![]() So, I'm guessing yours must have been one of the super early prototype Radian Pros then. Man, you must have mastered flying her over the last 21 years... ![]() For those who are totally lost with what I'm on about, watch the videos again and look in the very top left corner... Tee hee hee! Do you live in a household where the VCR is still blinking 00:00? Lol Dont worry, I'm only yanking your chain. Keep up the great videos, they are what keep this thread interesting since the bickering began. Hey, I got out after work today and the wind was surprisingly brisk on the hill where I have taken to flying. The flags were flying fully horizontal. Not wanting to be a wuss, up she went. Well, it was a different experience and somewhat unidirectional to say the least! 35 minutes of slope soaring followed by half a dozen lovely landings though. Circuit round downwind with more altitude than first seems necessary then drop in over the top of the hill with full crow and flaps deployed for nice hand catches (all except one slightly nose heavy cock up!). she really can come in steep without picking up any speed with a decent headwind. It's funny how bold you get with these things once you've realised that wind is not the enemy after all! |
LI, New York, USA
Joined Mar 2003
At 13 amps I would expect 6 minutes. This suggests you are running around 9 amps at full throttle. If you are running one of the props that tested out at 13 amps on the bench, that might actually be possible. If you are running a prop that pulls 16 amps, that seems surprising. |
LI, New York, USA
Joined Mar 2003
The original Radian pulls about 17-18 amps on the bench, probably about 14 or 15 in the air. I am quite confident that very few have changed the prop. The Radian Pro's original batch were pulling about 13 amps, or about 11 amps in the air. With the replacement prop from horizon hobby the reports were up to about 16 amps, which is probably about 13 to 14 in the air. Are there people who have over propped that motor to over 20 amps? Probably. Are there people who have replaced that motor? Probably. But most people who buy RTFs or Receiver Ready packages stay with the stock set-up. That is why they buy them that way. That is why I buy RTFs, BnF and RR packages. I don't want to do anything with them I don't have to. If I wanted to mess with them I would have gotten an ARF or a kit. |
Well ok, I guess that was an assumption made from reading posts about installing new props. I have never flown a Radian with its stock prop. The original 'exploding' prop issue got me in the habit of installing Aeronaut gear right out of the box.
My original Radian pulls right around 18-20 amps with a 10x7. The new Pro I set up with an 11x4. It only pulls 15-17 amps or so. The point was, as you noted, that 10 minutes of full throttle on 1300mah suggests 9 amps or less and that doesn't seem likely to me. But hey, maybe the stock setup does unload that much in the air. .........Mike |
Joined Feb 2011
I'm confident a lot comes down to flight style as well as I wasn't exactly doing loops the whole 10 minutes if you catch my drift. |
One day I'll add some music to my videos.....much better than just listening to the wind for sure. Some really good flying...and with a brand new plane? That's awesome. You're welcome on the GPS stuff. The geoid issue came up when the plots were starting 100 feet underground. Knew that wasn't right so had to look it up. My business involves using GIS mapping data, so I had to learn Autocad & Arcview for making the maps. The geoid issue is a downside of the cheap chinese logger. A full service GPS unit compensates automatically for geoid. The Canmore is bare bones...raw data. Luckily there is plenty of free software around to make the raw data useful. Not sure if you tried yet, but once you open your processed GPS plots in Google Earth, go to the menu under "Edit" "Show Elevation Profile" and up pops a chart of your flight with specs on max altitude, slope, speed, etc. Running your mouse over the chart displays more info about individual data points or a range of data points within the plot if you hold the left mouse button and drag it across the elevation profile. Makes it easier to get a precise time from motor cut off to landing. There is also a playback feature where a little arrow flies the path in real time so you can "refly" your flights. |
I've done quite a few flights now(40+). Best mod is ditching the wimpy 102 gram park 480 motor for a 3536 outrunner from headsuprc, also 102 grams. I made my own motor mount out of ply and glued it to the original trimmed plastic mount. I fly it on a rather windy slope, 10-30mph depending on the day. I use a 2200 3s battery. Without battery, it now weighs 900 grams
...tape, glue, extra carbon/fiber rod in the tail boom.This setup now allows me to comfortably penetrate the lower turbulent(rotor?) air on my less than ideal flying site, and enter the good lift zone for motor off soaring. I know this is not what the plane was designed for, but it works well and has been a great learning tool. I am now piecing one together that will have an aluminum motor mount from sotog(sold at headsuprc) and hopefully lighter reinforcments with less glue, tape and paint . thanksjz |
Wow
I just maidened my new Radian Pro. This is a great forum, and I've read it from posting #1 thru the latest. Obviously, there are +'s and -'s to the plane, but here is my perspective as a person moving from a 3-channel, heavy, underpowered electric sailplane to the Radian Pro.
WOW! I am using a DX8 and the Horizon Hobby Radian Pro program available at the Spektrum Community site. I haven't made any modifications to the HH program at this point. I have each aileron servo on its on channel. The wind was gusting 5 - 7 mph at ground level and was very turbulent. From about 50 feet on up, the wind was at least 10 - 15 mph. One step forward and a medium toss parallel to the ground, and it was easily airborne (my previous plane required me to run several steps and then to toss the plane as hard as I could). The plane easily and quickly climbed out at 30 - 40 degrees. I don't have an altimeter yet, but I am quite confident I could reach the magical 200 meters in 30 seconds. The plane required no trimming. It was very easy to control in the wind. It screamed past me when going down-wind and then penetrated slowly up-wind, but penetrate it did. Landing was fun! The wind was at right angles to our club landing strip, so I didn't have a lot of room to play with on my landing approaches. The plane was very controllable in the gusting wind, and the flaps allowed me to land in a very short distance (last week flying my other plane in similar winds, I got down to about 4 feet at the start of the landing strip and stayed that height for the entire length of the strip. My flight ended in a small pine tree at the end of the strip!). I tried the Crow function on one landing. With flaps and Crow, I am confident that I can gently land the plane pretty well where ever I want to. The only con I have seen so far is threading the wing servo wires into the plane. Per a suggestion somewhere into this forum, I used the unused aileron servo y-lead as an extension to the wing leads when threading them into the plane. I'm not comfortable with constantly plugging and unplugging the aileron servos into the receiver, so I will get a couple of 3 inch servo extensions to permanently attach to the receiver and then plug the aileron leads into them. I did several launches and multiple climb-outs and am anxious to see how many mAh I will need to put back into the battery. Again, I'm sure there are +'s and -'s to the plane, but it is definitely a HUGE move up for me. Now for a relatively calm day to see if I can find a thermal. Ray |
And of course..... the time stamp!!! Took me FOREVER to change it!! Apparently there's 17 ways to change the time stamp on those key chain cams and it figures that all three of my cameras took 17 tries!! So no more hot tub spa time warp on my videos! |
Thanks for the tip as far as "Show Elevation Profile". A few posts back I was wondering how you had all that slope and ascent/descent data. I'll mess with that next!! Does your business deal with aircraft avionics or Flight Management Computers? Just curious |
I too did the servo extensions versus plugging and unplugging the servos out of the receiver. But I did have to take it a step further and not only mark the flap and aileron male and female connectors but I had to make sure to match up the correct aileron connectors. During pre-flight before my 3rd flight I did the usual control check. All control surfaces moved as usual. Flaps deployed but when I selected crow my ailerons moved down instead of up. Hmmm??? I'm using the DX6i and I did NOT configure camber? Turns out I had the ailerons reversed. I noticed that the flap connectors can plug into either one but you have to have the ailerons plugged in accordingly other wise the crow configuration will not work, at least that's how mine is. |
No, aviation is a hobby. I deal with GIS mapping, so have some experience with locating things using GPS coordinates. Also lots of other computer experience with many different software packages combined to prepare reports & graphs. I had lots of trouble remembering to stop the timer at the end of a flight, so I was not getting an accurate record of flight duration. When I did get a time, I would forget to write it down. The GPS logger has solved that problem. On my blog page I'm assembling images to catalog some of the lesser known gps features of Google Earth. It's an amazing tool. |
Yes, lots to like about this plane. |
| Thread Tools | |
| Rave New Parkzone Radian Pro-discussion thread!!! | lightspeeddud | Electric Sailplanes | 3620 | May 13, 2013 04:23 PM |
| Discussion Official Radian Pro Thread | Magnumb | Parkflyers | 14 | Apr 10, 2011 10:56 PM |
| Gallery Parkzone Radian Pro Video | bakon | Electric Sailplanes | 6 | Mar 11, 2011 05:21 PM |
| New Product Parkzone Radian Pro | bakon | Electric Plane Talk | 24 | Oct 01, 2010 01:39 AM |
| Discussion Parkzone Radian Pro $229.99 BnF preorder | Tekwip | Hot Online Deals | 10 | Sep 29, 2010 04:35 PM |
