Old Jun 19, 2011, 07:03 PM
Raften is offline
Find More Posts by Raften
NorCal
Joined Dec 2009
Have heard that the battery needs to move foreward a bit. Try that and hand toss glides, no power. 25 to 30 % of the cord is a good place to start.
Raften is offline Find More Posts by Raften
Old Jun 19, 2011, 08:50 PM
JumpySticks is offline
Find More Posts by JumpySticks
Drifting off the reservation..
JumpySticks's Avatar
USA, LA, Broussard
Joined Jan 2011
Originally Posted by GoldCraft View Post
+1 on the 4s
If you plan to use bigger than 4s batteries in the future the 10s is great also...you can charge 2 batteries at once with it and you can get a refurb on for $99.
I ordered the 4s.
Still thinking about batteries.
Thanks to all for the help!
JumpySticks is offline Find More Posts by JumpySticks
Old Jun 20, 2011, 05:50 AM
HF_ATL is offline
Find More Posts by HF_ATL
Portugal
Joined Nov 2009
What do you guys recommend to strength the wings structure because of the extra weight I added to the radian pro? Steel rod instead of the stock rod?
Thanks!
HF_ATL is offline Find More Posts by HF_ATL
Old Jun 20, 2011, 05:56 AM
GoldCraft is offline
Find More Posts by GoldCraft
GoldCraft's Avatar
United States, GA, Woodstock
Joined Jan 2007
Thanks!
Stock should still be fine unless you are doing some crazy aerobatics in which case the outer portion of the wing would fail before the spar IMO. Just keep dont do crazy fast dives or turns and you should be fine.
GoldCraft is offline Find More Posts by GoldCraft
Old Jun 20, 2011, 06:02 AM
HF_ATL is offline
Portugal
Joined Nov 2009
Thanks for your quick reply.
I'm asking this because on the last saturday it was very windy and the wings flexed a lot! Added to the loads because of the strong winds, the added weight contributes to having a more delicate structure, thus my question...
Btw, I rarely do acrobatics with the pro, I use it for fpv.
Old Jun 20, 2011, 05:47 PM
GoldCraft's Avatar
Joined Jan 2007
Got a link to any of your flights....Im considering using mine for FPV too....right now I use and EZ*.
Old Jun 20, 2011, 08:14 PM
Mattvr1ck is offline
Find More Posts by Mattvr1ck
Australia, QLD, Brisbane
Joined Oct 2008
Anyone have the specs on the screws used to secure the wing? What length and thread? Thanks.
Mattvr1ck is offline Find More Posts by Mattvr1ck
Old Jun 20, 2011, 08:37 PM
mikeruth is offline
Find More Posts by mikeruth
The "Foaminator"
mikeruth's Avatar
Joined Mar 2007
quick search came up with this....
http://www.rcgroups.com/forums/showp...postcount=2164
MIke r
mikeruth is offline Find More Posts by mikeruth
Old Jun 20, 2011, 10:16 PM
USA, LA, Broussard
Joined Jan 2011
I have not heard anyone here say they folded a wing in flight....but then folks usually don't brag about that.
The wings are very flexible....it's disturbing sometime, but flex is a lot better than snap!
My weight with the contour camera and extra 4 ounces of lead in tail is about 42 ounces. I do moderate aerobatics with the camera installed....hasn't broken the wing yet.
That said, it's not fun to fly the rp in strong wind. Think about it, compared to a scale sailplane, the rp wings have a large chord in comparison to their span. It gets....really.....jumpy....
Old Jun 20, 2011, 10:45 PM
Raften is offline
NorCal
Joined Dec 2009
Someone once asked me how I get the wings to flap like that. It was a windy day.
Old Jun 20, 2011, 11:09 PM
kelloggair is offline
Find More Posts by kelloggair
kelloggair's Avatar
centennial/aurora colorado
Joined Mar 2008
only jumpy in turbulent wind, ive flown mine in 30 mph down here in nm. as long as its smooth its ok
kelloggair is offline Find More Posts by kelloggair
Old Jun 20, 2011, 11:18 PM
USA, LA, Broussard
Joined Jan 2011
Good point. We have so many trees down here...when it's windy it's usually turblent. Especially close to the ground where jumpy is not what you want.
Old Jun 21, 2011, 12:13 AM
RCRod is offline
Find More Posts by RCRod
Acacia II Lunar Lander
RCRod's Avatar
United States, CA, LADERA RANCH
Joined Feb 2011
I'd bet that it'd be pretty difficult to load the wings high enough to break them. I say this because I've actually seen one of my wings bent about 30 up at the tip - out past the spar.
The long story is that I was flying slope out over an 80-foot cliff at Crystal Cove State Park in southern California, and ended up losing the RP over the cliff edge on a landing approach. She got lodged in a crevasse about 30 feet down the cliff face, with the wing tips wedged perfectly perpendicular to the crack.
In my efforts to retrieve her, I tried fishing her out with a makeshift fishing pole made of bamboo and a noose fashioned out of electrical tape. I managed to hook her by the prop and started pulling. I must have had at least 20 pounds of tension on the noose, and the wing was getting tweaked something awful. I was certain I'd end up having to replace it.
I finally freed her by clambering down into the crevasse, and pulling her out by hand. A friendly passer-by fished me back up with the pole, while his girlfriend took pictures.
Now for the payoff to this overly long tale... The only damage sustained was a tiny thumbnail-sized notch torn out of one of the flaps. (I think the guy I handed her up to was more worried about getting me back up, and may have picked the RP up by the flap. It was an easy repair.) The wings have had about a dozen flights since, and you'd never guess one of them had been twisted up like a hockey stick at the end!
Moral of the story: really, really tough wings on that Pro.
RCRod is offline Find More Posts by RCRod
Old Jun 21, 2011, 03:07 AM
HF_ATL is offline
Portugal
Joined Nov 2009
Yes I have. I'll put it online asap...
Old Jun 21, 2011, 03:12 AM
HF_ATL is offline
Portugal
Joined Nov 2009
Thanks JumpySticks!
So for now I'll stick with stock wing rod and keep an eye in the structure strength.
Rave New Parkzone Radian Pro-discussion thread!!! lightspeeddud Electric Sailplanes 3861 Sep 11, 2016 09:06 AM
Gallery Parkzone Radian Pro Video bakon Electric Sailplanes 9 Sep 30, 2015 04:20 PM
Discussion Official Radian Pro Thread Magnumb Parkflyers 15 Aug 16, 2015 06:12 PM
New Product Parkzone Radian Pro bakon Electric Plane Talk 24 Oct 01, 2010 01:39 AM
Discussion Parkzone Radian Pro $229.99 BnF preorder Tekwip Hot Online Deals 10 Sep 29, 2010 04:35 PM
