Old Dec 16, 2010, 07:49 AM
kingsflyer is offline
Find More Posts by kingsflyer
We shall serve the Lord
kingsflyer's Avatar
United States, TX, Kingsland
Joined Sep 2005
Originally Posted by webdr View Post
Thanks for the links.
Does the graupner fold back well, or does it stick out in the airflow?
Matt
I don't have one in my hot little hands yet, but I understand the CAM series will fold back using the stock spinner.
McD
kingsflyer is offline Find More Posts by kingsflyer
Latest blog entry: LEDs on my T-28
Old Dec 16, 2010, 08:15 AM
Matt Gunn is offline
Find More Posts by Matt Gunn
RCGroups Editor
Matt Gunn's Avatar
United States, OH, Parma
Joined Jul 2009
McD
I think Ill pick one up, only for the reason that Im doing aerial photography and she could use a little more oomph with the added weight.
Matt Gunn is offline Find More Posts by Matt Gunn
Administrator
Old Dec 16, 2010, 08:19 AM
yellowcolorado is offline
Find More Posts by yellowcolorado
United States, LA, Metairie
Joined Feb 2009
If you click the link that says black outrunners and scroll down midpage, you will notice that these new motors sorta look like these sold by lightflyrc.com
http://www.lightflightrc.com/HTML/mo...outrunners.htm
yellowcolorado is offline Find More Posts by yellowcolorado
Old Dec 16, 2010, 10:04 AM
Eastcoast78 is offline
Find More Posts by Eastcoast78
Dixie Normious
Eastcoast78's Avatar
Can A da....Ehh!!
Joined May 2010
Nothing happens when i click the black out-runners like,Page refresh's and thats it.
Eastcoast78 is offline Find More Posts by Eastcoast78
Old Dec 16, 2010, 10:20 AM
ecase is offline
Find More Posts by ecase
Never enough time to fly!
ecase's Avatar
SLC, UT
Joined Sep 2006
My Radian Pro has a blue connector on the esc. Can anyone tell me what brand it is? I need to buy some to put on my batteries.
ecase is offline Find More Posts by ecase
Old Dec 16, 2010, 10:24 AM
RCGroups Editor
Matt Gunn's Avatar
Joined Jul 2009
im preyyt sure those are EC2 connectors
Administrator
Old Dec 16, 2010, 10:25 AM
Krazykayak75 is offline
Find More Posts by Krazykayak75
Holland MI
Joined Feb 2010
Originally Posted by Mr. Mike View Post
Hey KK, would you have a photo of of the 4 pin connector and how you did that, I would like to make assy/disassy of the wings easier, they are a pain.
mm
Here are the Picture you wanted of the 4 pin Dean connectors.
the right side is red and the left side is black.
each wire has different color heat shrink. this way match the colors and your done super super easy.
Krazykayak75 is offline Find More Posts by Krazykayak75
Fig Jam is offline
Find More Posts by Fig Jam
I am UNIQUE!
Fig Jam's Avatar
Kentucky
Joined Feb 2008
EC3 connector from Horizon.
Fig Jam is offline Find More Posts by Fig Jam
Old Dec 16, 2010, 10:56 AM
Mr. Mike is offline
Find More Posts by Mr. Mike
I don't giveup till it crashes
Mr. Mike's Avatar
Claremore, Ok.
Joined May 2007
Thanks KK, that's what I needed to know....
mm
Mr. Mike is offline Find More Posts by Mr. Mike
Old Dec 16, 2010, 11:06 AM
ecase is offline
ecase's Avatar
SLC, UT
Joined Sep 2006
This is likely a dumb question but, do you need a plug for each wing, or does one set connect both?
Also, is it tough to solder the wires to the plugs.
Old Dec 16, 2010, 11:14 AM
Holland MI
Joined Feb 2010
If you buy they come per pair... (one for wing and one for fuse in one bag) so I ordered a pair of red and one pair of black. From lhs. I didn't solder these as my skills suck but a buddy did and he made it look easy.
Old Dec 16, 2010, 11:33 AM
leosweers is offline
Find More Posts by leosweers
Toronto, Canada
Joined Jul 2003
They are EC3 Connectors
leosweers is offline Find More Posts by leosweers
Old Dec 16, 2010, 01:28 PM
boiko is offline
Find More Posts by boiko
Home of A-10 - Farmingdale NY
boiko's Avatar
United States, NH, Londonderry
Joined Dec 2006
Originally Posted by scb28 View Post
RE: motor issue. After reading some of the posts in this thread I tested my motor draw, it was a bit over 13amps. I then flew R Pro for the first time and was satified with the climb performance. Then I replaced the prop with an EMP 10x8 prop, the same prop I use on my good old Radian. The motor draw is now about 22amps and the R Pro climbs much better, just like my original Radian. I think the "motor" problem can be cured with a prop upgrade.
My 2cents, scb28
scb28,
I think you hit the nail on the head..
While there are people who can't get 12 Amps on their stock Radian Pro's...for them I think it might be a good idea to swap out their motors.
For all others...you might want to swap the prop to a Graupner 10x8..or as scb28 has found out. If you want to trade off a little more Amp draw, you might want to try the EMP Scimitar 10x8 - EMP is a bit of a thrust monster.
http://www.cermark.com/products/EMP-...ding-prop.html
-mike-
boiko is offline Find More Posts by boiko
Old Dec 16, 2010, 01:33 PM
RCLOCO is offline
Find More Posts by RCLOCO
Joined Dec 2010
Well I tried the prop off of my Radian on my pro and it pulls 1 more amp than the stock Radian pro prop does. 14.2A stock pro prop. Radian prop on Pro pulls 15.4amp. I think I will order a 10x8 and an 11x6 and give them a try. I have ran 4 packs thru my Pro and I like the climb rate it is not as good as the Radian but the Pro climbs to a speck in the sky in 40 seconds and a 30 second climb is high enough to look for lift for 5 min.
RCLOCO is offline Find More Posts by RCLOCO
Old Dec 16, 2010, 03:43 PM
tazmadman is offline
Find More Posts by tazmadman
Joined Mar 2009
can i just say lets move on from the motor issue everyone knows that a few have this issue if you have it contact HH and they will fix it easy but pages and pages of the same thing has made this a boring thread can we move on and post info on the glider
tazmadman is offline Find More Posts by tazmadman
Rave New Parkzone Radian Pro-discussion thread!!! lightspeeddud Electric Sailplanes 3856 Jul 18, 2016 05:40 PM
Gallery Parkzone Radian Pro Video bakon Electric Sailplanes 9 Sep 30, 2015 04:20 PM
Discussion Official Radian Pro Thread Magnumb Parkflyers 15 Aug 16, 2015 06:12 PM
New Product Parkzone Radian Pro bakon Electric Plane Talk 24 Oct 01, 2010 01:39 AM
Discussion Parkzone Radian Pro $229.99 BnF preorder Tekwip Hot Online Deals 10 Sep 29, 2010 04:35 PM
