Old Jan 14, 2012, 09:52 AM
Ruffnit4 is offline
Find More Posts by Ruffnit4
Ruffnit4's Avatar
Calgary AB
Joined Apr 2004
Originally Posted by bdshort View Post
I seem to have lost my wing mount screws, and can't find a replacement listed at Horizon. Can anyone tell me what size they are and where I might be able to buy replacements? Thanks!
Use DuBro #2126, 3mm x20 Socket Head Cap Screws,
Ruffnit4 is offline Find More Posts by Ruffnit4
Old Jan 14, 2012, 10:33 AM
bdshort is offline
Find More Posts by bdshort
United States, AK, Ketchikan
Joined Mar 2008
Excellent, thanks!
bdshort is offline Find More Posts by bdshort
Old Jan 14, 2012, 11:14 AM
Zor is offline
Zor
Find More Posts by Zor
Zor
Ontario,Canada
Joined Feb 2007
Originally Posted by Zor View Post
bdshort,
Poor you; we all have badlucks sometime.
But sometime we can get some reliable help.
The screws are 0.1175 inch dia that is 3 mm.
The length is 0.762 inch that is 19.3 mm.
The threaded lenght is 0.200 inch that is 5 mm
The proof is in the pictures.
Zor
I tried to help.
It was not good enough but I tried.
Zor
Zor is offline Find More Posts by Zor
Reply With Quote  (Disabled)
Old Jan 14, 2012, 11:28 AM
sonny1 is offline
Find More Posts by sonny1
Kool Kats Fly RC!! AMA 30462
sonny1's Avatar
United States, CA, Baywood-Los Osos
Joined Feb 2009
Found these at Esprit: http://www.espritmodel.com/bb-foldin...nt-screws.aspx. Right thread, and according to my measurements will work as RP wing screws.
Sonny
sonny1 is offline Find More Posts by sonny1
Old Jan 14, 2012, 01:32 PM
Zor is offline
Zor
Zor
Ontario,Canada
Joined Feb 2007
Sonny
It appears to me they are too short.
Did you see before that I measured the screws as being 19.3 mm long? and that the Dubro replacement screw has already been pointed out ?
Zor
Old Jan 14, 2012, 01:42 PM
rcoconut is online now
Find More Posts by rcoconut
Do you see what I see?
rcoconut's Avatar
Rancho Cucamonga, CA
Joined Sep 2006
Originally Posted by jackosmeister View Post
http://youtu.be/qk7nFtoo1I0
The old problem of which is the better plane is to be settled.
What the Assassin has in speed, maneuverability, and wind penetration... The radian makes up for in flexibility
Cool! I was scared just for a second for the RP!! That hand catch landing was nice!!
rcoconut is online now Find More Posts by rcoconut
Old Jan 14, 2012, 02:33 PM
sonny1 is offline
sonny1's Avatar
Joined Feb 2009
Zor
The screws on my BB Aluminum spinners are 19mm long, which means they will work on the RP's wing. I wouldn't have posted the link had that not been the case.
Sonny
Old Jan 14, 2012, 04:06 PM
Zor is offline
Zor
Zor
Ontario,Canada
Joined Feb 2007
Sonny
Thanks for that info sonny1.
I was judging by the look of the screws in the picture.
I did not find screw sizes else than the 2mm and 3 mm dia.
It still appears to me that if the screws in the pic are 3 mm dia they sure do not appear to be 19 mm long.
I thought that those screws in the pic were for holding the blades to the center piece that mounts on the motor shaft.
I imagine now that he will get the #2126 screws from Dubro.
Best regards and thanks from Zor.
Old Jan 14, 2012, 04:17 PM
Raften is offline
Find More Posts by Raften
NorCal
Joined Dec 2009
Good grief.
Raften is offline Find More Posts by Raften
Old Jan 14, 2012, 04:19 PM
overmyhead is online now
Find More Posts by overmyhead
United States, FL, Bradenton
Joined Jan 2012
Typical rookie first post:
Woops.. managed to park my Radian squarely into a telephone pole on the final approach and compound fractured the nose section with a full separation. The break is fairly clean but wondering what would be the best adhesive to use for this repair. Luckily the white cowling held most of the very front of the nose together including the motor cavity so there is basically the 2 main parts to rejoin.
Would gluing in a couple popsicle sticks fore and aft in the cockpit area add to the durability since it's a full break?
The rest of the plane amazingly survived intact except for the bent shaft on the motor since it was a direct hit and it took the brunt of the impact and got a replacement motor to install also.
overmyhead is online now Find More Posts by overmyhead
Old Jan 14, 2012, 04:27 PM
jackosmeister is offline
Find More Posts by jackosmeister
DroneWorlds - TEAM NEW ZEALAND
jackosmeister's Avatar
Auckland NZ
Joined Aug 2007
CA
My whole radian is held together with CA, just glue it back together.
It'll break somewhere else next time, just use more CA
jackosmeister is offline Find More Posts by jackosmeister
Old Jan 14, 2012, 05:48 PM
Zor is offline
Zor
Zor
Ontario,Canada
Joined Feb 2007
overmyhead,
Nice to see you here _ _ _ WELCOME .
Sorry about that telephone poll being at the wrong place.
Fortunately foam is easy to repair.
Check the fit of the break first then glue it.
I have been thinking of reinforcing the fuselage front of my Radian pro. It has not broken but one landing at too much of an angle has compressed the front by about 1/16 inch.
I had to trim the canopy front to fit nice again.
I thought of gluing in 3 lengths of carbon strips which I happen to have. One on each side and one on the bottom center.
Lolipop sticks would also be suitable.
Good luck with the repair.
Zor
Old Jan 14, 2012, 05:53 PM
Zor is offline
Zor
Zor
Ontario,Canada
Joined Feb 2007
Originally Posted by Raften View Post
Good grief.
Old Jan 14, 2012, 06:42 PM
Eastcoast78 is offline
Find More Posts by Eastcoast78
Dixie Normious
Eastcoast78's Avatar
Can A da....Ehh!!
Joined May 2010
Ca would work, but I like white gorilla glue, I recently had 2 crashes after a year of putting her through the paces
I like the this foam breaks and fits back together nicely
Check back a few pages of pics on her and you'll see my pics
It's kinda crzy but after my 2 repairs the forward section is alot stiffer, I can tell by watching the videos I've posted there is less vibrations
I don't think you need to reinforce it with anything
Gg is alot cheaper then ca and goes 4x as far.
Ca is brittle if you fly in a colder climate and yellows over time
Go to Wally world/ home depot/ michaels crafts etc and pick a bottle of the white gg read the directions and glue her back together.
My 2 cents...
Eastcoast78 is offline Find More Posts by Eastcoast78
Old Jan 14, 2012, 06:44 PM
Dixie Normious
Can A da....Ehh!!
Joined May 2010
Good grief.
Charlie brown... Lol
Rave New Parkzone Radian Pro-discussion thread!!! lightspeeddud Electric Sailplanes 3856 Jul 18, 2016 05:40 PM
Gallery Parkzone Radian Pro Video bakon Electric Sailplanes 9 Sep 30, 2015 04:20 PM
Discussion Official Radian Pro Thread Magnumb Parkflyers 15 Aug 16, 2015 06:12 PM
New Product Parkzone Radian Pro bakon Electric Plane Talk 24 Oct 01, 2010 01:39 AM
Discussion Parkzone Radian Pro $229.99 BnF preorder Tekwip Hot Online Deals 10 Sep 29, 2010 04:35 PM
