Old Sep 20, 2012, 05:24 AM
jrjr is offline
Find More Posts by jrjr
Gravity impaired
jrjr's Avatar
United States, NY, Wolcott
Joined Nov 2004
Originally Posted by JumpySticks View Post
Try that with a stiff CF bird.
Try 200mph with a RP!
jrjr is offline Find More Posts by jrjr
Old Sep 20, 2012, 06:28 AM
Danny_l is offline
Find More Posts by Danny_l
Danny_l's Avatar
South Africa, WC, Cape Town
Joined Oct 2011
OK,
This is what I've done so far:
  • ESC brake set on soft braking - check (it was already set like that)
  • All control surfaces neutral - check.
  • Camber and Reflex progammed - check (flaps and aileron movement = 1 trailing edge thickness)
  • Crow programmed
With 1800Mah battery the CG is at 77mm. (no weight added anywhere)
The whole tail section is very flexible, so I think I should do at least the arrow and CF stiffening mods before flying again, but I'll not touch the Horizontal Stab incidence for now.
Any other suggestions?
Danny
Danny_l is offline Find More Posts by Danny_l
Old Sep 20, 2012, 07:05 AM
eagle1960 is offline
Find More Posts by eagle1960
United States, TN, Johnson City
Joined Jul 2011
Originally Posted by Danny_l View Post
OK,
  • Crow programmed
Danny
Not necessary. IMHO you should go out and see if you can resolve the gliding issues that I think you said was your big dissapoinment. Stiffening the fuse really won't change that.
eagle1960 is offline Find More Posts by eagle1960
Old Sep 20, 2012, 07:12 AM
Jovanx is offline
Find More Posts by Jovanx
Tossing planes into the snow
Canada, BC, Smithers
Joined Nov 2011
I am amazed that you could get it to balance at that location with an 1800 battery and no weight on the tail. I tried an 1800 once and the plane definitely moved faster and came down faster. I wouldn't want to use a battery that size unless it was really windy. If you can get your hands on a 1300 it will flatten the glide ratio and float much better. On mine, I had to set it to a hard brake to keep the prop from windmilling.
The next step is to set all surfaces to neutral and take it out on a calm day. Don't worry about what it does when under power, but just adjust the elevator trim so that it glides hands-free without porpoising. Doing the mods will make the controls more responsive, but they will not help with the high sink rate that you have been experiencing with the big battery.
Jumpy...
Yes it goes in where the FG was. You have to remove that FG "stiffener" and hold it in your hand to truly realize how useless it is. Then compare that to the arrow shaft, widen the slot to fit the arrow, glue and enjoy. I was tempted to remove the other 2, but the plane is nose-heavy anyway, so I left them there.
Jovanx is offline Find More Posts by Jovanx
Old Sep 20, 2012, 07:21 AM
Gerry__ is offline
Find More Posts by Gerry__
Bye Bye VP Aug 2010 - Aug 2012
Gerry__'s Avatar
United Kingdom, London
Joined Jan 2005
OK,
  • Crow programmed
Danny
Don't worry about it, it's not a 'must do' mod. Some people are over anxious with the fact that foam flexes.. The RP's natural state is to glide around as slowly as it can, without abrupt control inputs, occasionally darting off in a straight line towards areas of suspected lift.
Gerry__ is offline Find More Posts by Gerry__
Old Sep 20, 2012, 07:43 AM
Danny_l is offline
Danny_l's Avatar
Joined Oct 2011
Hi,
thanks for the responses.
Well, I'll leave it all as is and try it.
The upside of using arrows for stiffeners is that both my son and my wife are into archery so I have a steady supply of arrows that are no longer useful due to small cracks etc.
I'll also see if I can scrounge a smaller battery.
Brgds,
Danny
Old Sep 20, 2012, 08:06 AM
Jovanx is offline
Joined Nov 2011
I get a great deal of pleasure out of making things work a little better than they did out of the box. It is a simple matter of receiving a reward for some extra effort expended. I don't consider that to be an obsession. As the owners of these planes, we should feel free to modify or not modify them according to our personal desires, and not be judged by others for doing so.
Old Sep 20, 2012, 08:13 AM
Brian VT is offline
Find More Posts by Brian VT
Brian VT's Avatar
United States, VT, Rutland
Joined Dec 2011
Brian VT is offline Find More Posts by Brian VT
Old Sep 20, 2012, 08:47 AM
kaptondave is offline
Find More Posts by kaptondave
Joined Jan 2010
Adjusting elevator trim is ok as an interim fix but ultimately you should be flying with a neutral elevator, so shift the CG as needed to achieve the best glide. Some argue that "a little" elevator trim does not cause significant drag or other problem but i is a sloppy solution.
kaptondave is offline Find More Posts by kaptondave
Old Sep 20, 2012, 08:52 AM
Joined Jul 2011
Me too! I With an 1800 I am guessing I would be around 82mm, but that is with stiffening mods and 1 oz. of lead on the tail!
Old Sep 20, 2012, 09:10 AM
Jovanx is offline
Joined Nov 2011
What you say is true for sure. My instructions were just the first step in the process, to see if it would glide without porpoising. The next step is to move the CG so the trim is no longer necessary.
Old Sep 20, 2012, 09:22 AM
aeajr is offline
Find More Posts by aeajr
Proud member of LISF and ESL
LI, New York, USA
Joined Mar 2003
Attention all new Radian Pro buyers and those considering buying a Radian Pro.
ALL MODIFICATIONS ARE OPTIONAL
Many have said this in bits and pieces so let me consolidate. The RP, as a thermal duration glider, flies very well straight out of the box. No mods are required. A little adjustment of the CG toward the rear is highly recommended, but other than that, all mods are optional.
This is like a Ford Taurus. Comes off the showroom floor and drives you everywhere reliably every day. Now, if you want a little better handling you might switch to the super stickey X1000 tires. And if you want a little more pop coming from those red lights, just add the Whamo engine booster. And to anchor it better, put in the super slamo brake shoes. Now if you want a little better steering, swap out the steering rack for the Zapo steering rack and the difference will blow you away. And, if you pull that motor and drop in a Super screamer V8, well, now you have a car you can proudly drive to the super market.
Or you can drive it off the lot and enjoy it for 100,00 miles with regular maintenance.
The Radian Pro is the same. You do not NEED to modify anything except, perhaps, move the CG back a bit as part of your tuning process. But if you fly the stock Radian Pro, as a thermal duration glider, with the recommended 1300 mah battery or one of comparable size and shape, you are good to go.
If you just like to modify things, there are lots of suggestions in this thread. But they are not required.
ALL MODIFICATIONS ARE OPTIONAL! THE RADIAN PRO FLIES FINE RIGHT OUT OF THE BOX.
This has been brought to you as a public service announcement by the association to stop the confusion.
aeajr is offline Find More Posts by aeajr
Last edited by aeajr; Sep 20, 2012 at 09:42 AM. Reason: Added this phrase - as a thermal duration glider
Old Sep 20, 2012, 09:28 AM
ecase is offline
Find More Posts by ecase
Never enough time to fly!
ecase's Avatar
SLC, UT
Joined Sep 2006
Many have said this in bits and pieces so let me consolidate. The RP flies very well straight out of the box. No mods are required. A little adjustment of the CG toward the rear is highly recommended, but other than that, all mods are optional.
I couldn't have said it better myself. And with that I will go back to work.
ecase is offline Find More Posts by ecase
Old Sep 20, 2012, 09:34 AM
Woodstock 1 is offline
Find More Posts by Woodstock 1
Woodstock 1's Avatar
Ireland, County Kerry, Kerry
Joined Dec 2005
Absolutely. This should be printed and framed.
Chris
Woodstock 1 is offline Find More Posts by Woodstock 1
Old Sep 20, 2012, 09:38 AM
Joined Jul 2011
The Radian Pro is the same. You do not NEED to modify anything except, perhaps, move the CG back a bit as part of your tuning process. But if you fly the stock radian pro with the recommended 1300 mah battery or one of comparable size and shape, you are good to go.
Wish I had thought to do that!
Rave New Parkzone Radian Pro-discussion thread!!! lightspeeddud Electric Sailplanes 3861 Sep 11, 2016 09:06 AM
Gallery Parkzone Radian Pro Video bakon Electric Sailplanes 9 Sep 30, 2015 04:20 PM
Discussion Official Radian Pro Thread Magnumb Parkflyers 15 Aug 16, 2015 06:12 PM
New Product Parkzone Radian Pro bakon Electric Plane Talk 24 Oct 01, 2010 01:39 AM
Discussion Parkzone Radian Pro $229.99 BnF preorder Tekwip Hot Online Deals 10 Sep 29, 2010 04:35 PM
