Old Oct 24, 2012, 10:48 PM
Jasong911 is online now
Find More Posts by Jasong911
United States, CO, Lakewood
Joined Jan 2011
So, Clif, ...has the decalage between Hstab and wing been off by much on the pro when you measure at the root of the main?
--Jason
Oh, and the servos have held up fine on mine, even without covers.
Jasong911 is online now Find More Posts by Jasong911
Old Oct 25, 2012, 09:50 AM
jrtubb is offline
Find More Posts by jrtubb
I Fly!
jrtubb's Avatar
United States, AL, Huntsville
Joined Jan 2011
I was thinking of getting a Radian PNP or PZ T-28 as a something different to have at the field in addition to my RP. I was leaning toward the Radian since it would use all the batteries I already have. But I've seen how nice and fun the T-28 is but would have to get more 1800-2200 batteries. Any thoughts?
jrtubb is offline Find More Posts by jrtubb
Old Oct 25, 2012, 09:55 AM
coreman is offline
Find More Posts by coreman
Kit Manufacturer
coreman's Avatar
United States, MA, Southbridge
Joined Feb 2010
what need is the RP not fulfilling? My thought is the Radian would be redundant
coreman is offline Find More Posts by coreman
Latest blog entry: BluFO review by Jim T Graham
Old Oct 25, 2012, 10:03 AM
Rickn816 is offline
Find More Posts by Rickn816
RCHN #150
Rickn816's Avatar
Lawrenceville, GA
Joined Nov 2007
Most of us would probably do one of each.
Or, already have.
Rick
Rickn816 is offline Find More Posts by Rickn816
Old Oct 25, 2012, 10:56 AM
Brian VT is offline
Find More Posts by Brian VT
Brian VT's Avatar
United States, VT, Rutland
Joined Dec 2011
You can run those in your RP, too.
Brian VT is offline Find More Posts by Brian VT
Old Oct 25, 2012, 11:08 AM
Jovanx is offline
Find More Posts by Jovanx
Tossing planes into the snow
Canada, BC, Smithers
Joined Nov 2011
A Radian in addition to a Radian Pro is definitely not redundant. They are very different airplanes, and each can do things the other one cannot. I like them both for different reasons. The Radian floats much better especially in light lift. It is slower and more friendly to land or catch in small spaces. You can relax much more than you can with the RP, and even hand your transmitter to someone who has never flown before.
On the other hand, the RP can do many things the Radian cannot do.
Jovanx is offline Find More Posts by Jovanx
Old Oct 25, 2012, 11:42 AM
coreman is offline
Kit Manufacturer
coreman's Avatar
Joined Feb 2010
Thank you. I just see the things the Radian can't do compared to the Pro and would miss them due to my background with gliders
Old Oct 25, 2012, 03:19 PM
jrtubb is offline
I Fly!
jrtubb's Avatar
Joined Jan 2011
So I do know I run the larger batteries in the Pro, I have a 2100 pack for heavy wind days. But in light wind days the heavy pack is useless as the plane sinks too fast and I end up motoring around the entire time.
I've flown with the Radian guys and they do float much easier in the light lift conditions we have at our field. Which is why I was interested in one. I also have a few smaller fields I would like to fly in that I don't feel comfortable with the RP in.
To make matters worse I was also considering the PZ BL P-51, but I would have to add wheels for our paved runway...
Old Oct 25, 2012, 05:12 PM
cliffkot is offline
Find More Posts by cliffkot
cliffkot's Avatar
Joined Jun 2010
--Jason
Well, I should have prefaced my comments. I fly a Radian, not the pro, so I can't comment on that particular bird. My new Radian had 2 degrees of decalage out of the box, measured on the main wing about 2 inches or so from the fuse. I set the decalage angle to 0.5 degrees using the light weight bubble level method because the weight of the Robart on the stab caused it to bend. Even the fuse twisted a little. I never felt confident that I could get it right. In fact initially my measurement was off and caused me to cut too much. I realized my mistake after I used the level to check my setup and had to undo things. Once I flight test the Radian I plan to inject some Gorilla glue or calk into the slot to fix things.
Right now my mind is on a leaky hot water heater, so flying will have to wait.
Cliff
cliffkot is offline Find More Posts by cliffkot
Old Oct 25, 2012, 05:14 PM
coreman is offline
Kit Manufacturer
coreman's Avatar
Joined Feb 2010
Cliff
That is why I suggested checking the stab decalage both upright and inverted and then average the position.
Old Oct 26, 2012, 09:32 AM
Jimn8uay is offline
Find More Posts by Jimn8uay
JimN8UAY
United States, OH, Medina
Comments? I have a RP that I needed to rework a bit from some recent abuse. I am remounting the nose cone/motor mount and noticed a pretty large amount of down and right thrust angle molded into the piece. Since I've made some mods in decalage and balance, should I shim the motor mount to a more neutral thrust angle?
Jim
Jimn8uay is offline Find More Posts by Jimn8uay
Old Oct 26, 2012, 03:55 PM
coreman is offline
Kit Manufacturer
coreman's Avatar
Joined Feb 2010
Jim
I wouldn't. it seems to fly pretty well under power with that setup
Old Oct 26, 2012, 04:55 PM
av8ersteve is offline
Find More Posts by av8ersteve
I did it...
av8ersteve's Avatar
Morganton, NC
Joined Jun 2005
Hey all. My DX18 just showed up cutesy of FedX. The first thing that is going in my new radio is my RP. What all can I do with the stock receiver in the Radion? Is anyone flying with the 18? Thanks for any help. Learning a new radio is sometimes challenging but I hope not to bad with this as I have been flying with the DX6i.
av8ersteve is offline Find More Posts by av8ersteve
Old Oct 26, 2012, 05:42 PM
Radio.Active is offline
Find More Posts by Radio.Active
Closed Account
Joined Aug 2011
Radio.Active is offline Find More Posts by Radio.Active
Old Oct 26, 2012, 05:55 PM
I did it...
av8ersteve's Avatar
Morganton, NC
Joined Jun 2005
Originally Posted by Radio.Active View Post
Congradulations on your investment. The receiver has nothing to do with it. Okay someone surely have a say here, but, you have a bunch of preporgrammed sailplane settings and wing types. You might find yourself moving some of the servos/channels around, get rid of all Y-Adapters, study the "wing-types" and "tail types" and "flight modes" under the sailplane settings.
You will be able to program "launch", "thermal" an "land" settings and more as I think there is about a dozen separate sailplane modes in the computer.
I suggest you search around RCG and Google to see if someone already has a nice full house setup you can plagerize and get up quickly. Then fine tune it for your likes. I always work on the assumption that someone has done or fixed this before me and i just need to search them out.
Did you also order any telemetery sensors? The altimeter would be nice to see lift especially when flying directly overhead.
No telemetery sensors yet (have to save some more) but the initial investment is made. I love the way this thing looks, and feels. And, that is what I'm hopeing for here, someone that has already done a full house setup with this beast so I can get up quickly. The sailplane software is more than I have ever seen, one of the reasons I got it, and I'm hopeing to learn it all, just going to take some time. Thanks for your help.
Rave New Parkzone Radian Pro-discussion thread!!! lightspeeddud Electric Sailplanes 3853 Jun 07, 2016 12:56 PM
Gallery Parkzone Radian Pro Video bakon Electric Sailplanes 9 Sep 30, 2015 04:20 PM
Discussion Official Radian Pro Thread Magnumb Parkflyers 15 Aug 16, 2015 06:12 PM
New Product Parkzone Radian Pro bakon Electric Plane Talk 24 Oct 01, 2010 01:39 AM
Discussion Parkzone Radian Pro $229.99 BnF preorder Tekwip Hot Online Deals 10 Sep 29, 2010 04:35 PM
