Old Jul 12, 2012, 01:23 PM
Gerry__ is offline
Find More Posts by Gerry__
Bye Bye VP Aug 2010 - Aug 2012
Gerry__'s Avatar
United Kingdom, London
Joined Jan 2005
Originally Posted by Rickochet View Post
...do not exceed any flap airspeed limitations.
Exactly. If your RP goes nuts when you chuck out the flaps, then you might want to consider a lower speed deployment.
The fact is that many RC pilots, across many different models, will deploy their flaps at too higher speed and then moan about the results like it's a fault with the design of the plane.
Gerry__ is offline Find More Posts by Gerry__
Latest blog entry: Eflite Gee Bee Racing
Old Jul 12, 2012, 02:32 PM
aeajr is online now
Find More Posts by aeajr
Proud member of LISF and ESL
LI, New York, USA
Joined Mar 2003
Concepts like VNE, velocity not to exceed, are unknown to most RC pilots
aeajr is online now Find More Posts by aeajr
Old Jul 12, 2012, 02:52 PM
Eastcoast78 is online now
Find More Posts by Eastcoast78
Dixie Normious
Eastcoast78's Avatar
Can A da....Ehh!!
Joined May 2010
Jov I agree, I should of made it more clearer.
Seems to becoming a pissing match lol
As for how much down elev you well need depends on the air speed you have
Kill some off and it well not balloon so much.
Cheers
Eastcoast78 is online now Find More Posts by Eastcoast78
Old Jul 12, 2012, 03:11 PM
aeajr is online now
LI, New York, USA
Joined Mar 2003
When setting up a flap to elevator mix we are usually talking about a landing mix.
Get plane up at least 100 feet so you have time to recover if something weird happens
Come to level flight at a speed that would approximate your landing approach speed. Deply flaps as you would on a landing approach, going to 100 % on your flap setting in the manner allowed by your radio and your mixing. For me the flaps are on the left stick so I can ease them in and out. Normally I do not go quickly from zero to 100 but bring them in over several seconds. And most of the time I do not use full flaps, but for this excercise we will go to full flaps.
Watch to see what happens in terms of pitch change. This is what you are trying to tune out. When you are done there should be little or now pitch change when you deploy flaps.
If you would rather start with some elevator mixed in, start with 20% done elevator to 100% down flap. Tune from there.
The actual amount you will want is unique to each pilot and each plane. I typically strive for a slighly nose down attitude to keep the plane flying. Otherwise you get a tendency to stall too easily.
Some people prefer to have less elevator comp and add the rest by hand. Some prefer to add more in the mix and then take it out from the stick according to their needs.
Your smileage will vary. to get it right may take 5-10 flights. Then you test it on landing to see if it behaves as you expect on an actual landing approach.
Now, if you want to use flaps to come down from high you do not dive to high speeds and then deploy flaps. That is how you exceed design speeds or overwhelm servos or flutter surfaces on a foam glider.
To use flaps to come down steeply you deploy flaps then turn nose down. The flaps keep you from picking up a lot of speed. On some gliders you can go 60 degrees and pick up very little speed. For most TD applications that is the proper use of flaps and the flap to elevator mix for glide path control and landing.
Note that I am not talking about F3B speed runs, pattern planes or hotliners. This is how they are typically used for a TD glider.
Old Jul 12, 2012, 06:18 PM
timography is offline
Find More Posts by timography
Electric Glider Nut
timography's Avatar
Australia, WA, Perth
Joined Feb 2012
yeah - what aeajr said...
timography is offline Find More Posts by timography
Old Jul 12, 2012, 06:40 PM
Zor is offline
Zor
Find More Posts by Zor
Zor
Ontario,Canada
Joined Feb 2007
Originally Posted by JumpySticks View Post
The DX7 programming is not very intuitive and I'm a little leery of messing up the good settings I have now.
Write on paper your present good settings then experiment.
You can always reset your present settings.
Another way is to copy your present settings to another memory and play with that one. The original memory will still be there.
Zor
Zor is offline Find More Posts by Zor
Reply With Quote  (Disabled)
Old Jul 12, 2012, 07:04 PM
Watdazit is offline
Find More Posts by Watdazit
A geriatric flier
Watdazit's Avatar
Australia, NSW, Braidwood
Joined Nov 2008
I have just taken delivery of my R Pro. I had a Radian for a couple of years and really enjoyed it but lost it in a cloud updraft.
I have to agree with guys who say the ability to put on and take off the wings for transport is a pain in the posterior. It would be nice to design a plug system on the ends of the wings so putting the wings on automatically plugged them in. I have noted in the forum one method of putting the Y harness connections into a cutout in the side of the fuselage under the wings. Do you glue the connections in place and connect the wires after the wings have been bolted on or do you hold the connections down and as you slide the wings onto the CF rod push the connection in? I am luck in that I can walk out of my back door and I have 600 acres to fly in so unless I take the RP to the club I would leave the wings on.
Watdazit is offline Find More Posts by Watdazit
Old Jul 12, 2012, 09:16 PM
JumpySticks is offline
Find More Posts by JumpySticks
Drifting off the reservation..
JumpySticks's Avatar
USA, LA, Broussard
Joined Jan 2011
Zor
Yeah, I could copy to another memory, but I'm too lazy to rebind the plane.
Maybe one of these days I'll try it.
Thanks!
JumpySticks is offline Find More Posts by JumpySticks
Old Jul 12, 2012, 09:26 PM
USA, LA, Broussard
Joined Jan 2011
Yeah, i leave my wings on. SUV is big enough to haul it thank goodness.
There are several methods folks have used to install connectors at the wing root, but I believe all of them discourage gluing them into the wing or fuselage. The wings flex at the joint and I believe someone had posted that pins break if you try to mount the plugs solid.
This website has a compilation of most of the mods for the RP, and the page I link has information about wing mounting methods.
Others who have actually done the mod will probably chime in here soon.
I would strongly recommend installing fairings over the wing servo. Same website has info about them. The aileron servos are particularly vulnerable to hanging on grass and stripping or jumping gears. The fairings solve the issue.
Check out that website for a list of most common modifications. I also have a short list on my blog, here.
Old Jul 13, 2012, 01:43 AM
allelectrik is offline
Find More Posts by allelectrik
Eugene, Oregon
Joined Feb 2011
My PNP arrived today.
Box and contents look ok.
Probably won't have a chance to put her together for a few days.
allelectrik is offline Find More Posts by allelectrik
Old Jul 13, 2012, 02:30 AM
eroeder is offline
Find More Posts by eroeder
eroeder's Avatar
United States, TX, Frisco
Joined Jan 2004
Great flight today as I get her dialed in. With the carbon spar, taill stiffing and being able to select full span ailerons, she was lzipping around looking almost like a hotliner. Fun fun!
eroeder is offline Find More Posts by eroeder
Old Jul 13, 2012, 10:32 AM
Flux Cobalt is offline
Find More Posts by Flux Cobalt
Joined Feb 2011
A new setup for me.
Well I have decided to take some advice from more experienced flyers here and I am going to put my RP throttle on a switch and move the flaps to the stick. I have been flying my RP for almost a year now and I love it. Currently I use a DX5e, Iím not into all that programming stuff. Anyway I put the throttle on the spring loaded trainer switch and the flaps on the throttle stick. It checks out great, now I just have to get used to flying with the different setup and wait to test fly it under this new setup. Thanks everyone for all of the great advice in the past.
Flux Cobalt is offline Find More Posts by Flux Cobalt
Old Jul 13, 2012, 12:42 PM
ddruck is offline
Find More Posts by ddruck
ddruck's Avatar
Canada, ON, Pickering
Joined Nov 2006
Just one minor advice, since you are going to on/off switch, I would reprogram the ESC to a softer start. The jolt of the instant start causes the prop hubs to crack around the pins due to undo stress (crashes are good for that also)
I see you hate programming but you only have to do it once and it does help.
ddruck is offline Find More Posts by ddruck
Old Jul 13, 2012, 12:51 PM
flycracker is offline
Find More Posts by flycracker
Rich
flycracker's Avatar
USA, SC, Lexington
Joined Sep 2001
Sudden full throttle launch on a RP. Dunno bout that. Perhaps some do.
flycracker is offline Find More Posts by flycracker
Old Jul 13, 2012, 01:30 PM
ddruck is offline
ddruck's Avatar
Joined Nov 2006
It is not a problem if it is setup, I launch mine full power all the time.
Rave New Parkzone Radian Pro-discussion thread!!! lightspeeddud Electric Sailplanes 3856 Jul 18, 2016 05:40 PM
Gallery Parkzone Radian Pro Video bakon Electric Sailplanes 9 Sep 30, 2015 04:20 PM
Discussion Official Radian Pro Thread Magnumb Parkflyers 15 Aug 16, 2015 06:12 PM
New Product Parkzone Radian Pro bakon Electric Plane Talk 24 Oct 01, 2010 01:39 AM
Discussion Parkzone Radian Pro $229.99 BnF preorder Tekwip Hot Online Deals 10 Sep 29, 2010 04:35 PM
