I took the RP to the club field today, despite the 9-17 MPH wind. I've been wanting to test the advanced wing functions & get things tuned-in, but the wx just hasn't been cooperating. Today was about as good as it will be for awhile, so I decided to go for it. I'm running proportional camber & reflex, proportional flaps, and single-position crow on my 10CHP. I've got the elevator mix & delay set up so that there is no pitch change when crow is engaged or when adding camber.
I was messing around with adding camber & gliding backwards across the runway, switching to reflex and moving forward again, and then coming around on approach & engaging crow for a spot-landing in the wind. I think I've got things dialed-in fairly well as a starting point. Now I just need a day with some lift. Joel |
Latest blog entry: Eflite UMX Sbach 3D on 3s - 2300Kv/5043...
Forecast says 2-10 MPH winds & 65 F for today, and 5-9 MPH & 70 F for tomorrow. Finally, I will be able to get in some serious stick-time on this bird! Looking forward to exploring the lift conditions around the club field.
I plan to shoot some on-board video.Joel |
I have the replacement 9.5mm CF wing rod coming as well as a CF square tube to use for the tailboom reinforcement (I feel using the square tube will install easier). I'll be doing most of Paul Naton's modifications eventually. Just moving the CG back (2 quarters taped to the base of the fin) to 80mm with no decalage change flattened out the power on climb Jim |
Stunts, loops, and some ZOOMING then back to the thermal for a climb. Had to pack it in after 30 or 40 minutes as my neck was getting sore from staring UP! LOL Sure is a different style of flying, very relaxing and very rewarding when you catch that thermal. The telemetry unit with Baro Altimiter was a GREAT add on as well, you can see right away when you get a thermal. Take care, Marlin |
Didn't know that you had a sailplane! The RP is my first purpose-built sailplane & I am having a blast! I just love surfing the currents, staying up there for ages without even using the motor. As you noted - it is so relaxing, and catching some lift is very rewarding. Yesterday was a great flying day in general, but there wasn't much lift at the field. I managed to catch a couple of weak thermals, but I had trouble staying in them. I mainly worked on fine-tuning my camber, reflex, and crow mixes. I've got crow & reflex working the way I want them to, but I'm still getting a bit of porpoising when I use the camber mix. Not sure if I need a bit more down-elevator, or if I'm just using too much camber. Today it's supposed to be partly cloudy & 70 F, with 6-9 MPH winds. I'll be spending most of the day at the club field. I plan to shoot some more on-board video. If I get anything worth watching, I'll post a clip. BTW - that baro unit sounds very interesting. I'll have to check it out.Take care, and may there always be lift under your wings! ![]() Joel |
United States, WA, Spokane
Joined Feb 2004
![]() I love those long lasting and strong thermals, like an elevator to the sky!
| Thread Tools | |
| Rave New Parkzone Radian Pro-discussion thread!!! | lightspeeddud | Electric Sailplanes | 3620 | May 13, 2013 04:23 PM |
| Discussion Official Radian Pro Thread | Magnumb | Parkflyers | 14 | Apr 10, 2011 10:56 PM |
| Gallery Parkzone Radian Pro Video | bakon | Electric Sailplanes | 6 | Mar 11, 2011 05:21 PM |
| New Product Parkzone Radian Pro | bakon | Electric Plane Talk | 24 | Oct 01, 2010 01:39 AM |
| Discussion Parkzone Radian Pro $229.99 BnF preorder | Tekwip | Hot Online Deals | 10 | Sep 29, 2010 04:35 PM |
