Old Feb 09, 2013, 10:49 AM
ncflyer79 is online now
Find More Posts by ncflyer79
ncflyer79's Avatar
United States, NC, Marion
Joined Jun 2011
Guys I made a few more changes to my setup on the ailerons and they now feel like they have better response. I am loving this glider more and more each time I fly it. Such a nice change of pace from my warbirds.
ncflyer79 is online now Find More Posts by ncflyer79
Old Feb 09, 2013, 04:24 PM
coreman is offline
Find More Posts by coreman
Kit Manufacturer
coreman's Avatar
United States, MA, Southbridge
Joined Feb 2010
and that is the whole point. Just to relax and enjoy things for a little bit. Challenge yourself to find the invisible lift in the river of air and stretch your times longer and longer
coreman is offline Find More Posts by coreman
Old Feb 09, 2013, 05:37 PM
rcfisherman is offline
Find More Posts by rcfisherman
Joined Nov 2012
It might seem like a paradox at 1st glance but I find that flying my radian pro to is a lot more challenging and less relaxing than sport flying my warbirds.
With the warbirds, I just fly around doing whatever I want at a comfortable altitude and distance. When I fly the radian pro, I'm constantly searching for signs of lift and when I do find it, I try very hard to stay in the lift and fly as smooth as possible. This sometimes occurs at great heights and distances so my eyes are constantly straining (far distances and concentrating to see what the plane and the environment is doing) and my neck gets stiff. After a 5min warbird flight I feel fine. After a 1hr radian pro flight I need to stretch and unwind!
The good thing about stiffing up the wings and increasing the roll rate is when you want to relax and sport/slow fly it and of course when you want to slope fly. I also enjoy this hobby by modding and customizing the "one size fits all" aspect of any mass produced product.
rcfisherman is offline Find More Posts by rcfisherman
Old Feb 09, 2013, 09:14 PM
Watdazit is offline
Find More Posts by Watdazit
A geriatric flier
Watdazit's Avatar
Australia, NSW, Braidwood
Joined Nov 2008
Originally Posted by tlar633 View Post
.............But for the life of me I cannot understand why someone would buy what is marketed and designed as a sailplane and then complain because its too slow and does not fly 3D ! The idea behind motorized sailplanes is to use the motor to get you up then shut the motor off and try to find thermals, which both versions of the Radian does.
I agree also. The only performance modifications which I would consider carrying out are motor, prop and battery, all with the express reason to get higher quicker in club gliding comps.
Someone was asking about increasing aileron throw. I have to agree the ailerons are a bit "weak". I do mix in some rudder and I increased my end points but the difference on the latter was hardly noticeable. Freeing up te hinge by cutting small sections out made some difference as I noted the outer section of the aileron was not moving as much as the section closer to the horn. I also believe some people have taped the aileron to make it more rigid.
Watdazit is offline Find More Posts by Watdazit
Old Feb 10, 2013, 11:35 AM
Gtdunham is offline
Find More Posts by Gtdunham
Joined Feb 2013
Hi All. Have just bought a RP as a novice I must say I am very impressed. On my last landing i caught a wing and the glider span gently on the grass strip. The result is that the plastic securing lug for the wing has broken. Does any one know where you can buy this plastic fuselage insert ( without buying a complete new fus). I have searched the web without success. Many thanks.
Gtdunham is offline Find More Posts by Gtdunham
Old Feb 10, 2013, 11:45 AM
Jovanx is offline
Find More Posts by Jovanx
Tossing planes into the snow
Canada, BC, Smithers
Joined Nov 2011
Yes this is one of the weak spots on the plane. When it happened to me, I glued it back together with JBWeld. After the glue was hardened, I added a piece of bubble pack plastic as a "scab" to make it stronger. I roughened up the surfaces before gluing the scab on. It has stayed together and even with a few rough landings, it's still good.
Jovanx is offline Find More Posts by Jovanx
Old Feb 10, 2013, 05:32 PM
tlar633 is offline
Find More Posts by tlar633
Joined Aug 2010
Someone was asking about increasing aileron throw. I have to agree the ailerons are a bit "weak". I do mix in some rudder and I increased my end points but the difference on the latter was hardly noticeable. Freeing up te hinge by cutting small sections out made some difference as I noted the outer section of the aileron was not moving as much as the section closer to the horn. I also believe some people have taped the aileron to make it more rigid.[/QUOTE]
Perhaps a small carbon (tow?) the length of the flap and aileron. As far as roll rate I just for what ifs I am going to make the flap/ aileron pair work as flapperons
In reality with the rudder mix the plane turns about right (coordination wise) for thermal flying. There really isn't a need for much more bank
tlar633 is offline Find More Posts by tlar633
Old Feb 10, 2013, 05:54 PM
coreman is offline
Kit Manufacturer
coreman's Avatar
Joined Feb 2010
if you bank too much the wing spills lift. You could put it on a switch to boost the throw when you want to crank a roll out. or even just the dual rates
A buddy recently sent me a video of a guy in Florida doing a demo of a V-Tail powered glider. He was flying it like an aerobatic power plane and to be honest, I wouldn't buy it as a glider based on the video. And I wouldn't buy it as an aerobatic power plane either as it didn't have the roll rate for it. It was probably doing a roll every 2-3 seconds. To each their own. Each plane does specific things and you need to know what you are looking to do with them before evaluating what to buy.
Old Feb 10, 2013, 08:22 PM
davovinch is offline
Find More Posts by davovinch
United States, PA, Meadville
Joined Feb 2011
This is a very important discussion for new glider pilots and I thank all the contributors for the valuable info you have provided re: preset fail safe
It's important to not give up when trying to locate a lost plane, i know that's obvious but what I mean is a lot of people don't bother with Craigslist or even the local paper but if you print up a bunch of flyers and distribute them to peoples homesyou just might be amazed. People do talk to others still and a simple flyer has been my salvation more than once. One time I had no sooner parked the car and took a seat when the phone rang and this was after beating the brush for three days. It turned out I never would have found the plane b/c the finder had put it inside for safety, LOL
davovinch is offline Find More Posts by davovinch
Old Feb 10, 2013, 10:37 PM
coreman is offline
Kit Manufacturer
coreman's Avatar
Joined Feb 2010
Here's the video. Glider?
Old Feb 11, 2013, 03:10 AM
socommk23 is offline
Find More Posts by socommk23
always looking for clouds
socommk23's Avatar
Joined Aug 2010
spoke to a guy at my local club a while ago.
he lost his ultra jet 4 weeks prior, pointed it the direction and said he had given up after having several people help him for 2 to 3 hours.
as i headed home i stopped at the "crash site" to have a quick look.
10 mins later i found it.
i took it back to him, as far as he was concerned it was mine as he had given up on it so long ago.
so im up one more plane. well i was till my brother took it out without me and crashed it!
socommk23 is offline Find More Posts by socommk23
Old Feb 11, 2013, 11:09 AM
got-one is online now
Find More Posts by got-one
On Short Final for 36
got-one's Avatar
USA, MI, Rochester
Joined Nov 2008
Exactly..Glider?? I'm seeing little to no gliding or soaring. This video is what I'd call sport/aerobatics flying. Are'nt real gliders supposed to be catcihng thermals, climbing out of sight, and landing on a spot?
Dave F
got-one is online now Find More Posts by got-one
Old Feb 11, 2013, 12:23 PM
coreman is offline
Kit Manufacturer
coreman's Avatar
Joined Feb 2010
Dave F
or at the very least flying unpowered for more than 10-15 seconds
Old Feb 11, 2013, 02:19 PM
turboparker is online now
Find More Posts by turboparker
Gopher huntin' stick jockey
turboparker's Avatar
Joined Jul 2009
Looked more 'fast sport plane with a good glide-ratio' than 'high-performance powered sailplane'.
Hey, it's a hobby. Fly a TD glider like it's a pylon-racer, fly a Cub like it's a 3D ship, fly a warbird like it's a sport-plane. If that's what floats your boat - go for it - regardless of how goofy it may appear to experienced modelers. I never have been able to understand why people do that, given the nearly endless choices of aircraft which are actually designed for the purpose. Oh, well. A guy's gotta have time for a snack & a nature-break at the club field at some point. I'll take my break during those flights, since there won't be anything of interest to watch anyway.
Joel
turboparker is online now Find More Posts by turboparker
Old Feb 12, 2013, 03:50 AM
Patchitagain is online now
Find More Posts by Patchitagain
NE Texas, USA
Joined Jan 2011
@Gtdunham
That happened to me also. Instead of buying a wing set, I used some rare earth magnets I had handy to hold the wings on.. I drilled holes in the plastic portion of the fuse and CA'd the magnets in place, then CA'd a washer in the wing.. Works great and the wing has never come loose during flight and requires a bit of 'pull' to get them to part..
Paul
Patchitagain is online now Find More Posts by Patchitagain
Rave New Parkzone Radian Pro-discussion thread!!! lightspeeddud Electric Sailplanes 3813 Yesterday 07:52 AM
Gallery Parkzone Radian Pro Video bakon Electric Sailplanes 9 Sep 30, 2015 04:20 PM
Discussion Official Radian Pro Thread Magnumb Parkflyers 15 Aug 16, 2015 06:12 PM
New Product Parkzone Radian Pro bakon Electric Plane Talk 24 Oct 01, 2010 01:39 AM
Discussion Parkzone Radian Pro $229.99 BnF preorder Tekwip Hot Online Deals 10 Sep 29, 2010 04:35 PM
