Old Nov 17, 2010, 01:06 AM
NiceOh is offline
Find More Posts by NiceOh
Joined Nov 2010
Help!
How can use switch Turnigy 9X(FW. ER9x) in Simulator
Hello.
I have a Turnigy 9X TX v2. and I was upgraded firmware, ER9x.
I have some problem in Realflight G4.5.
I can use a nomal 4ch plane in simulator.
I can use a Throttle Cut switch {It was same real RC(Durafly Cessna 182) setting.}
But, I can't use a Flap and Gear switches my Tx.
(This mean, I use Flap my Real RC set ch6, but just it can't use simulater)
I think, it's need a setting something...
I was changed some plane setting to (Pass Though).
How can I use a switches.
Please, help me a setting knowhow (Transmitter and Simulator.) step by step
Thank you.
NiceOh is offline Find More Posts by NiceOh
Old Nov 19, 2010, 03:38 AM
Malc C is offline
Find More Posts by Malc C
UK
Joined Oct 2003
I don't own that sim, but it could be that the interface will only recognise the first 5 channels (four gymbals and a switch) and the transmitter is sending the flap and gear as 6th and 7th channel, which isn't read. ??
Can you see the channels in any calibration screens and do they move when you activate the switches
Malc C is offline Find More Posts by Malc C
Old Nov 23, 2010, 05:13 AM
solentlife is offline
Find More Posts by solentlife
222 km/hr Parkjet flyer
solentlife's Avatar
Latvia, Ventspils pilsēta, Ventspils
Joined Jan 2010
Some sims will not see the 'extra' ch's when Module is unplugged from Tx. This is a problem not of the Tx but of the Sim. You have to trial and see which does and which doesn't.
With RCPlanemaster - I get aux's ch's with module in, take it out and I lose ch's 5 and up.
HeliSimRC doesn't care
FMS ... that crashes anyway !
Oh and before anyone shouts ... you MUST take out module to stop Transmitting signal - rubbish. The trainer / DSC socket specifically on most radios disconnects RF signal ... Don't believe ? Then try this :
Plug in radio to PC ... it should come on without need to switch on. Now switch on model taking care of course ... any joy ? Didn't think so. Now switch on Tx and still zero ... now unplug cable ... Oh NOW you have life. BUT be warned - plugging cable back in now will NOT stop RF ... only switching of Tx switch will ... and then cable keeps radio on to work PC.
solentlife is offline Find More Posts by solentlife
Old May 21, 2011, 10:51 AM
Mavni is offline
Find More Posts by Mavni
Joined Nov 2010
I have the same problem,
Only if I go in "Display" in the menu, I see no switch movement
Is that normal?
This happens even if i turn my Rx on normally
Mavni is offline Find More Posts by Mavni
Discussion Turnigy 9x can't figure out flapperon Gigaah Radios 16 Mar 03, 2014 11:19 PM
Discussion How can convert simcable E-sky to turnigy 9x(JR port) NiceOh DIY Electronics 4 Nov 17, 2010 12:31 AM
Help! How can I to convert simcable E-sky to turnigy 9x? NiceOh Radios 0 Nov 15, 2010 05:58 AM
Help! Can't get my Turnigy 9X to work with Phoenix agent1940 Simulators 1 Oct 22, 2010 01:42 AM
Discussion How to use TH9x (Turnigy 9x, etc) with DX6 in trainer mode? polar8 Radios 7 Oct 19, 2010 03:04 AM
