Old Jan 16, 2012, 09:15 PM
EZCanuck is offline
Find More Posts by EZCanuck
Closed Account
Joined Aug 2010
EZCanuck is offline Find More Posts by EZCanuck
Old Jan 16, 2012, 09:18 PM
JumpySticks is offline
Find More Posts by JumpySticks
Drifting off the reservation..
JumpySticks's Avatar
USA, LA, Broussard
Joined Jan 2011
Originally Posted by moparherb View Post
Here is the mix settings so that you can use throttle hold switch to disable your electric motor on electric airplanes. I know this works on DX7, DX8 and JR 9303 and JR 9503. I can see no reason it would not work on DX6I but you will have to try it using a different mix:
I use mix 3
make it a THRO to THRO mix
POS 0 Should be 0% in both Positions
POS 1 make both settings -100% that is minus 100%
you do that by changing the position of throttle stick
Set Offset to -200 that is minus 200
make sure that "mix" is set to position 1
Leave THRO STK Inhibited (INH)
Now when you put the throttle hold switch in position 1 (toward you) the motor will be disabled. Hope this helps and if you have any questions please ask.
I have yet to make sense of the Spektrum mix syntax.
I have a DX7, and it does not have a throttle switch, but it does have a rudder mix switch, which I never use. Guess what I will do is use the current rudder mix and make that the throttle cut off mix as per your instruction.
Thanks!
JumpySticks is offline Find More Posts by JumpySticks
Old Jan 16, 2012, 09:27 PM
moparherb is offline
Find More Posts by moparherb
Fly It Like You Stole It.....
moparherb's Avatar
United States, NY, Fulton
Joined Jan 2009
The DX7 throttle hold switch is the two position switch in the upper right corner of he transmitter. Call it whatever you want, the name came from the heli guys, but it does the same thing no matter what you call it. This switch is usually behind the rudder dual rate switch.
moparherb is offline Find More Posts by moparherb
Old Jan 16, 2012, 09:36 PM
EZCanuck is offline
Closed Account
Joined Aug 2010
... deleted
Old Jan 16, 2012, 09:41 PM
Jovanx is offline
Find More Posts by Jovanx
Tossing planes into the snow
Canada, BC, Smithers
Joined Nov 2011
The DX6i also has that throttle hold switch, but it only works in heli mode. It also has a throttle-cut button that only works if you are pressing it. If that switch works in ACRO mode on the DX7, that is good news. It seems that everybody has their own solution to this obvious deficiency, and that indicates that the need is there.
Shame on you Spektrum and Futaba for thinking this feature is only of use to helicopter pilots. The picture shows my DX6i with the modified throttle-cut switch. The red button at lower left (if anybody is wondering ) is an "Enter" button to take the place of pressing down on the roller wheel.
Jovanx is offline Find More Posts by Jovanx
Old Jan 16, 2012, 09:44 PM
Zor is offline
Zor
Find More Posts by Zor
Zor
Ontario,Canada
Joined Feb 2007
Originally Posted by botulism View Post
Zor - there's a switch in there (switch B in this case) that's acting as a throttle cutoff switch. In one (switch) position, the throttle stick has no effect, it's 'off'. In the other (switch) position, the throttle actuates normally.
Greg
I read you Greg but you are not answering my question.
Zor
Zor is offline Find More Posts by Zor
Reply With Quote  (Disabled)
Old Jan 16, 2012, 10:11 PM
gdouglas is online now
Find More Posts by gdouglas
Camber down and screw it up.
gdouglas's Avatar
United States, MT, Kalispell
Joined Aug 2004
Zor
You're right, Zor. I didn't answer your question because I (mistakenly) assumed that you didn't know there was another switch in there.
OK, let's try it again.
So, why another switch ?
Zor
Because many people (myself included) have accidentally bumped the throttle stick, causing the motor (with attached propeller) to turn rapidly, possibly inflicting serious injury on humans, animals, plants, economy cars, or even furniture. If you have a switch in there, then it won't matter if you accidentally bump the throttle stick while, e.g. slinging the xmtr around your neck, or leaning over to pick up your Radian.
Did that answer your question, Zor?
Greg
gdouglas is online now Find More Posts by gdouglas
Old Jan 16, 2012, 10:16 PM
Jovanx is offline
Joined Nov 2011
EZCanuck,
Your post kind of puzzles me.
All I have to do is bring the throttle stick all the way toward me (down) and the motor stops being energized and the break comes on from the ESC.
So why another switch ?
Zor
I have the answer to your question Zor, or at least I think I do. This is only speculation. Maybe you are a bot, or a replicator, or a cylon. If that is the case, you never make mistakes. I, and most of the others on this post, are merely human, and sometimes we make mistakes. Sometimes we accidentally bump the throttle stick when we don't mean to. Sometimes we choose the wrong menu item when programming our transmitters. For us, having an extra level of protection is very helpful to prevent us from hurting ourselves or others.
Old Jan 16, 2012, 10:18 PM
Jovanx is offline
Joined Nov 2011
Hey botulism, I was typing up my reply to Zor at the same time you were. You beat me to the punch, and your answer is right on.
Old Jan 16, 2012, 10:26 PM
Eastcoast78 is online now
Find More Posts by Eastcoast78
Dixie Normious
Eastcoast78's Avatar
Can A da....Ehh!!
Joined May 2010
giddy up!!
Eastcoast78 is online now Find More Posts by Eastcoast78
Old Jan 16, 2012, 10:44 PM
gdouglas's Avatar
Joined Aug 2004
Originally Posted by Eastcoast78 View Post
giddy up!!
Yee-haw !!!
I got my hat.... on.
I got my boots... dusty.
I got my saddle... on my horse
He's called T-T-T-T-T-T-Trigger.
Of course.
Greg
Old Jan 17, 2012, 12:21 AM
Zor is offline
Zor
Zor
Ontario,Canada
Joined Feb 2007
Greg
Yes Greg, it fully answers why some of you guys wish to have more security in the form of a switch that disable the motor completely and prevents the throttle stick from accidentally putting the motor on.
Thanks to all respondent and for the explanation.
Zor
Old Jan 17, 2012, 11:01 AM
RTF Thumper is offline
Find More Posts by RTF Thumper
Big Jim
RTF Thumper's Avatar
United States, ID, Mountain Home
Joined Jun 2011
Nope not going to do it, no troll feeding for me.
RTF Thumper is offline Find More Posts by RTF Thumper
Old Jan 17, 2012, 11:22 AM
Patchitagain is offline
Find More Posts by Patchitagain
NE Texas, USA
Joined Jan 2011
Hello! Here's a first attempt at video from last week's flying at the field, so hopefully reviews won't be too harsh... It was a glorious evening, winds out of the west (in the direction of the sun), gusting to 10 at times.. Enjoy..
Here's the link:
Sunset Flying with RP.mp4 (16 min 32 sec)
Patchitagain is offline Find More Posts by Patchitagain
Old Jan 17, 2012, 11:49 AM
USA, LA, Broussard
Joined Jan 2011
Zor
Zor, do you happen to work for the Government?
Rave New Parkzone Radian Pro-discussion thread!!! lightspeeddud Electric Sailplanes 3853 Jun 07, 2016 12:56 PM
Gallery Parkzone Radian Pro Video bakon Electric Sailplanes 9 Sep 30, 2015 04:20 PM
Discussion Official Radian Pro Thread Magnumb Parkflyers 15 Aug 16, 2015 06:12 PM
New Product Parkzone Radian Pro bakon Electric Plane Talk 24 Oct 01, 2010 01:39 AM
Discussion Parkzone Radian Pro $229.99 BnF preorder Tekwip Hot Online Deals 10 Sep 29, 2010 04:35 PM
