Old Jan 22, 2013, 02:43 PM
ktuluz is offline
Find More Posts by ktuluz
Joined Jan 2013
Originally Posted by kaptondave View Post
Just my opinion: yes the GoPros are amazing camers - for the intended purpose which is up close video of personal action sports, but they are a poor choice for AP. The FOV is much too wide, producing images with too little detail of distant objects. Moreover the attendant spherical distortion that caused curved horizons is annoying.
I know I will get a lot of push-back on this but again, just my opinion as a long-time photographer.
I would have to agree, and this coming from a heavy go pro user, I have comes to realize the go pro is not going to capture the picture quality I want from AP, and am now looking at carrying my micro 4/3 under my quad. But for the radian I still think the go pro gives me a good feel for the flight, and will continue to use as a fpv camera or for those quick flight videos. For AP if you are serious u use a multi rotor anyways.
ktuluz is offline Find More Posts by ktuluz
Old Jan 22, 2013, 02:49 PM
turboparker is offline
Find More Posts by turboparker
Gopher huntin' stick jockey
turboparker's Avatar
Joined Jul 2009
Dave,
I also agree. GoPros are excellent for their intended purposes, but I prefer a non-distorted image for on-board RC video, and I prefer a much narrower FOV when shooting from the ground with my hatcam. I'm also looking for a camera/lens combo that captures a 1:1 image so that distance & speed are not distorted when flying FPV. Is that practical?
Joel
turboparker is offline Find More Posts by turboparker
Old Jan 22, 2013, 04:24 PM
Jovanx is offline
Find More Posts by Jovanx
Tossing planes into the snow
Canada, BC, Smithers
Joined Nov 2011
I think that any time you take a picture through a circular lens, the distance/pixel relationship will be different in the center than at the edges. Even high-end airphotos have to be digitally "warped" before they can be used by surveyors and planners.
I don't have a GoPro, but I know there are programs out there that can resample the images to remove the fisheye effect. Some of them are specifically designed for GoPro videos. Something like that could be used, in theory, to warp the videos that your FPV system was broadcasting to you, but I'm not sure we have the processing power yet to do that in real time.
Jovanx is offline Find More Posts by Jovanx
Old Jan 22, 2013, 05:39 PM
socommk23 is offline
Find More Posts by socommk23
always looking for clouds
socommk23's Avatar
Joined Aug 2010
Dave,
Joel
just so you guys know....
you can change the FOV on the go pro cameras down to 90 degrees
socommk23 is offline Find More Posts by socommk23
Old Jan 22, 2013, 05:44 PM
socommk23's Avatar
Joined Aug 2010
flew my RP yesterday for the first time.
loooooooove it!
so smooth!
so floaty
flaps work a treat!
so now it has the 8ch in it and has the lizarmans setup with my own flight mode tweeks. ready for tomorow after work. fingers crossed the weather holds out.
then im going to mount my gopro onboard and get some footage.
then ill be getting some fpv gear too.
woop woop.
so exited. (is that sad?)
Old Jan 22, 2013, 06:07 PM
kaptondave is offline
Find More Posts by kaptondave
Joined Jan 2010
Yes, but I believe that is done simply by *cropping" the full sensor image, using just the centr and throwing the rest way? That is what many camera manufacturers call "digital zoom", as opposed to optical zoom which shifts the focal length of the lens. The result is a lower-resolution image.
kaptondave is offline Find More Posts by kaptondave
Old Jan 22, 2013, 06:16 PM
Joined Jan 2010
Not true. All camera lenses are circular (round) but most conventional lenses are optically corrected to produce an image that does not have visible distortion of straight lines. In conventional lenses only specialty lenses called fish-eyes produce images with visible spherical distortion.
Old Jan 22, 2013, 06:29 PM
Joined Jan 2010
Dave,
I'm also looking for a camera/lens combo that captures a 1:1 image so that distance & speed are not distorted when flying FPV. Is that practical?Joel
Not as you state it. In photography a 1:1 image is one in which the subject is the same size at the image plane (i..e., on film) as it is in life. That is achieved only at extreme close-up distances with "macro" lenses. I think what you mean is a lens that produces a what photographers call a rectalinear image - one which is smaller than life but without distortion of straight lines. The field of view and focal length of such lenses is a function of the image ("film") size. In a 35 mm camera, which was the most popular type in the pre-digital era, that corresponded to a 50 mm lens with a diagonal FOV of ~47 degrees. In contrast a GoPro has a normal FOV of 110 degrees, or 90 degrees at the narrowest setting, which would be called super-wide or wide-angle in 35 mm photography.
http://en.wikipedia.org/wiki/Angle_of_view
Old Jan 22, 2013, 06:53 PM
Joined Jul 2009
Dave,
Thanks for the info! I was actually referring to a 1:1 image, so that distance & speed appear to be scaled correctly in the video, rather than zoomed-out like things appear in wide-angle lenses. I'd like to fly FPV through the goggles & have things appear life-size - so that if I were flying at 50 MPH, it would look like 50 MPH in the goggles. Or if I were flying at 200' AGL, it would look like 200' AGL in the goggles. Or if I were coming in on approach & there happened to be an obstacle to clear, I could accurately judge the distance & height. From what you've told me, I gather that it is at least impractical, if not impossible for this application.
Joel
Old Jan 22, 2013, 07:52 PM
Joined Jan 2010
Dave,
Thanks for the info! I was actually referring to a 1:1 image, so that distance & speed appear to be scaled correctly in the video, rather than zoomed-out like things appear in wide-angle lenses. I'd like to fly FPV through the goggles & have things appear life-size - so that if I were flying at 50 MPH, it would look like 50 MPH in the goggles. .... I gather that it is at least impractical, if not impossible for this application.
Joel
I think it is doable. The reason that the 50 mm focal length was considered to be the "normal" lens for 35 mm photography was that it produced what most people judged to be the most life-like perspective. If you can find a digital camera with something like a 50 degree FOV it should do what you want. I can't recommend any specific cameras but I think there are small "point and shoot" style cameras by Canon, Casio, etc. with video capability and video output that could be down-linked. A good place to look is dpphotoreviews.com.
Old Jan 22, 2013, 10:45 PM
rcoconut is online now
Find More Posts by rcoconut
Do you see what I see?
rcoconut's Avatar
Rancho Cucamonga, CA
Joined Sep 2006
Originally Posted by coreman View Post
Thanks for the link!! Will definitely look into that!
And nice mount for your GoPro!! I was gonna use the curve mount & secure the cam on the top of the fuselage.
rcoconut is online now Find More Posts by rcoconut
Old Jan 22, 2013, 11:50 PM
Myko is offline
Find More Posts by Myko
fly 1 day, repair the next 3
Myko's Avatar
United States, CA, San Mateo
Joined Dec 2012
O....my....gosh! What a blast. My maiden flight was 28 min on a 1800 mah 25c pack! Vertical for days! I'm so happy. the cg was a smidge nose heavy but not overwhelming. although I am a little worried about the flimsy tail section and the flex in the wings she's a far cry from my first plane, the vista ep from tower hobbies. (rip) Really really loved the straight up balls to the wall power. Can't wait to get back out there with my buddy F.A.R.M.E.R. The guys got great experience and flys a heli like a horny hummingbird.
Myko is offline Find More Posts by Myko
Old Jan 23, 2013, 01:12 AM
f.a.r.m.e.r is offline
Find More Posts by f.a.r.m.e.r
Farmer
f.a.r.m.e.r's Avatar
United States, CA
Joined Oct 2011
Aha mike
its been fun watching you progress every time we go out flying.. thanks for all you do and the great times
P.s you need a lawn chair and cup holders possibly some icy hot on your neck after flying that thing
btw mike is one hell of a cook lol
f.a.r.m.e.r is offline Find More Posts by f.a.r.m.e.r
Old Jan 23, 2013, 01:20 AM
muhkaydenz is offline
Find More Posts by muhkaydenz
muhkaydenz's Avatar
United States, UT, Provo
Joined Sep 2012
Here is my radian setup let me know what you think, thanks!
muhkaydenz is offline Find More Posts by muhkaydenz
Old Jan 23, 2013, 01:37 AM
foamyflyerr is offline
Find More Posts by foamyflyerr
Joined Jun 2012
Where in San Mateo do you fly at. I work in Belmont , and live in Hayward.
foamyflyerr is offline Find More Posts by foamyflyerr
Rave New Parkzone Radian Pro-discussion thread!!! lightspeeddud Electric Sailplanes 3750 Feb 11, 2016 10:41 PM
Gallery Parkzone Radian Pro Video bakon Electric Sailplanes 9 Sep 30, 2015 05:20 PM
Discussion Official Radian Pro Thread Magnumb Parkflyers 15 Aug 16, 2015 07:12 PM
New Product Parkzone Radian Pro bakon Electric Plane Talk 24 Oct 01, 2010 02:39 AM
Discussion Parkzone Radian Pro $229.99 BnF preorder Tekwip Hot Online Deals 10 Sep 29, 2010 05:35 PM
