Old Dec 14, 2012, 11:37 AM
campbellj is offline
Find More Posts by campbellj
campbellj's Avatar
United States, FL, Port St Lucie
Joined Jan 2011
Originally Posted by Jovanx View Post
Could you possibly post some pictures of your mod? Did you just put a ring around each prop pin, or cover the whole thing? I would like to try this.
After a year with the RP and 5 months with the Radian, I never broke a prop or a spinner. There were a few minor nose-ins along the way. Then I started to push the envelope (slope soaring over rocks and lots of hand-catches), and broke 4 of them in 2 months. It is not minor nose in events that break it, but prop strikes. All 4 were caused by my wrong decision to hit the throttle when the plane was too close to the ground.
If you hear that squealing sound, you may as well assume the spinner is broken.
+1 for the pics, I would also like to see it. Seems like a great idea!
campbellj is offline Find More Posts by campbellj
Old Dec 14, 2012, 07:27 PM
Moby58 is online now
Find More Posts by Moby58
Upside down, downunder in Oz
Moby58's Avatar
Thornlie, Australia
Joined Jul 2005
Originally Posted by kaptondave View Post
I have no proof but my theory is that you should avoid mounting a receiver in close proximity to the ESC. ESCs generate high energy pulses which could cause interference.
Also, the ESC will generate a lot of heat at times, so anything on top wil a) reduce cooling of ESC, and b) put that heat into the sat aerial.
Moby58 is online now Find More Posts by Moby58
Old Dec 14, 2012, 07:49 PM
Zor is offline
Zor
Find More Posts by Zor
Zor
Ontario,Canada
Joined Feb 2007
Originally Posted by campbellj View Post
Stayed up tonight and repaired my wings on my RP the best I could. I'm probably not going to go too much more with it though, unless any of you have any more suggestions. I will probably put clear packing tape all down the leading edges and I might fill in the scratches with light weight spackle but that will be about it. Here is what I done so far
I'm pretty happy with the results so far. Hopefully I will have her back up in the air soon!
You could install an aluminum leading edge as I did on my Radian pro.
Zor
Zor is offline Find More Posts by Zor
Reply With Quote  (Disabled)
Old Dec 14, 2012, 08:51 PM
jrtubb is offline
Find More Posts by jrtubb
I Fly!
jrtubb's Avatar
United States, AL, Huntsville
Joined Jan 2011
Let me see see what I can do tonight. I didn't take in pictures as I went so I'll go out and update the extra one I have.
jrtubb is offline Find More Posts by jrtubb
Old Dec 14, 2012, 09:37 PM
jrtubb is offline
I Fly!
jrtubb's Avatar
Joined Jan 2011
Sorry pictures suck I tried the best but camera was having a hard time focusing, you should be able to get the general idea.
You will need fiberglass cloth for joining built up balsa wings.
Description: First you will need some fiberglass, I used some for joining balsa wings together.
Rough up / sand lightly the four areas on each side of the spinner where the pins insert to hold the prop blades in.
Description: Sand this area a bit with a file, you want to rough up the surface to bond the fiberglass too.
Cut the fiberglass into strips and place on each section and drop CA glue onto it. I use the tip to spread it out all the way past the edges of the spinner sides. Using some pliers to hold it keeps you from gluing your fingers together
Description: Cut fiberglass into strips and place on this area, I drop the CA glue onto it and use the tip to spread it out as I go.
Old Dec 14, 2012, 09:47 PM
jrtubb is offline
I Fly!
jrtubb's Avatar
Joined Jan 2011
Let the glue dry really good for each of the four sides, you want some glue to wick-out from the edges to make it easier to trim flush to the sides.
Description:
When glue is dry, trip with hobby knife flush to the edges and one up the pin holes.
Description:
That is it, you will need to sand down the spinner inside edges that touch the sides that have fiberglass s they will still fit together smoothly.
Old Dec 15, 2012, 06:08 PM
Jovanx is offline
Find More Posts by Jovanx
Tossing planes into the snow
Canada, BC, Smithers
Joined Nov 2011
Thanks for that jrtubb. Although the pictures were fuzzy the verbal description was clear. I have pondered other possible solutions such as hollowing out some of the cheap plastic and putting a metal or nylon washer there to make it stronger.
I know all the guys with aluminum spinners are laughing while reading this, but I just can't bring myself to the point of adding a bunch of weight to the front of a plane that is already nose heavy.
In defense of aluminum spinners, both Radio.Active and Av8rshane have come up with effective methods of moving the CG back, making the use of heavy aluminum spinners more viable. Maybe someday I will go that route, but right now I am sticking to the story that all of the failures of the stock spinner are pilot-induced.
Jovanx is offline Find More Posts by Jovanx
Old Dec 15, 2012, 06:14 PM
Nam Lemmi is offline
Find More Posts by Nam Lemmi
This thing runs real nice...
Nam Lemmi's Avatar
Joined Jun 2012
Finally bought a Radian Pro during the week(it's my first glider).
Had a lovely maiden in 15-20mph winds and even managed a little slope soaring.
The crow is amazing! Awesome to see how it slows the glider right down.
The ailerons seemed so sluggish. It felt like I had to use massive amounts of rudder to get the glider to turn. Why are the ailerons so ineffective?
Next day tried a low pass at WOT and lost control. She nosed into the ground at WOT
Nam Lemmi is offline Find More Posts by Nam Lemmi
Old Dec 15, 2012, 06:23 PM
Jovanx is offline
Joined Nov 2011
The ailerons are ineffective because the stock FG wing spar is so wimpy. If you replace that with a stiff CF rod the ailerons will respond to your commands.
Why would anybody do a low pass at WOT with this plane? It is a glider. I like to do high speed passes but only with the motor off.
Old Dec 15, 2012, 06:31 PM
600Bob is offline
Find More Posts by 600Bob
United States, OR, Canby
Joined Aug 2011
The longer the wings the more effect adverse yaw has and the greater the need for aileron differential.
600Bob is offline Find More Posts by 600Bob
Old Dec 15, 2012, 06:37 PM
coreman is online now
Find More Posts by coreman
Kit Manufacturer
coreman's Avatar
United States, MA, Southbridge
Joined Feb 2010
They are, the pilots refuse to see the light and swap them out!!
coreman is online now Find More Posts by coreman
Latest blog entry: BluFO review by Jim T Graham
Old Dec 15, 2012, 06:43 PM
Kit Manufacturer
coreman's Avatar
Joined Feb 2010
I think the phrase (it's my first glider) (and he said it was bought this week) answers that question.
As a power pilot, what is your first task once the trimming is done? WOT passes.
What does the peanut gallery chant? Lower! Lower!
Old Dec 15, 2012, 07:29 PM
turboparker is offline
Find More Posts by turboparker
Gopher huntin' stick jockey
turboparker's Avatar
Joined Jul 2009
WOT passes.
Actually - as a power pilot, the first task after trimming should be to explore the plane's low-speed handling qualities, stall-behavior, and power-on/power-off glide characteristics up high. I've been doing it that way for 28 years so far. It tends to greatly extend a plane's service life.
Joel
turboparker is offline Find More Posts by turboparker
Old Dec 15, 2012, 07:33 PM
Jovanx is offline
Joined Nov 2011
LOL true! There is a limit to how low you can go. After that limit is exceeded, you no longer have a bunch of parts flying in formation.
Old Dec 15, 2012, 07:45 PM
Jovanx is offline
Joined Nov 2011
Joel
I totally agree. Every time I maiden a new plane, I test out it's gliding abilities and stall characteristics, even though it is not a glider. I had a 28 minute flight with the Mustang once, thanks to a major thermal event. IMO trying to fly a warbird as a glider is better than trying to fly a glider as a warbird.
Rave New Parkzone Radian Pro-discussion thread!!! lightspeeddud Electric Sailplanes 3853 Jun 07, 2016 12:56 PM
Gallery Parkzone Radian Pro Video bakon Electric Sailplanes 9 Sep 30, 2015 04:20 PM
Discussion Official Radian Pro Thread Magnumb Parkflyers 15 Aug 16, 2015 06:12 PM
New Product Parkzone Radian Pro bakon Electric Plane Talk 24 Oct 01, 2010 01:39 AM
Discussion Parkzone Radian Pro $229.99 BnF preorder Tekwip Hot Online Deals 10 Sep 29, 2010 04:35 PM
