First I cover the entire bottom of the wing with black stick on trim film. IMHO it's the most visible color against the sky. Then I cut the chrome piece the length from the fuse to the polyhedral break. Then I split that piece to end up with a strip about 3" wide. I apply the strip starting at the top of the wing about an inch behind the leading edge, and then wrap it around the leading edge ending up on the bottom of the wing, overlapping the black bottom covering. I like having a slick leading edge and wing bottom. I think the smooth bottom and rough top on a wing adds a little lift. Just a personal theory. The chrome tape gives off a nice flash when the sun is out, helping me to locate and verify orientation of the plane at longer distances. I also use Monocote trim tape to cover the bottom of the fuse to lessen dinging. Chrome Stock Number: TOPQ4110 Black Stock Number: TOPQ4109 |
Disclaimer: Not responsible for burned flesh!!!!! |
this is why you should put your address in yur plane...
Eugene, Oregon
Joined Feb 2011
rcoconut
Which diameter BB spinner fits? The 480 shaft is 4mm. RP due to arrive Thursday. In the middle of moving, hopefully will be settled in enough to assemble and maiden next weekend. Graupner prop is backordered so the stock prop will have to make do for a while. |
Australia, NSW, Braidwood
Joined Nov 2008
http://www.solarfilm.co.uk/ |
I just finished a mod i found in this thread. It makes putting the RP together and taking it a park so much easier. only needed a knife and some hot glue. |
Looks good Coenraad. are you planning to put a black dot on the Negative side of the 2 plugs as a reminder which way to plug in. I dont know how many times ive plugged mine in, screwed wings in and powered up only to find i had a wire reversed.
I like the 6 pin plug mod so far i should of done it along time ago! mine don't look so neat as yours. So last night i added some more LEDS on the top of the wing. just enough to give me orientation when turning etc... |
You need to run the data through GPS Visualizer. That's a free website that converts raw data to nice looking KMZ files. Instructions in my blog. |
Do you use the flight battery or do you use a separate battery to run the lights? I'm also thinking of setting up the mutliplex plug system and using my old wings (with the keycam holes) with the lights. I want to keep a clean set of wings for thermal duration. Do you use the magnets or screws to hold the wings in? |
And love those leds on the tips. Thanks Jumpy. Think i'll need to buy some flowers for the wife and order the unit :P |
| Thread Tools | |
| Rave New Parkzone Radian Pro-discussion thread!!! | lightspeeddud | Electric Sailplanes | 3624 | May 28, 2013 04:03 PM |
| Discussion Official Radian Pro Thread | Magnumb | Parkflyers | 14 | Apr 10, 2011 10:56 PM |
| Gallery Parkzone Radian Pro Video | bakon | Electric Sailplanes | 6 | Mar 11, 2011 05:21 PM |
| New Product Parkzone Radian Pro | bakon | Electric Plane Talk | 24 | Oct 01, 2010 01:39 AM |
| Discussion Parkzone Radian Pro $229.99 BnF preorder | Tekwip | Hot Online Deals | 10 | Sep 29, 2010 04:35 PM |
