United States, CA, Ukiah
Joined Jan 2011
Here:
http://www.cxndesigns.com/radiancameramounts.html Though it is not that hard to make your own. I found that pitching the motor up (towards the nose) about 12 degrees minimizes nose-down effect. |
Tuck can also be caused by improper decalage where the horizontal stabilizer acts like down trim on the elevator. This requires adjusting the horizontal stabilizer to be parralel with the bottom of the wing. High speed passes are beyond the normal expected speed range of a thermaling glider. Setting up for speed without tucks will dimminish the ability of the glider to visually indicate entering and exitng lift conditions. The choice is yours. Dave F >< *> |
Canada, BC, Smithers
Joined Nov 2011
Also, the elevator is a little wimpy at high speeds due to fuselage flex and due to the narrow waist between the two halves of the elevator. There are fixes for those as well. You don't have to give up any thermal performance or add any weight to make this plane fly a lot better. If you are doing anything other than gentle soaring, the CF wing spar is a must. |
this is with a solid carbon fibre rod and small stiffening rods at the back too |
Joined Nov 2011
Where is your CG located? What happens if you do a standard "dive test"? Put it in a 45 degree dive and then release the sticks. Does it come out of the dive by itself or does it tuck?
OOps forgot to mention...before you do the dive test the elevator has to be trimmed to fly hands free without porpoising. |
CoG is where its set from the box. |
Joined Nov 2011
One more question...now that you have it trimmed to fly hands free...is there any elevator trim required? Up, down, or neutral. |
Yeah, sounds like it's tail heavy.
CG figure quoted in the manual is just a guide to me. Start from there and adjust according to flight tests
Latest blog entry: Maybe my fleet is too big...
the thing is...the other day i checked the decalage setting....and it looks correct to me, as in its neutral. i also added some weight on the tail for the CoG as per radiocarbonart sugests.....it flew great until it slowed down then stalled all the time. i reduced the weight and kept trying it out.
its only happy at box setting, but that just tucks when i wanna go from thermal to thermal. |
Thanks much.
| Thread Tools | |
| Rave New Parkzone Radian Pro-discussion thread!!! | lightspeeddud | Electric Sailplanes | 3620 | May 13, 2013 04:23 PM |
| Discussion Official Radian Pro Thread | Magnumb | Parkflyers | 14 | Apr 10, 2011 10:56 PM |
| Gallery Parkzone Radian Pro Video | bakon | Electric Sailplanes | 6 | Mar 11, 2011 05:21 PM |
| New Product Parkzone Radian Pro | bakon | Electric Plane Talk | 24 | Oct 01, 2010 01:39 AM |
| Discussion Parkzone Radian Pro $229.99 BnF preorder | Tekwip | Hot Online Deals | 10 | Sep 29, 2010 04:35 PM |
