Old Jul 20, 2012, 08:58 PM
sonny1 is offline
Find More Posts by sonny1
Kool Kats Fly RC!! AMA 30462
sonny1's Avatar
United States, CA, Baywood-Los Osos
Joined Feb 2009
I have 3 & 5 mil laminating film on hand that I use for ding-proofing my slope foamies, but it's really quite heavy. I've considered adding a strip of it to the leading edge, but a strip of packing tape would work just as well, (at less than half the weight). I think Paul Naton recommended packing tape on his mod site for "smoothiness".
Sonny
sonny1 is offline Find More Posts by sonny1
Old Jul 20, 2012, 09:53 PM
JumpySticks is offline
Find More Posts by JumpySticks
Drifting off the reservation..
JumpySticks's Avatar
USA, LA, Broussard
Joined Jan 2011
Monocote stick on trim film works great.
The chrome color reflects sunlight for a good "flash" for visibilty up high.
JumpySticks is offline Find More Posts by JumpySticks
Old Jul 20, 2012, 09:58 PM
Desert flier is offline
Find More Posts by Desert flier
Desert flier's Avatar
Australia, SA, Morphett Vale
Yea have the thin laminating film and have used it on a home made weasel with polystyrene wing and it diddnt melt the foam so I guess it should be right on the radian foam. Try and see I supose will realy stiffen and strengthen the wing heaps
Desert flier is offline Find More Posts by Desert flier
Old Jul 20, 2012, 09:59 PM
Zor is offline
Zor
Find More Posts by Zor
Zor
Ontario,Canada
Joined Feb 2007
Weight versus rate of descnet
I wish someone can correct me with explanations if I am wrong in what follows _ _ _
The manual states the weight is 34.6 oz.
My Radian pro weight ready to fly 39.05 oz.
That is an increase of 4.45 oz or 12.9 %
So the speed for the same lift will be 6.25 % more and consequently the rate of descent will increase just about by that percentage of 6.25%.
We might say it will fall like a brick .
I fail to understgand why many are so concerned with weight while ohers install a 5 to 7 oz rod in the wings.
Any tape on the leading edge is not going to do much to prevent nicks, recesses and broken tid bits. Any extra strength from the tape is not going to prevent or reduce flexing worth talking about.
It will not smooth out the air flow because the air separation takes place ahead of the leading edge.
I endorse smoothing the surface mainly for appearacnce and some small reduction in drag. A light transparent sticky tape can do that. Another way is to gently sand the surface with 400 grit and apply a coat or two of aircraft dope. Again a negligeable increase in weight.
Any correction to the above and showing what you know by experience is the proper way would be appreciated.
Zor
Zor is offline Find More Posts by Zor
Reply With Quote  (Disabled)
Old Jul 20, 2012, 10:11 PM
Zor is offline
Zor
Zor
Ontario,Canada
Joined Feb 2007
Sonny
Please put figures like grams or ounces of weight in your post so we can evaluate what you are talking about.
Naton was covering the whole model for smoothness not mainly for strength.
Zor
Old Jul 20, 2012, 11:03 PM
Jovanx is offline
Find More Posts by Jovanx
Tossing planes into the snow
Canada, BC, Smithers
Joined Nov 2011
When people put heavy rods in the wing, it is only temporary. It flies better on windy days, but it can be removed for calm weather or thermal soaring. I have a 3/8" full-length solid steel rod that weights 404 grams. That is a lot of weight to add to a plane that weighs between 900 and 1000 grams. I just tried it for a laugh to see how much extra weight the RP could carry. It takes a long time for the motor to get it up there but it flies very well. It looks like the glide angle is about the same, but it is moving much faster, and loses altitude faster.
A couple of weeks ago I got a Radian, and it's performance has exceeded my expectations. It is significantly lighter than a RP and it seems to stay up there forever. It climbs almost vertically with the same motor and prop. On the downside the wind blows it around a lot more, and it takes more room to land if there is no wind. What this amounts to (in my experience) is that when you add weight, the plane flies faster, cuts through the wind better, and lands sooner.
Jovanx is offline Find More Posts by Jovanx
Old Jul 21, 2012, 01:17 AM
Zor is offline
Zor
Zor
Ontario,Canada
Joined Feb 2007
Thanks for you post Jovanx
The nominal book figure of 34.6 Oz is 980.56 grams.
If we now add 404 grams we have a total of 1384.56 grams; an incease of 41 %.
The speed becomes 19 % higher and the rate of descent has increased by 19%.
The figures give us a much better idea of what is going on.
Of course the pilot may be playing with the elevators and at one moment nosing down and the next moment slightly climbing and soon stall.
The model will nose down on its own, gain speed and nose up again to repeat the process. That is not due to the airplane but it is induced by the pilot unable to judge the nose atitude of the model.
Many will blame the airplane when the reality is their piloting.
It appears to me that you and I have the same understanding. I wonder if we will see any posting disagreeing with us.
Zor
Old Jul 21, 2012, 02:41 AM
When it all boils down it is High weight = high wing loading wich will stall at a higher arispeed will use more power to get up but will penetreate better but at a cost.
I think it is better to build a plane to fly not to crash
my 2c
Old Jul 21, 2012, 02:54 AM
Watdazit is offline
Find More Posts by Watdazit
A geriatric flier
Watdazit's Avatar
Australia, NSW, Braidwood
Joined Nov 2008
whatdazit,............................
Also there was an error in mix 1 ....
It had .... Select GEAR > FLAP
It has to be ... Select AUX2 > FLAP
I have set up exactly as Chuckdseeker did in his video and he mentions an error in the original setup notes. His set up is different to your's above. I did the change as you suggested and all it did was change the operation of the Gear and Aux 2 switch and I still had the problem of the aileron not moving the same way as the flaps on Camber and Reflex and still moving in opposite direction in Crow. Got me stuffed but sitting here I think I should do one more thing. That is rebind just in case all the changes are not being read by the Rx. In the words of some actor with lots of muscles...I'll be back.
Watdazit is offline Find More Posts by Watdazit
Old Jul 21, 2012, 03:05 AM
Zor is offline
Zor
Zor
Ontario,Canada
Joined Feb 2007
my 2c
I fully agree with you.
I highlighted "but at a cost" above.
You did not explain at what cost.
The cost is "the speed".
You seem to think that weight makes airplanes crash.
The weight is not what makes airplanes crash.
Some airplanes weighing 700,000 lbs (seven hundred thousands pounds) 350 tons do fly and do not crash.
Zor
Editing
My finger slipped to the 6 instead of clicking the 3 .
I had 700,000 lbs as being 650 tons. It is obviously 350 tons.
Sorry I had not noticed it.
End
Old Jul 21, 2012, 03:10 AM
arcarius is offline
Find More Posts by arcarius
Troy Bowman
arcarius's Avatar
United States, UT, Woods Cross
Joined Sep 2011
I got a Radian Pro the other day. What a great easy way to get into gliding.
I must admit that this thread is daunting, and I haven't read it all. But I would like to share a bit of the fun I've had and experience I've gained over the last week.
My Radian Pro came with really warped ailerons. At first I thought I'd have to call Parkzone and complain and get a new wing, but I was able to warp it back to being straight using the low setting on my heat gun.
I thought it would be fun to have a tail cam on this glider, and an 808#16 (0.6oz or 17.5g) 720p HD keychain video camera seemed to fit the bill. I'll link to the videos I took with it below.
In the first flight with the camera on the tail, I completely forgot to check CG. I honestly didn't think 17g would make that big of a difference. Well, it makes a huge difference on the rudder. So, I had to stop and move the battery forward.
Parkzone Radian Pro Flight 1 Rudder-cam (13 min 47 sec)
Here's my second tailcam video.
Parkzone Radian Pro Flight 2 Rudder-cam (17 min 4 sec)
The third video was at a parking lot near my house. Because I had lost the micro SD card which contained the first two videos, I thought I had to start over. So, this video has another intro to the camera mount at the start. I also noticed my aileron was weird, so I had to fix it. On this cloudy day, I actually got some updrafts (dunno if you can call them thermals) and got a pretty decent 8 minute glide:
Parkzone Radian Pro Flight 3 Rudder-cam (26 min 49 sec)
The fourth video, you can see my daughter found the card and we're happy about it... But, the camera ran out of battery before I finished.
Parkzone Radian Pro Flight 4 Rudder-cam (12 min 1 sec)
At the end of flight 4, I had an accident as I was trying to catch the glider -- I accidentally hit the throttle! Had to get stitches -- nuff sed. So that leads me to my next video, my DX8 configuration with a new safety configuration.
Radian Pro DX8 Setup (11 min 33 sec)
And I'm attaching my DX8 configuration file if anyone wants what I've got going here...
arcarius is offline Find More Posts by arcarius
Old Jul 21, 2012, 08:05 AM
kaptondave is offline
Find More Posts by kaptondave
Joined Jan 2010
I groan when I see someone put up over an hour of video (wish everyone would edit them) but I did skim through the DX8 setup. I fly the RE Radian so can't do the full house tricks but the video helped me understand how it works. Thanks.
Sorry about the prop cut. Been there.
kaptondave is offline Find More Posts by kaptondave
Old Jul 21, 2012, 09:12 AM
dawsonh is offline
Find More Posts by dawsonh
Flagstaff, AZ
dawsonh's Avatar
USA, AZ, Flagstaff
Joined Mar 2003
Howdy ZOR:
We have been using laminating film on our light weight slope acrobats. We use it to cover the EPP wings and fuse. It has proven to be very durable. We mostly use the 1.7 mil and 3 mil thicknesses.
I weighed four square feet of material and got this result.
28 grams for the 3 mil
18 grams for the 1.7 mil
I have put a three inch "D Box" of the 1.7 mil on my Radian. It seems to do a nice job of protecting the LE from minor dings and road rash.
Regards,
Dawson
dawsonh is offline Find More Posts by dawsonh
Old Jul 21, 2012, 11:04 AM
Zor is offline
Zor
Zor
Ontario,Canada
Joined Feb 2007
Hello watdazit,
I may have some time later today to type the programming.
Note that we are talking about a DX7 and not a DX7s .
C U later.
Zor
Old Jul 21, 2012, 11:33 AM
Quasi_Mojo is offline
Find More Posts by Quasi_Mojo
Quasi_Mojo's Avatar
Canada, AB, Calgary
Joined Sep 2006
I picked up a couple of the 808 #16 keychain cams, as well. I really like your idea for the tail mount. I had wanted to set up a tail cam, but thought I would have to mount it to the side of the vert stab.
Wait a minute... your camera is mounted to the top of the rudder and the camera image is always facing forward - your rudder is not moving! Do you always fly with no rudder control?
I'm trying to figure out a reliable way of mounting my second #16 cam to glasses or the front of a ball cap, so I can film the plane hands-free.
Quasi_Mojo is offline Find More Posts by Quasi_Mojo
Rave New Parkzone Radian Pro-discussion thread!!! lightspeeddud Electric Sailplanes 3861 Sep 11, 2016 09:06 AM
Gallery Parkzone Radian Pro Video bakon Electric Sailplanes 9 Sep 30, 2015 04:20 PM
Discussion Official Radian Pro Thread Magnumb Parkflyers 15 Aug 16, 2015 06:12 PM
New Product Parkzone Radian Pro bakon Electric Plane Talk 24 Oct 01, 2010 01:39 AM
Discussion Parkzone Radian Pro $229.99 BnF preorder Tekwip Hot Online Deals 10 Sep 29, 2010 04:35 PM
