United States, WA, Spokane
Joined Feb 2004
Damn plastic spinner broke apart today on a launch and ripped the front of the plane off. I inspect the spinner/blades on a daily basis, but there was no visible signs of impending danger.
Luckily it left the ESC and battery behind so I was able to kind of fly it in inverted and flip it back somewhat level before touchdown. Everything I've previously heard about it came from http://www.radian-pro.com/propeller. Going to the 10x8 prop sounds good, but I worry about burning up the motor or stock battery. My usual flying is full power climb for 30-45 seconds and then several minutes of gliding, but occasionally when the air is dead I just fly around at partial power. What kind of prop do ya'll think I can get away with? (I know, I really should get myself a watt meter) |
Joined Jan 2010
Everybody should have one. This is what I use:
http://www.hobbyking.com/hobbyking/s...dproduct=10080 |
I'm still evaluating the turnigy batteries. They are supposed to be 25-40 c rated, but they don't seem to have as much oomph as the stock ones. Maybe they just need to be broken in. They do not overheat with my larger prop like the stock parkzone batteries did. The overheating was my main concern. |
LI, New York, USA
Joined Mar 2003
The only things I advise is to darken the bottom of the wings for better visability. We hand toss (power off) and trim till it gliders nicely. Usually that means adding a quarter to the tail. When it glides out level from a hand toss then and only then do we power up and take it up. Then more trimming till it really glides nice. No other mods recommended unless they want to fly ALES contest with it. Then a prop change and replacement battery of 1300 to 1500 mah of 25C or higher to handle the higher amp load. After that they can play with it all they want, but at this point they have a nice flying glider that will let them enjoy thermal soaring, and they can fly in our ALES thermal soaring contests. That is all she needs. |
Joined Sep 2010
It's an electric R/C swiss army knife. Check www.progressiverc.com and www.epbuddy.com. Good people who will treat you right. Yes, HobbyKing sells these slightly cheaper. Buy from the good guys, they really are good guys. |
Joined Sep 2010
It's small and doesn't weigh much. Most of the weight is from copper in the Deans connectors and amp meter shunt.
It's a way to test props and motors in flight, rather than on a static test stand. If you also connect the battery balance leads, servo lead for your ESC and place a temp probe on the ESC it records flight pack voltage, current, power, ESC heat build up, throttle signal and individual cell (balance under load) during flight. It's possible to use an LED connected to the motor leads to trigger the optical tach sensor. |
Zor |
Cliff And while I'm on the subject of life testing. The labeled capacity rating of NiMh and NiCads are typically inflated by 20 to 25 percent. Duty life is also dependent on current drain. If you use them at a 1/20 capacity rate they will last a lot longer and reach an operating time close to what the capacity rating suggests. Also quick charging them easily takes half their life away. |
I buy in pairs and have been gentle with one and not the other, but can't really say if it makes any difference at all. Much better just to operate them within specs all the time. |
I don't know if Lipos have similar "break-in" properties, but I sure hope so, because my brand new 40c rated lipos do not seem to have the same oomph that the stock parkzone batteries had. The problem with the stock parkzone 25c rated batteries is that they had been overheating and puffing since switching to a larger prop setup. And yes, my lipo charger is very gentle, taking about an hour and a half to charge a 1300 ma lipo (and probably only 1/2 to 2/3 discharged). |
Running out of spec, this is what you'd expect to happen. |
Latest blog entry: Foamie Resurrection
| Thread Tools | |
| Rave New Parkzone Radian Pro-discussion thread!!! | lightspeeddud | Electric Sailplanes | 3624 | May 28, 2013 04:03 PM |
| Discussion Official Radian Pro Thread | Magnumb | Parkflyers | 14 | Apr 10, 2011 10:56 PM |
| Gallery Parkzone Radian Pro Video | bakon | Electric Sailplanes | 6 | Mar 11, 2011 05:21 PM |
| New Product Parkzone Radian Pro | bakon | Electric Plane Talk | 24 | Oct 01, 2010 01:39 AM |
| Discussion Parkzone Radian Pro $229.99 BnF preorder | Tekwip | Hot Online Deals | 10 | Sep 29, 2010 04:35 PM |
