 10:49 AM
LesUyeda's Avatar
San Diego, California
Joined Dec 2004
Marion. Do you still have the parallel rule off of that drafting table. I do mine. Somewhere!!!!!:-))))))))
Les
LesUyeda is offline Find More Posts by LesUyeda
Old Nov 20, 2010, 12:10 PM
Joined Mar 2006
Looks good to me for the price.
I payed alot more for benches.
http://www.advancedmachinery.com/pro...bench-1151.cfm
I got one for $400 years ago.
You find these on sale.
scrape is offline Find More Posts by scrape
FF conversion - Harbor Freight jeffs555 Parkflyers 5 Jun 09, 2008 10:31 PM
Discussion Catalina's over Dutch Harbor/How bad is salt water? mokimakana Waterplanes 14 Mar 26, 2008 08:46 AM
Sky Runner from Harbor Freight Greg Covey Indoor and Micro Models 69 Feb 18, 2003 10:25 AM
CNC setup for mini mill from harbor freight stealthy Life, The Universe, and Politics 0 Jan 21, 2002 02:32 AM
Harbor Freight F/F E-planes: Thomas B Indoor and Micro Models 7 Jan 13, 2002 09:24 PM
