Old Jan 17, 2013, 09:58 PM
Myko is offline
Find More Posts by Myko
fly 1 day, repair the next 3
Myko's Avatar
United States, CA, San Mateo
Joined Dec 2012
Yippee, I just ordered a RP! For the first time I will not have to worry about motors or battery or esc's matching up. Just take it out of the box and ficken fly the thing. Can't wait. One thing though... I'm going to be using a 3 cell 1800 mAh 25c pack and was wondering if this is going to be a problem. Maybe just move the pack forward a little to get a correct cg. Might give me a little more umph.
Myko is offline Find More Posts by Myko
Old Jan 17, 2013, 11:25 PM
Jasong911 is online now
Find More Posts by Jasong911
United States, CO, Lakewood
Joined Jan 2011
I would recommend the 1300 over the 1800 for normal thermal hunting. I needed more weight rearwards on mine. I fly my 1800 and 2200's when the wind is ripping and I want weight forward and upwind penetration overall.
--Jason
Jasong911 is online now Find More Posts by Jasong911
Old Jan 18, 2013, 05:29 AM
coreman is online now
Find More Posts by coreman
Kit Manufacturer
coreman's Avatar
United States, MA, Southbridge
Joined Feb 2010
Originally Posted by mikeruth View Post
For me I have been in the hobby now for over 40 years, of course back then nitro was about your only option, and I never would have even given the thought of flying a glider more than a heartbeats time. I flew pattern for many years and have to say I enjoyed it quite a bit, then the electrics started appearing. Didn't think much of it in the begining as packs were expensive and of course the variety was small. As it grew I got an EZ glider and of course souped it up and flew it more like a plane on steriods than a glider, then I was introduced to a field that was electric only and how to look for thermals. That was it, almost all of my RC interest went there, I still fly hot rods now and then, I think its good for the fingers and the rush. No matter what a 150+mph beast is a rush. I build and sell a 3D epp plane that is simply put, a blast as well But as I have progressed with gliders I'm now in to DLG's as well. That to was a segment of this hobby I would have never thought of doing and now I watch the sky and the air no matter where I am when ever I can, wishing I had a plane up right now!. I'm addicted
sorry for off topic comments, back to regular programing
I assume you've looked at the adrenaline rush? yeah, I've been in it since 1970 so I can relate. Lipos were a godsend from a weight perspective. 16 nicad cells gets a bit heavy. My glider introduction was a 2M with an .049 power pod I had to wait to run out of fuel before gliding and there were no go arounds, still, it was fun and led me to compete in thermal duration for years. The RP is a nice reentry into lawn chair flying for fun and relaxation. being a manufacturer is so much fun, isn't it?
coreman is online now Find More Posts by coreman
Latest blog entry: BluFO review by Jim T Graham
Old Jan 18, 2013, 11:46 AM
rcoconut is offline
Find More Posts by rcoconut
Do you see what I see?
rcoconut's Avatar
Rancho Cucamonga, CA
Joined Sep 2006
Congrats!!! She's a blast, you'll have fun, escpecially when you get that first thermal!!
Have fun!!!
rcoconut is offline Find More Posts by rcoconut
Old Jan 18, 2013, 12:10 PM
Jovanx is offline
Find More Posts by Jovanx
Tossing planes into the snow
Canada, BC, Smithers
Joined Nov 2011
--Jason
Agreed that the 1300 is better for everyday flying. I also have a 1000 50c battery that is even lighter and it's great. I tried using bigger batteries on windy days and they help, but what works even better is ballast in the wing tube. This plane is nose heavy out of the box even with the recommended 1300, and a bigger battery makes it more nose heavy
I have a solid 3/8" steel rod that I use as a wing spar on super-windy days. It weighs almost 400 grams but doesn't change the CG due to it's location, and wing-flex is zero because it is so stiff. It also reduces the roll rate which isn't a bad thing on days like that. Gusts have less of a tendency to tilt the wings, so it provides a degree of lateral stability as well.
Jovanx is offline Find More Posts by Jovanx
Old Jan 18, 2013, 12:28 PM
Joined Jan 2011
I tried using just my 1/4 inch threaded steel rod glued inside the stock spar on a windy day, and it wasn't enough for me. My primary field is in the lee of a sharp ridge, and if the temp is warm enough to fly without my blizzard gear, then it usually means that the drainage winds are howling, and we get a 15 to 30 type day. It's fun when using both the larger battery and heavy spar, and a lot more "Whoa!" when I put in the 1300. Still, all the experimenting is blazing good fun.
--jason
Old Jan 18, 2013, 12:47 PM
Jovanx is offline
Joined Nov 2011
Yes flying in the mountains has it's rewards and challenges, whether it is summer or winter. There is no such thing as a steady wind. It changes directions often and gusts can be devastating. Most days I like to fly the Radian and RP as light as possible and just deal with the wind and do hover-landings. When the wind gets really crazy, the heavy wing spar settles them down nicely.
If you go to your local welding shop, they should have a 3/8" non-threaded steel rod. If not they should know where you could get one. It is much heavier than a 1/4" threaded rod, and fits nicely into the wings.
mikeruth is online now
Find More Posts by mikeruth
The "Foaminator"
mikeruth's Avatar
Joined Mar 2007
Haven't done the Adreniline Rush yet! but I have done the NanoPlanes Babyshark built up, Radar said 165! Felt like 265 LOL. They do capture your attention.
And as a manufacture, uggg, if I was making a living at it well maybe, but it's just for the local crowd. Did 76 planes in 6 months last year and due to moving and health had to stop for a while. That might be a good thing
mikeruth is online now Find More Posts by mikeruth
Old Jan 18, 2013, 01:29 PM
Myko is offline
Myko's Avatar
Joined Dec 2012
Has anybody attempted or achieved a barrelroll? Is it even possible?
Old Jan 18, 2013, 01:36 PM
The "Foaminator"
mikeruth's Avatar
Joined Mar 2007
Uhh yeah, attempted and achieved by many i'm sure.
Old Jan 18, 2013, 01:38 PM
Jovanx is offline
Joined Nov 2011
Yes it is possible and I have done it once. It is also possible to get a Mustang to soar if there is enough lift, and I have done that too.
Old Jan 18, 2013, 04:21 PM
Kit Manufacturer
coreman's Avatar
Joined Feb 2010
165!! I'm just building my first AR but I have it cranking 3000kv 2730 with 4.75x4.75 props which should get it at least over 100. With the profile, I figure I'll just listen for the impact in the trees downrange as my eyes will never keep up with it. I did 56 BnF planes last year and it saddens me to be in my shop all the time for others. i used to love scratch building
Old Jan 18, 2013, 07:02 PM
turboparker is offline
Find More Posts by turboparker
Gopher huntin' stick jockey
turboparker's Avatar
Joined Jul 2009
LOL! That was good. I once thermalled my .91 Saito-powered Ace Bingo! Had her just off-idle with the on-board glow lit, circling for nearly 10 minutes without losing altitude. Unfortunately, I had to cut out early. The club field's resident bald eagle wasn't in the mood for sharing his hunting circle with me that day & decided give chase. I quickly learned that bald eagles can be pretty damn fast when they want to be, and that they can easily out-maneuver a 60-size Bingo! I could just barely stay ahead of him @ WOT in level flight, and he'd start to catch up in the turns. He chased me around the field long enough that I was worried about running out of fuel. He finally got bored & broke it off. There was just over an ounce of useable fuel left in the tank when I got back to the pits.
Joel
turboparker is offline Find More Posts by turboparker
Old Jan 18, 2013, 07:49 PM
JumpySticks is offline
Find More Posts by JumpySticks
Drifting off the reservation..
JumpySticks's Avatar
USA, LA, Broussard
Joined Jan 2011
Yes, the RP will barrel roll. It takes some speed which bleeds off lots of energy.
JumpySticks is offline Find More Posts by JumpySticks
Old Jan 18, 2013, 08:20 PM
ppridday is online now
Find More Posts by ppridday
Breaker of Things
ppridday's Avatar
United States, MN, Detroit Lakes
Joined Mar 2005
I bought a Radian Pro last summer and had it out a few times. This is my first plane after flying heli's for a few years. I thought it would be an nice relaxing change and I had a blast just floating around learning how a plane reacts etc. Now I finally come on here to read up on the threads here and over at the Mystique thread. (saw the banner ad and thought it was a cool looking glider) Wow, there seems to be a LOT more to gliders than just motoring up and floating down, motoring up and floating down....
I'm going to go check out HobbyKing and see if I can buy an electronic thermal finder...
Paul
ppridday is online now Find More Posts by ppridday
Rave New Parkzone Radian Pro-discussion thread!!! lightspeeddud Electric Sailplanes 3856 Jul 18, 2016 05:40 PM
Gallery Parkzone Radian Pro Video bakon Electric Sailplanes 9 Sep 30, 2015 04:20 PM
Discussion Official Radian Pro Thread Magnumb Parkflyers 15 Aug 16, 2015 06:12 PM
New Product Parkzone Radian Pro bakon Electric Plane Talk 24 Oct 01, 2010 01:39 AM
Discussion Parkzone Radian Pro $229.99 BnF preorder Tekwip Hot Online Deals 10 Sep 29, 2010 04:35 PM
