Rudder and Ailerons on same stick
I question your controls scheme as I believe most of us have conformed to a plan of ailerons and elevator on the right stick with throttle and rudder on the left. I then mix out throttle and have flaps and crow and rudder on the left stick.
just my preference maybe??? |
Brampton Ontario Canada
Originally Posted by aeajr Assuming there is no loss of contact with the receiver I would think the reason a Radian might now be able to pull out of a high speed dive would be: * Servo not strong enough to overcome the pressure on the elevator * Linkage is flexing under the heavy load trying to move teh elevator against the pressure on the elevator * Servo arm has stripped under the high pressure so the servo moves but the surface does not. * Control rod connection failed so the rod is not moving the elevator. I guess you could stall the elevator, but that is something I don't know how to test. But these are items I can check. Quote:
and very flexible. In a sustained dive the whole wing is likely twisting to a negative angle of attack and causing it to want to tuck. I don't own one but I am impressed that it did not flutter itself into confetti during a 400 ft dive. Doug |
I'm sorry but I remain convinced these 'tail stall' scenarios are fantasy extrapolated from the notion that the elevator 'levers' the tail through all 90 degrees of a pullout. It does not. The elevator pushes the tail down a few degrees, STOPS and HOLDS it there. It is not continuously pushing the tail down, it simply sets the main wing to a different angle of attack to the airflow. The lift of the main wing is what pulls the airplane into a curving flight path. The elevator is not gonna lose all its 'push' on the tail until it's deflected 90 degrees to the airflow, if then. I doubt anyone has elevator throw set anywhere close to 'airbrake'. The stab is not gonna 'generate lift' until the deflected elevator forces it to assume an angle of attack with the airflow. That's how the elevator works. .........Mike |
With something foamy and a bit floppy, I don't think ANY of these aerodynamic explanations are relevant. It just flutters and distorts when flown outside of it's design speed.
Latest blog entry: Last great slope session of the summer?
Highlands Ranch, CO
Joined Dec 2007
USA, CO, Frederick
Joined Jan 2011
i'm agreeing with MS in NY... i don't think the dives are tail stalls.
. i think we are looking at brownouts, electronic malfunction (moisture), or weather/lift/sink. . i was at a hand launch competiton this weekend with the competition-class pilots and very expensive, top-of-the-line competition DLG's. At one point (i didn't gete to see it - just told of it), all were in a downwind thermal and had to get back because of the timed task. all but one flew directly back upwind. the other flew out at a 45degree angle. all the others went straight down to the ground. one of the pilots described his glider as ignoring any elevator inputs and going straight down - even curving back in towards the thermal at the bottom. (sound familiar?). the pilot that flew out at 45 degrees is the only one that was able to return to the landing area. he explained that the area just upwind of a thermal is very strong sink, so one should always try and fly out of a thermal at 45 degrees to the prevailing wind. AHA! |
| Thread Tools | |
| Rave New Parkzone Radian Pro-discussion thread!!! | lightspeeddud | Electric Sailplanes | 3620 | May 13, 2013 04:23 PM |
| Discussion Official Radian Pro Thread | Magnumb | Parkflyers | 14 | Apr 10, 2011 10:56 PM |
| Gallery Parkzone Radian Pro Video | bakon | Electric Sailplanes | 6 | Mar 11, 2011 05:21 PM |
| New Product Parkzone Radian Pro | bakon | Electric Plane Talk | 24 | Oct 01, 2010 01:39 AM |
| Discussion Parkzone Radian Pro $229.99 BnF preorder | Tekwip | Hot Online Deals | 10 | Sep 29, 2010 04:35 PM |
