Old Jun 17, 2012, 05:33 PM
rcoconut is offline
Find More Posts by rcoconut
Do you see what I see?
rcoconut's Avatar
Rancho Cucamonga, CA
Joined Sep 2006
Man I forgot what it was like to fly the RP!! 2 GREAT flights with her this morning!! Not much convective activity so flights were under 15mins but she's still flying GREAT!! My original 1300mAh batt died today so flew with 1800mAh's. I've been away far too long that's for sure!! Happy Father's Day as well guys!!
rcoconut is offline Find More Posts by rcoconut
Old Jun 17, 2012, 05:41 PM
Nemesisuk is offline
Find More Posts by Nemesisuk
Joined May 2012
Maiden flight (or chuck and hope its setup right) or rp today and she flies really nicely. Great kit for floating around the skies at very little cost.
I used solar film to cover the kit (much more ridgid, looks better plus easy clean) and pushed some sharpend carbon rods into the tail for rigidity.
Nemesisuk is offline Find More Posts by Nemesisuk
Old Jun 17, 2012, 06:03 PM
JumpySticks is offline
Find More Posts by JumpySticks
Drifting off the reservation..
JumpySticks's Avatar
USA, LA, Broussard
Joined Jan 2011
Neat idea with the solar film.
JumpySticks is offline Find More Posts by JumpySticks
Old Jun 17, 2012, 06:09 PM
USA, LA, Broussard
Joined Jan 2011
I whacked a wing on a 2 foot high pipe rail yesterday. Leading edge is crumpled and the wing cracked from the flap all the way to the spar end plug. I have the old set of wings with the camera mounts I can use until I fix or replace.
There were strong ups and strong downs yesterday, and the winds were extremely variable.
I made a downwind, and then a crosswind leg, and on final found that I was in a downwind leg again due to a wind shift. It was too late, had lots of speed and not enough airspeed to turn, about 1 foot off the ground, and she just coasted straight into the railing that surrounds the parking lot. Booooonnnnggggg....snap.
Old Jun 17, 2012, 06:10 PM
eroeder is offline
Find More Posts by eroeder
eroeder's Avatar
United States, TX, Frisco
Joined Jan 2004
Working it back and forth it is loosening up. Of course, now I found out the the screw hole in the collet for nose cone was not drill out completely and tapped so I can secure the nose cone. Looks like the collet will need to be replaced by Espirit since I don't have the tools to fix. Ugh!
eroeder is offline Find More Posts by eroeder
Old Jun 17, 2012, 09:06 PM
Jimmitude is offline
Find More Posts by Jimmitude
United States, WI, Appleton
Joined Jul 2010
Jumpy, sorry to hear about your incident. I really like seeing your videos and hearing your flight reports! I'm sure you'll be up and flying in no time. When I can't fly (unfortunately, getting more commont) I really like seeing your posts.
dmohring, I'd suggest either crow, which as Jumpy showed works quite well, or increase your flap throw to 80-90 deg to see which you like better (remembver to mix in elevator comp.) BTW, Hooterville, NC!!?? That's where I grew up. Are you in a flying club? If so, which one?
Good flying, and good thermals
Jim
Jimmitude is offline Find More Posts by Jimmitude
Old Jun 17, 2012, 11:23 PM
devinvagt is offline
Find More Posts by devinvagt
United States, CA, Ukiah
Joined Jan 2011
looking for non-folding prop + spinner for radian pro
I've moved the motor in my radian pro to let me put a camera in the cockpit area, but I'm having trouble with the folding prop so I need to put in a standard prop and spinner. A 10/8 prop seems like the way to go but I don't know which brand of spinner will accept the hex nut on the radian prop shaft. Any help?
here's a picture, the zip tie is to keep the prop from folding!
prop shaft is 4mm diameter, hex nut is 10mm diameter, but I haven't been able to remove it.
devinvagt is offline Find More Posts by devinvagt
Old Jun 18, 2012, 03:21 AM
eroeder is offline
eroeder's Avatar
Joined Jan 2004
Just curious,
How much flex can this plane stand? Pulling out of a dive, boy do these wings flex. I thought the PZ F4U flexed, but boy this plane has it beat.
Old Jun 18, 2012, 06:35 AM
kaptondave is offline
Find More Posts by kaptondave
Joined Jan 2010
Your question is confusing, You say you need to use a standard prop and spinner but then ask about after-market spinners.
I use a Cermark spinner. It does not use the hex nut. It mounts to the shaft with a collet. I believe that other popular spinners like the BB are the same.
kaptondave is offline Find More Posts by kaptondave
Old Jun 18, 2012, 07:12 AM
moparherb is offline
Find More Posts by moparherb
Fly It Like You Stole It.....
moparherb's Avatar
United States, NY, Fulton
Joined Jan 2009
Why would you do that to a perfectly good aircraft?
moparherb is offline Find More Posts by moparherb
Old Jun 18, 2012, 08:32 AM
Joined Jan 2010
Because it was not perfect for his needs. If I wanted a stable camera platform with a a clear view forward it is a logical solution.
Do not put down other people's ideas just because they are different from yours.
Old Jun 18, 2012, 09:55 AM
Jovanx is offline
Find More Posts by Jovanx
Tossing planes into the snow
Canada, BC, Smithers
Joined Nov 2011
Originally Posted by eroeder View Post
Just curious,
Yes, both of these planes suffer from excessive wing flex. The solution for the RP is easy, just replace the stock FG spar with a CF spar. Done. There is lots of info on the Corsair thread about making curved aluminum spars, which is much more difficult.
Jovanx is offline Find More Posts by Jovanx
Old Jun 18, 2012, 11:09 AM
Joined Jan 2010
When I Google "solar film" it comes back with links to the film you use to tint windows and block UV. Is that what you use?
Old Jun 18, 2012, 11:17 AM
Joined Jan 2011
Thanks for the info.
by " standard " I mean non-folding style-- that was a little vague. I'm having trouble getting the hex piece off the shaft. Once I do, I assume I'm going to need a prop that will fit a 4mm shaft ?
Old Jun 18, 2012, 11:18 AM
Radio.Active is offline
Find More Posts by Radio.Active
Closed Account
Joined Aug 2011
Radio.Active is offline Find More Posts by Radio.Active
Rave New Parkzone Radian Pro-discussion thread!!! lightspeeddud Electric Sailplanes 3856 Jul 18, 2016 05:40 PM
Gallery Parkzone Radian Pro Video bakon Electric Sailplanes 9 Sep 30, 2015 04:20 PM
Discussion Official Radian Pro Thread Magnumb Parkflyers 15 Aug 16, 2015 06:12 PM
New Product Parkzone Radian Pro bakon Electric Plane Talk 24 Oct 01, 2010 01:39 AM
Discussion Parkzone Radian Pro $229.99 BnF preorder Tekwip Hot Online Deals 10 Sep 29, 2010 04:35 PM
