To those who are new to soaring, I suggest picking up Old Buzzard's Soaring Book by Dave Thornburg. Coreman recommended it to me. It's a fun read, and you'll learn a lot. It's the best 16 bucks I've spent in the hobby in a long time. I also suggest picking up Paul Naton's Secrets of Thermal Soaring, High Performance Thermal Soaring, and Performance Tuning For Sailplanes DVDs. Watch them a few times & you'll gain an in-depth understanding of how it all works - from the details of how the air behaves to the aircraft setup. You can get them here: http://www.radiocarbonart.com/catego...uctional-DVDs/
Joel |
Latest blog entry: Eflite UMX Sbach 3D on 3s - 2300Kv/5043...
I do love that book and if it makes you remember the concepts easier, it's well worth it. |
Joined Jul 2011
Hey Hobbit, I had the same issue with receiver installation just doesn't seem to be enough room. I am using the 6channel Orange RX 2.4 from Hobbyking with a Satalite extension. I had to put the receiver just forward of the servos free floats okay. The battery still fits nicely and doesn't affect the CG.
Mike |
What about the soaring master class, anyone seen those? |
hey guys
my radian pro turned up today, got in from work for lunch, built it, bind it, set it up. its now in the car waiting for the end of work to fly it. i cant wait. it has no mixes as yet and im not likily to do them until i swap my reciever for an 8ch one i have spare from my dx8 purchase. i want to use it for the mixes like all moving ailerons/flaps then the rest like crow, reflex and camber. i was also thinking about seting it up so that my trainer button was the throttle, ive bought this to be a self launch glider not a hotliner, and wanted to use the throttle stick as flap then crow braking as you bring it back. also with the flaps coming down ill need the elevator to kick in and stop it ballooning. does anyone know where to start to get these mixes to work? otherwise i think im gonna be up all night trying to figure it out. if its even possible. one more thing. has anyone carried out the mods involving the tailplane angle adjustment and CoG movement as suggested by "Radio carbon art" in their youtube video? how did it work out? is it a better flying sailplane? how does it effect the flying speeds, trim or control authority? if there is a single post here somewhere that explains all this id love to be directed there. too many pages to filter through when i just wanna fly a great glider. thanks in advance for your help. russell |
Joined Jan 2010
Russell, I use a programmed flap-to-elevator mix.. It does not take very much elevator. I suggest using at 10 percent and do some trial flap deployments at a safe altitude until you get it dialed in.I have made the stabilizer mod that Paul Naton talks about and like the result but suggest that you hole off doing that until you get some flight time with the standard configuration because the mo makes the plane less stable in pitch. If you o it measure the difference betwee the wing and stab incidence angles (called decalage) before cutting foam. Not all Raians are exactly alike and if you cut too much the plane will be difficult to fly. In my case I cut only about 1/2 as much ad Paul did. Follow the old carpenter's rule - measure twice, cut once.
There is a long discussion of the decalage mod here: http://www.rcgroups.com/forums/showthread.php?t=1646181 |
LI, New York, USA
Joined Mar 2003
http://www.horizonhobby.com/products...pnp-PKZ5475#t6 |
cheers for your speedy reply. ill hold off on the stab mod for a bit then. im sure i could handle it a bit more pitchy, dial down the throws etc. modded my bros radian as he wanted flaperons. had loads of time on that before the mod so this will be a step up. i just like the radian so much i needed a self launch glider in my life. my 3mtr condor doesnt get flown much since i got my 4mtr ask21, and that only get flown in the best weather or on aerotow situations. so the RP will fill the void of not having a local tug or close by hill. |
| Thread Tools | |
| Rave New Parkzone Radian Pro-discussion thread!!! | lightspeeddud | Electric Sailplanes | 3624 | May 28, 2013 04:03 PM |
| Discussion Official Radian Pro Thread | Magnumb | Parkflyers | 14 | Apr 10, 2011 10:56 PM |
| Gallery Parkzone Radian Pro Video | bakon | Electric Sailplanes | 6 | Mar 11, 2011 05:21 PM |
| New Product Parkzone Radian Pro | bakon | Electric Plane Talk | 24 | Oct 01, 2010 01:39 AM |
| Discussion Parkzone Radian Pro $229.99 BnF preorder | Tekwip | Hot Online Deals | 10 | Sep 29, 2010 04:35 PM |
