Greg, An open switch prevents a circuit from operating. If the circuit is supposed to be preventing the throttle stick from energizing the motor, then this circuit has to be operating and it cannot do that if the circuit is open with an open switch. Your comments ? Zor |
I am honestly trying to understand your posting. At the upper right of the DX7 that I have there is 3 switches. Two on the front panel and one on top of the case. On the front panel the second switch from the edge is the AUX2 switch. The other one closer to the ege is the AILERON D/R switch. The one on top of the case is the MIX-RUDDER D/R switch. There is no other switch behind the rudder dual rate switch. I wonder if the DX7 has more than one model and if mine is different from yours. Zor |
@Zor:
The throttle hold switch is one of the first things you learn to operate if you are flying a heli. Because a heli has a lot more caution for spinning blades.If a crash or other calamity presents itself you have to be able to take out the throttle. Also electric heli's have a 80 or 100% flat throttle curve. So that's why this is mainly a heli-thing. I also fly gliders. I have all my throttles set on the throttle stick. And I am used to the throttle hold switch being the top right switch. Most North American, Canadian and European heli flyers are used to a mode 2 TX and have the Throtle Hold assigned to the top right switch and the top left is for the different flight modes (Normal, Stunt1 and Stunt2) Maybe I cleared up the issue now........
You are referring to "the top right switch" when there is on my DX7 3 switches at the top right like I explained in my post. I still do not see another switch behind the MIX-RUDDER D/R switch. Thanks for your post. Zor |
Agreed.
I think I explained myself pretty clearly and wanted to cover all three switches that I see on my DX7 that can be considered to be at top right in case it becomes mentioned that the front face only was implied. I am now disregarding the claim of a switch behind the MIX-RUDDER D/R switch. No use to perpetrate the issue. Good day all, I am hitting bed at 05:45 AM , Zor |
![]() ![]() BTW - I find it odd you guys are flying backwards ![]() Why do you need part throttle on a sail plane? You either want to go, or you dont. Put throttle on a sprung off switch, this is doable on a spektrum Tx's with a futaba sprung trainer switch stuck in the case. Leaves the throttle stick free for crow, also makes launching easier in the case of mode 2, as you can control throttle, elevator, and ailerons all with the one hand. I fly an A9, mode 2, throttle on the top RH sprung switch, crow on throttle stick, Reflex/camber on LH slider. Its logical , And to lock the throttle you just touch the screen ![]() My 2C, from someone who has some of the BEST toy plane/helicopter scar's in the business (well over 50 stitches...) , and still regularly plays catch the plane
Latest blog entry: Last great slope session of the summer?
C'mon, when a thread has a trillion posts like this one, everything is getting silly... |
Zor, I'm so sorry if my explanation messed you up, it was not my intention. I'm a heli guy who just so happens to also like flying gliders and airplanes. So to me throttle hold has ALWAYS been the furthest back switch on the right hand side. It usually has a slightly longer shaft. Now the story I related about the aircraft "dropping like a rock" was correct. I was flying an E-flite Advance, not my glider and it literally fell straight down when the throttle kill switch was accidentally hit. Don't do the throttle cutoff mix if you see no need for it. I personally do and that is why all my electric aircraft are programmed that way. I'm NOT trying to convince you that my way is better or the only way, just a different slant on saftey.
This "major flaw" does not happen with my mix setup. When the "throttle hold" switch is in the more forward position (meaning closer to the pilot) the electric motor will not operate. All other receiver function operate as normal. The motor is completely disabled using this mx setup. Now if you have a DX6I and cannot create this mix setup than I know of no way to disable the motor short of the deans wiring setup that you install in the aircraft. This is a commercial sold thing that is not expensive and works quite well. I don't know where you would install it on a RP.
I was wondering what this rubber band throttle method looks like to hold the throttle closed on a DX6i. A picture would be great.
As a much more experienced glow plane pilot, I noticed right away this live throttle on electric planes was a bit of a worry to me. I'm also a new helicopter pilot and I'm getting better with the throttle hold switch on the right side, but getting to that throttle cut button is wired. I was told the throttle cut was for glow engines, but I was always taught to cut throttle and throttle trim to shut the motor down. It is one area I always check and set-up on a glow plane first. |
| Thread Tools | |
| Rave New Parkzone Radian Pro-discussion thread!!! | lightspeeddud | Electric Sailplanes | 3620 | May 13, 2013 04:23 PM |
| Discussion Official Radian Pro Thread | Magnumb | Parkflyers | 14 | Apr 10, 2011 10:56 PM |
| Gallery Parkzone Radian Pro Video | bakon | Electric Sailplanes | 6 | Mar 11, 2011 05:21 PM |
| New Product Parkzone Radian Pro | bakon | Electric Plane Talk | 24 | Oct 01, 2010 01:39 AM |
| Discussion Parkzone Radian Pro $229.99 BnF preorder | Tekwip | Hot Online Deals | 10 | Sep 29, 2010 04:35 PM |
