Old May 28, 2012, 07:28 AM
Kenny Sharp is offline
Find More Posts by Kenny Sharp
turn, turn, turn.
Athol, Massachusetts
Joined Oct 2005
Futaba is foreign to JR users.
I know it is to me.
Kenny Sharp is offline Find More Posts by Kenny Sharp
Old May 28, 2012, 07:33 AM
kaptondave is offline
Find More Posts by kaptondave
Joined Jan 2010
I am betting that aeajr is correct on the Futaba. The ESC will not arm because it thinks the throttle is wide open. Reverse Ch 3 and you should be ready to launch.
BTW, throttle trim has nothing to do with your problem. Leave it at neutral.
kaptondave is offline Find More Posts by kaptondave
Old May 28, 2012, 07:47 AM
turn, turn, turn.
Joined Oct 2005
Oh yeah ...Ed knows Futaba.
Old May 28, 2012, 10:26 AM
Quasi_Mojo is offline
Find More Posts by Quasi_Mojo
Quasi_Mojo's Avatar
Canada, AB, Calgary
Joined Sep 2006
I previously mentioned that I have already tried reversing Channel 3, to no avail. I have also tried ACRO mode, and got no loving from Channel 3, there, either. I have tried putting the motor on other Channels/switches and still got no response.
The manual shows that Channel 3 should work for the motor (see attachment).
I've got everything boxed up and will be dropping it off at LHS after work for them to look at and will post their findings.
Quasi_Mojo is offline Find More Posts by Quasi_Mojo
Old May 28, 2012, 11:05 AM
Radio.Active is offline
Find More Posts by Radio.Active
Closed Account
Joined Aug 2011
Radio.Active is offline Find More Posts by Radio.Active
Old May 28, 2012, 01:12 PM
jro0662 is offline
Find More Posts by jro0662
Closed Account
Joined Apr 2012
Wing from HH
Has anyone heard when the radian pro wing is supposed to be in stock? I've had a replacement wing on back order for a month now and haven't heard a thing about when its due out. An email i received from HH said "On back order till second week of may." Is this the norm for HH parts?
jro0662 is offline Find More Posts by jro0662
Old May 28, 2012, 01:48 PM
Jovanx is offline
Find More Posts by Jovanx
Tossing planes into the snow
Canada, BC, Smithers
Joined Nov 2011
Originally Posted by Eastcoast78 View Post
Planning a sunrise flight here tomorrow if the winds stay as forecasted
http://www.youtube.com/watch?v=MfrdSc0WerA
That would be absolutely awesome! The video was beautiful, with big waves and icebergs and the total blue everywhere. As I was watching it, I thought how exciting it would be to have a Radian Pro quietly eating up the scenery as it floated over the icebergs. What about those cliffs? Could you get some slope soaring happening? I wish I was there...
Jovanx is offline Find More Posts by Jovanx
Old May 28, 2012, 01:58 PM
Eastcoast78 is offline
Find More Posts by Eastcoast78
Dixie Normious
Eastcoast78's Avatar
Can A da....Ehh!!
Joined May 2010
Thanks, yea it is quite the spot. I was out there this AM at 5am, Got some nice footage of the sunrise, even had a Whale offshore. Heard him blowing, but only got a few glimpses of him
It was a bit cool just over freezing, and time the sun got up it was starting to become overcast and i lost interest in a flight.
Yes with the right, winds you can slope there for sure. I was watching gulls ride the slope while i was there and was sooooo temped!
I've been wanting to fly there for along time and it well happen ;0)
Eastcoast78 is offline Find More Posts by Eastcoast78
Old May 28, 2012, 04:01 PM
JumpySticks is offline
Find More Posts by JumpySticks
Drifting off the reservation..
JumpySticks's Avatar
USA, LA, Broussard
Joined Jan 2011
Yeah, i thought I had read that you tried reversing. Sorry I couldn't help. Hope the LHS figures it out for you.
JumpySticks is offline Find More Posts by JumpySticks
Old May 28, 2012, 06:00 PM
tony w is offline
Find More Posts by tony w
Flies Like Rock
United States, CO, Monument
Joined Jan 2005
now my ailerons are knobby!
Had some warped ailerons on my new Radian Pro, so I gently steamed the warped areas and held them until they cooled. Warps are gone, but the steamed areas of the ailerons and adjacent wing have little raised bumps. Is this much of a problem on a foam model like this? Is there any way to remove them?
Are any of you still flying wings with bumpy areas, or should I discard these and get new ones?
I thought I was pretty gentle with the heating, but I guess not.
Tony
tony w is offline Find More Posts by tony w
Old May 28, 2012, 06:04 PM
Dixie Normious
Can A da....Ehh!!
Joined May 2010
Some Pictures would be great! If it was to hot/close to the heat of the burner it well cause the foam to look more like snake scales?
maybe a good idea would be get the water boiling and remove form heat all together and let the steam warm the foam!
Also just laying the wing in the sun for 30mins would Prob do the trick
Old May 28, 2012, 06:13 PM
tony w is offline
Flies Like Rock
Joined Jan 2005
The areas I heated up look just like bumpy snake scales. I held it about 6 inches above a small pan of gently boiling water. I guess that was too much. Question is- should I get new wings?
Tony
Old May 28, 2012, 06:19 PM
Dixie Normious
Can A da....Ehh!!
Joined May 2010
Tony
Yea that would do it, At least 2ft away. Even when i did my freinds IconA5 at that distance i noticed it starting to. Thats why i think more then 2ft or the other optionof removering the water from the hot buner all together! Its not the heat form the steam that's doing it, its the heat rising around the pot form the burner.
I would imagine if the pot of steaming water was off the burner, you could get it close like 6'' with out worries.
As for replacing the wing, na!! Well you see the white snake skin effect from 500ft? I think not...
If it bothers you that much, i guess a new set would do! You could always get some colored packing tape and cover the outer 1/3 of the wing tips and make her more visible at Altitude
Its a win win situation.
Plus it may be hard to find a set of wings in stock?
Me personally i would not.
USA, LA, Broussard
Joined Jan 2011
I agree with eastcoast, try the sun first.
New wings are fairly cheap, but apparently on backorder. Guess lots of folks getting this plane.
Old May 28, 2012, 06:35 PM
Closed Account
Joined Aug 2011
Rave New Parkzone Radian Pro-discussion thread!!! lightspeeddud Electric Sailplanes 3861 Sep 11, 2016 09:06 AM
Gallery Parkzone Radian Pro Video bakon Electric Sailplanes 9 Sep 30, 2015 04:20 PM
Discussion Official Radian Pro Thread Magnumb Parkflyers 15 Aug 16, 2015 06:12 PM
New Product Parkzone Radian Pro bakon Electric Plane Talk 24 Oct 01, 2010 01:39 AM
Discussion Parkzone Radian Pro $229.99 BnF preorder Tekwip Hot Online Deals 10 Sep 29, 2010 04:35 PM
