Old Sep 27, 2012, 03:19 PM
Brian VT is online now
Find More Posts by Brian VT
Brian VT's Avatar
United States, VT, Rutland
Joined Dec 2011
Originally Posted by Radio.Active View Post
I started to fly his while mine spiralled in.
LOL. I never heard of that and I haven't flown with anyone else yet.
Thanks for the "heads up", in case I ever get into that situation.
Brian VT is online now Find More Posts by Brian VT
Old Sep 27, 2012, 03:20 PM
Radio.Active is offline
Find More Posts by Radio.Active
Closed Account
Joined Aug 2011
Radio.Active is offline Find More Posts by Radio.Active
Old Sep 27, 2012, 03:22 PM
coreman is offline
Find More Posts by coreman
Kit Manufacturer
coreman's Avatar
United States, MA, Southbridge
Joined Feb 2010
It seems I have to experience every possible noob mistake at least once. My most recent smack down was a result of flying with a friend and our 2 Radians got too close. They didn't crash! I started to fly his while mine spiralled in. I had heard of that happening but never though it would happen to me bwahhahhahaha.
That is a good reason to "personalize it" so you can tell the difference. Where I fly indoors we will regularly have 5-6 champs or vapors or embers up at once and regularly have planes fly into the wall unattended. When a high performance glider becomes the "must have" plane (Supra currently) it is very easy to see 3-5 of them coring the same thermal in a launch group and suddenly notice one wander out. it usually isn't immediate since you are all giving about the same inputs to circle the same space but at altitude is hard to see small trim details and even different colored large stripes on the bottom blend to gray/black. it's worse when the one you are watching wanders out because the pilot needs to come down to make his time and now you need to discover which remaining ones is yours... I always try to put a chrome strip on my leading edges so I get a flash once per revolution from the sun. That helps at distance too as I know what orientation I must be in to see it even when specked out and I can level out and fly back by timing it. (another example of knowing your plane)
coreman is offline Find More Posts by coreman
Old Sep 27, 2012, 03:30 PM
Closed Account
Joined Aug 2011
Old Sep 27, 2012, 03:39 PM
coreman is offline
Kit Manufacturer
coreman's Avatar
Joined Feb 2010
I've now seen that happen in a couple of ALES competitions when about 10 sailplanes are in the air close to each other but the spotter, if they are on their toes, usually see's that happening pretty and get everything back under control much to the embarassment of the pilot. Even world class guys can do this. Still, its funny to watch that few moments of panic and confusion when you aren't on the stick
yep, and if you aren't actively centering the plane, the edge of the thermal can boot you out (under just one wing). The easiest way to tell which is yours is to reverse the circle and see which one does it. If you do it right you can do a 360 into a figure 8 and get your thermal back. It's not as dramatic as hearing a plane got into the trees behind you and having an extra pilot still flying
Old Sep 27, 2012, 05:47 PM
Jovanx is offline
Find More Posts by Jovanx
Tossing planes into the snow
Canada, BC, Smithers
Joined Nov 2011
Originally Posted by rwelder View Post
It dove full power into the ground. Thankfully it didn't hurt anyone or anything else.
Why was the throttle on full when it hit the ground?
Jovanx is offline Find More Posts by Jovanx
Old Sep 27, 2012, 06:26 PM
kaptondave is offline
Find More Posts by kaptondave
Joined Jan 2010
.... one mistake I had to do twice in 2 years before before I learned was not to fly so high as to get near spec-out.
Not meaning this as a criticism because I realize that "spec-out" is following common usage in glider-speak but am wondering how it came to be that way. "Spec" is a term often used as a short for specification. When a plane gets far away it becomes a speck. Just curious.
kaptondave is offline Find More Posts by kaptondave
Old Sep 27, 2012, 06:44 PM
Jovanx is offline
Joined Nov 2011
Originally Posted by kaptondave View Post
Not meaning this as a criticism because I realize you are following common usage in glider-speak but am wondering how it came to be that way. "Spec" is a term often used as a short for specification. When a plane gets far away it becomes a speck. Just curious.
That is an example of one of the things that makes English challenging to learn as a second language. There are words that sound the same, but are spelled differently and have different meanings. Another example is "wood" and "would". I suppose if you really wanted to be specific, it could be argued that spec'd out was being used correctly. In that case it would not be the plane that was being pushed beyond specifications, but the eyes of the pilot instead.
Old Sep 27, 2012, 09:20 PM
JumpySticks is offline
Find More Posts by JumpySticks
Drifting off the reservation..
JumpySticks's Avatar
USA, LA, Broussard
Joined Jan 2011
Originally Posted by Gerry__ View Post
Climb rate does NOT increase into wind.
Rate of climb over distance does increase.
JumpySticks is offline Find More Posts by JumpySticks
Old Sep 27, 2012, 09:21 PM
cliffkot is offline
Find More Posts by cliffkot
cliffkot's Avatar
Joined Jun 2010
Unrelated to rweder's issue; one mistake I had to do twice in 2 years before before I learned was not to fly so high as to get near spec-out, getting distracted and looking away for a split second and unable to refocus on the plane ( near field myopia ) against a clear blue sky. I had a Graupner Elektro Rookie and a Radian, both with 808 cams and CAM ALES cutoffs, fly/soar away to never-neverland.
I know the feeling. I lost my Radian Sunday. She disappeared into a cloud that was far, far away. She is somewhere in the Land of Oz. I almost cried. It felt like I lost a child. It was a real bummer.
Cliff
cliffkot is offline Find More Posts by cliffkot
Old Sep 27, 2012, 09:23 PM
cliffkot is offline
cliffkot's Avatar
Joined Jun 2010
Rate of climb is measured in FPM, not distance.
Old Sep 27, 2012, 09:35 PM
USA, LA, Broussard
Joined Jan 2011
There are many types of rates in aeronautics. One is rate of climb over distance. It's most commonly used at airfields located in a box canyon.
A high rate of climb/distance is useful if you want to keep your glider close to the field, or a thermal, etc. It's not the most effective way to get the most altitude from a timed launch. Then you want to maximize rate of climb over time.
Old Sep 27, 2012, 10:02 PM
cliffkot is offline
cliffkot's Avatar
Joined Jun 2010
I would think that would have to factor in wind speed? For example, it the wind were a steady 20 knots, and you flew directly into it at a 20 knot climb speed, the plane would be going straight up ( in a relatively level attitude of course) like an elevator. Is that how it works?
Old Sep 28, 2012, 12:29 AM
Gerry__ is offline
Find More Posts by Gerry__
Bye Bye VP Aug 2010 - Aug 2012
Gerry__'s Avatar
United Kingdom, London
Joined Jan 2005
No. As cuff said, rate of climb is measured in feet per minute. You are confusing rate of climb with angle of climb.
Gerry__ is offline Find More Posts by Gerry__
Old Sep 28, 2012, 12:35 AM
Gerry__ is offline
Gerry__'s Avatar
Joined Jan 2005
Not correct. Taking off into wind, for example, the best climb rate does not change but the climb angle, and therefore the ability to clear ground obstacles, is increased.
Latest blog entry: Foamie Resurrection
Rave New Parkzone Radian Pro-discussion thread!!! lightspeeddud Electric Sailplanes 3813 Yesterday 07:52 AM
Gallery Parkzone Radian Pro Video bakon Electric Sailplanes 9 Sep 30, 2015 04:20 PM
Discussion Official Radian Pro Thread Magnumb Parkflyers 15 Aug 16, 2015 06:12 PM
New Product Parkzone Radian Pro bakon Electric Plane Talk 24 Oct 01, 2010 01:39 AM
Discussion Parkzone Radian Pro $229.99 BnF preorder Tekwip Hot Online Deals 10 Sep 29, 2010 04:35 PM
