Joined Jan 2010
http://www.goodwinds.com/merch/list....ultrudedcarbon |
Joined Aug 2011
I found this totally useless http://www.hobbyking.com/hobbyking/s...dProduct=13064 regardless of the db rating. I suspect that high frequency audio is absorbed by foliage more than low frequency - I'm guessing. In a corn field or forest I can't hear it 30 meters away when its sitting on the ground and there is just the chance with the plane upside down or pointing nose down the audio signal will be radiating away from you. I've had more success reving up the motor for a second to get a direction to walk "the walk of shame" up to a 100 meters in the bush. But none of this will work with a spec-out loss where you could be kilometers down range. So a couple of alternatives 1 - this is a $50 solution if you already have a UHF receiver or scanner http://www.rcgroups.com/forums/showthread.php?t=1274173 2 - this is a $100 solution if you are a ham http://www.byonics.com/mf and if you are a ham you would probably already have a VHF receiver ( HT ) to do RDF For about another $50 you can add a GPS and not only find your lost plane using GPS coordinates but also track successful flights and do Google Earth KML/KMZ 3D plots or APRS etc like this http://aprs.fi/#!mt=roadmap&z=11&cal...timerange=3600 You have to zoom in real tight to see the track. Of course you have to have this stuff installed BEFORE you loose your ride Take that from a 2 time losser of Radians . 2 in 2 years
Remaiden went OK, but the stabilization is set a little too high so it went up and down. Not sure why the video quality is so poor compared to my local copy. Hmmm.
I also didn't realize the sound was not working. Really this is just a test of the system to get familar before moving to a bigger plane with longer flight times. In the video at 5:47, I did realize I almost had a mid air with a TREX up high I didn't see up. Yikes! And I was flying with my eyes!
Either you had power on full time, or you should adjust the brake setting on your esc. Looks like the prop is freewheeling? If so, that's a lot of drag. |
Trial and Error.
It looks like you have to maintain a higher than normal airspeed to lift all that gear, so I would just adjust it upward until it stops spinning. Airspeed with the stock plane is around 16-20, and yours looks like its 25-30, so the prop never gets a chance to stop at motor cut off. I'm guessing you had flaps down toward the end of the video, so the airspeed is closer to 20 there, but the prop still does not stop. If you are using the stock esc, it has at least 6 or maybe 9 different settings and comes medium IIRC. |
| Thread Tools | |
| Rave New Parkzone Radian Pro-discussion thread!!! | lightspeeddud | Electric Sailplanes | 3620 | May 13, 2013 04:23 PM |
| Discussion Official Radian Pro Thread | Magnumb | Parkflyers | 14 | Apr 10, 2011 10:56 PM |
| Gallery Parkzone Radian Pro Video | bakon | Electric Sailplanes | 6 | Mar 11, 2011 05:21 PM |
| New Product Parkzone Radian Pro | bakon | Electric Plane Talk | 24 | Oct 01, 2010 01:39 AM |
| Discussion Parkzone Radian Pro $229.99 BnF preorder | Tekwip | Hot Online Deals | 10 | Sep 29, 2010 04:35 PM |
