Old Oct 16, 2012, 08:53 AM
coreman is offline
Find More Posts by coreman
Kit Manufacturer
coreman's Avatar
United States, MA, Southbridge
Joined Feb 2010
Originally Posted by KLRico View Post
I will only fly gliders while seated in lawn chair.
That was my main criteria when I bought my Radian Pro
coreman is offline Find More Posts by coreman
Old Oct 16, 2012, 12:02 PM
Fish99 is offline
Find More Posts by Fish99
Flying addicted and lovin it!
Fish99's Avatar
Canada, AB, Edmonton
Joined Jun 2010
I love those long lasting and strong thermals, like an elevator to the sky!
LOL, I hear you. I have taken a camping chair to the local park a few times and plunked it down and just stretched out and flew for 45 minutes! Gets loads of funny comments and chats from passer's by. Just didn't have that with me at the flight station at the club field.
Marlin
Fish99 is offline Find More Posts by Fish99
Old Oct 16, 2012, 12:50 PM
KLRico is offline
Find More Posts by KLRico
United States, WA, Spokane
Joined Feb 2004
Yeah, when I fly at the park and the plane is up nearly out of sight, it seems that most people just think I'm sleeping in my chair. LOL.
KLRico is offline Find More Posts by KLRico
Old Oct 16, 2012, 01:09 PM
coreman is offline
Kit Manufacturer
coreman's Avatar
Joined Feb 2010
it can be a pain in the butt when they stand in your line of sight to meet your eyes
Old Oct 16, 2012, 09:05 PM
Jovanx is offline
Find More Posts by Jovanx
Tossing planes into the snow
Canada, BC, Smithers
Joined Nov 2011
The man who is standing will always have the Darwinian advantage over the man who is seated in a chair.
Jovanx is offline Find More Posts by Jovanx
Old Oct 16, 2012, 09:49 PM
chronodeco is offline
Find More Posts by chronodeco
Joined Aug 2011
Mods....
Originally Posted by coreman View Post
I think part of my problem is that I am comparing it to my open class competition ships. I just need a good glider day to see what I can get out of it. Too little data in one flight in suboptimal conditions. I was a bit surprised about the sink rate so i will throw my Robart meter on it and probably do the boom strengthening mods and get everything straight and true. it's worth 50 cents if I can get useful weight in the tail!
Oh, and I was pleased with how flat it would turn. That shows promise
Extend the ailerons to the tips. Then it will be more like a comp ship. Stock aileron responce is too slow, especially in thermal kick out.
chronodeco is offline Find More Posts by chronodeco
Old Oct 17, 2012, 08:59 AM
jrtubb is offline
Find More Posts by jrtubb
I Fly!
jrtubb's Avatar
United States, AL, Huntsville
Joined Jan 2011
Do you have some photos showing this change?
jrtubb is offline Find More Posts by jrtubb
Old Oct 17, 2012, 12:13 PM
JumpySticks is offline
Find More Posts by JumpySticks
Drifting off the reservation..
JumpySticks's Avatar
USA, LA, Broussard
Joined Jan 2011
Drag a tip and off they'll rip.
JumpySticks is offline Find More Posts by JumpySticks
Old Oct 17, 2012, 12:14 PM
Jovanx is offline
Joined Nov 2011
Extending the ailerons out to the tips would be easy, and so would extending them inwards, by stealing some of the flaps. The flaps are so brutally effective, that stealing a bit probably wouldn't hurt. I was thinking of doing both of these at one point, but after putting in a stiffer wing spar, the aileron performance improved noticeably and I'm happy with the way it flies.
Old Oct 17, 2012, 12:16 PM
USA, LA, Broussard
Joined Jan 2011
The polyhedral won't allow inward extension.
If you want more aileron surface, enlarge them 1/2 inch rearward with some clear plastic.
I think the stock ailerons are fine with the stiffer wing spar.
Old Oct 17, 2012, 02:53 PM
turboparker is online now
Find More Posts by turboparker
Gopher huntin' stick jockey
turboparker's Avatar
Joined Jul 2009
Had fun at the field yesterday. Now that I have things set up reasonably well, I spent the day attempting to find & stay in some lift. Finding lift was really easy. Staying in it was a more of a challenge, however. I've been doing a lot of reading today.....
A question for the experienced RP pilots on here - how many degrees of full-span camber should I use for weaker lift conditions? Or, put another way - what's the most camber that one should use for thermalling? (I'm assuming that there is a point where the increase in drag of adding more camber will overcome any increase in lift.)
Joel
turboparker is online now Find More Posts by turboparker
Old Oct 17, 2012, 03:24 PM
coreman is offline
Kit Manufacturer
coreman's Avatar
Joined Feb 2010
Joel
it's going to depend on your wing loading and how strong the lift is. I generally droop the TE about 1/8"-3/16" and then compensate with some up/down elevator if need be. In a unpowered glider you generally put it on the throttle stick and feed in whatever it will take and then try to lock into the core of the thermal and keep the wing as flat as possible. You could probably put it on a transmitter knob but that is always bothersome as you never know if it is back to neutral once you turn it off (would have to be on a switch mix to the knob). If the lift is strong, you can put in quite a bit. you can also use high rate elevator to help keep it climbing and you can use elevator to flap mixing also on the switch. There are lots of ways and it really is personal preference and you have to get a feel for what works. The problem is there is no "standard" thermal and each one will be different and you need to watch your plane and see how it is reacting. One of the reasons gliders "indicate" thermals by going faster is that the tail gets raised so you are "diving" through the thermal and so feeding in elevator to level it off will actually cause you to climb with the rising column of lift
Later: Sounds like the day you flew was a good day to do testing in that you had a recurring cycle of lift. Those days are nice because the thermals tend to be more uniform and in similar sections of the sky so you can adjust and test and repeat
Old Oct 17, 2012, 04:53 PM
peterlngh is offline
Find More Posts by peterlngh
Joined Apr 2012
I have found that one of the biggest issues with the foamies I've flown is that the control surfaces are not rigid enough. I don't think that the overall size is the major problem. I have used Skyloft fabric to stiffen some and replaced others with balsa and have found the controls much more responsive in every case.
peterlngh is offline Find More Posts by peterlngh
Old Oct 17, 2012, 07:47 PM
USA, LA, Broussard
Joined Jan 2011
Joel
I think 1/8" is plenty of camber. I don't think it's a good idea to put camber on a proportional control because you just don't know how much you are adding.
Mine is on a three way switch. Forward is 1/8" reflex, neutral is neutral, and back is 1/8" camber. That's about the thickness of the trailing edge.
If you have the flaps on the throttle lever or other proportional flap control, you can always add a tad more flap to increase camber on the inboard part of the wing.
I use camber sparingly because the stock wing is really a good design at most speeds.
Old Oct 17, 2012, 07:57 PM
Joined Jul 2009
Thanks for the info guys!
I already have proportional camber/reflex assigned to the right-hand slider on the rear of my 10CHP, so it's very easy to operate & feel the position. The center detent is neutral, while full down is 3/8" TE droop, and full up is 1/8" aileron-only reflex. I have proportional flaps set up on the left-hand rear slider, and crow set up on a switch. I was just wondering if I may be using too much camber for the conditions. I just rechecked my camber setup menu, and found that I had forgotten to add down-trim with camber. That explains things! No wonder I had to crank in so much down-trim when using camber.
Joel
Rave New Parkzone Radian Pro-discussion thread!!! lightspeeddud Electric Sailplanes 3798 Today 02:12 AM
Gallery Parkzone Radian Pro Video bakon Electric Sailplanes 9 Sep 30, 2015 04:20 PM
Discussion Official Radian Pro Thread Magnumb Parkflyers 15 Aug 16, 2015 06:12 PM
New Product Parkzone Radian Pro bakon Electric Plane Talk 24 Oct 01, 2010 01:39 AM
Discussion Parkzone Radian Pro $229.99 BnF preorder Tekwip Hot Online Deals 10 Sep 29, 2010 04:35 PM
