Old Feb 14, 2013, 02:06 AM
killercando is online now
Find More Posts by killercando
Certifiable User
killercando's Avatar
United States, WA, North Bend
Joined Mar 2011
Just count how many fibers the strand is made of(squint) then divide by 1000 and add a K at the end. Hey we have soe real nice stuff here from Soller composites that comes in a plane weave 5.8oz fabric it is 12k tow spread to about 11mm it is supe flat and easy to work with. I been lovin it
killercando is online now Find More Posts by killercando
Old Feb 14, 2013, 02:20 PM
Fubar 123 is offline
Find More Posts by Fubar 123
Fubar 123's Avatar
Whitchurch,Shropshire. UK
Joined Jul 2008
Hi Jim,
Just wondering if you have taken a look at those molds yet ?
Fingers crossed
Chris
Fubar 123 is offline Find More Posts by Fubar 123
Old Feb 14, 2013, 05:35 PM
Jim.Thompson is offline
Find More Posts by Jim.Thompson
Entropy is happening!
Jim.Thompson's Avatar
Australia, NSW, Bellingen
Joined Aug 2008
Originally Posted by Fubar 123 View Post
Hi Jim,
Fingers crossed
Chris
Chris,
Not yet, I'm playing a patient game (with myself!).
Also, I have had plenty to do and I've got the first half of the wing mould well and truly started. I expect to finish the layup of this first side tonight and will be welding up the backing frames this afternoon.
The grass is well and truly wet, so I will have no fire risk like the last time I welded!
Lee,
I am envious of your ease of local supply from Soller. I have some of their very fine socking (biaxial sleeving), which I use for drag and control surface spars. The product is cheap, but the postage to us here is exorbitant!
Good products they have!
Jim.
Jim.Thompson is offline Find More Posts by Jim.Thompson
Old Feb 14, 2013, 06:14 PM
josh18 is offline
Find More Posts by josh18
608 km/h!
josh18's Avatar
Australia, QLD, Toowoomba
Joined Jan 2010
Jim I have bought carbon sock from CG composites in ?Sydney? before and they were cheap and quick. They didnt have the range of soller but you only really need a few sizes as it stretches up or down so much. Give them a go next time- I have a feeling they are the only place to get it in australia but am probably wrong. Good luck with your plug releases!
josh18 is offline Find More Posts by josh18
Old Feb 14, 2013, 09:46 PM
Joined Aug 2008
Excellent Josh, I'm glad to know that.
Tomorrow is tail mould split day!
Watch this space, as the saying goes.
Old Feb 15, 2013, 11:24 AM
Fubar 123's Avatar
Joined Jul 2008
Watching....
Old Feb 15, 2013, 03:15 PM
Joined Aug 2008
The first half of the wing mould is no layed up.
1 layer of veil
1 layer of 80 gsm glass cloth PW
8 layers of 295 gsm glass cloth 4HS.
I will be doing the steel work this afternoon. Also, de-moulding tail moulds as I said before!
I've got more resin and the heavy glass being delivered early next week to complete the second side. Once I have bonded the steel frame to the back, I will add a couple more layers of the heavy glass between the steel. That will bring the laminate thickness up to 5 mm. It is 4.5 mm thick now.
Old Feb 15, 2013, 10:03 PM
Joined Aug 2008
Good release!
Watching....
Here it is Chris:
Wompoo tail moulds (3 min 35 sec)
My very first video upload too!
The moulds are fine except for a very small bit of damage on the TE on one side of one of them. I don't know if I remembered to put some carbon tow in there or not. I think not. That would have reinforced it.
I'm pleased, to say the least.
Last edited by Jim.Thompson; Feb 15, 2013 at 10:04 PM. Reason: additional information.
Old Feb 16, 2013, 12:53 AM
josh18 is offline
608 km/h!
josh18's Avatar
Joined Jan 2010
well done Jim!
Old Feb 16, 2013, 01:22 AM
timbuck is offline
Find More Posts by timbuck
Nothing is easy
timbuck's Avatar
gold coast australia
Joined Aug 2008
Always good to hear that CRACK..
Tim
timbuck is offline Find More Posts by timbuck
Latest blog entry: More colours
Old Feb 16, 2013, 03:27 AM
Fubar 123's Avatar
Joined Jul 2008
Originally Posted by Jim.Thompson View Post
Here it is Chris: https://vimeo.com/59776567
Well Done Jim,
What a sweet release !
Thanks for making the effort to make a film far better than 20 photos ! Keep them coming
Old Feb 16, 2013, 04:33 AM
Joined Aug 2008
Thanks guys!
Like Tim say, that "crack" sound is sure welcome.
Old Feb 19, 2013, 03:41 AM
Joined Aug 2008
First side wing moulds.
I've now finished the first side of the wing moulds.
The pictures pretty well tell it all.
I'll be removing the parting board tomorrow and waxing up the second side.
edit: I used 2 mm wall thickness primed RHS this time. Much easier to weld than the galvo thinner walled (1.6mm) material.
Old Feb 21, 2013, 09:23 PM
Joined Aug 2008
Flooding rains again!
We have very heavy rain here with moderate local flooding. Forecast to last the best part of another week. Half the east coast is flooding, while parts of the south of the country is still burning!
It's too wet to do any composite work. So, when there is a slight moderation in the downpour, I plan to prepare the threaded rod and 20x20mm RHS clamps to clamp the moulds together. There will be no through bolts on any of these moulds.
I'm copying the set up first described (to my knowledge), by WWW Adam.
Instead of nuts, I will make up some large wing nuts for speed of assembly and dissembly. This is a particular advantage in the case of the fuse mould and inflation bladder assembly. In the event of a burst inflation bladder, it is important to be able to strip and re-assembly the mould/layup quickly. I'm over the fuss and bother of picking up and dealing with bolts and power drivers with sticky epoxy covered gloves. Besides, with repeated use, the moulds with through bolts will suffer some distortion around the bolts.
The specially made clamps can be positioned in new places each use if there is any sign of fatigue or distortion. Besides, this fuse mould is massively supported with double steel framed runners. They had to be double for the clamps to clear the protruding wing fillets.
If I am to build another low wing, or mid wing model, I will be using very minimal fillets, as is done on most commercial model that I've seen lately. These large radius fillets were more of an aesthetic design fancy that I had at the time. Made a bit of a rod for my back though!
Old Feb 21, 2013, 09:49 PM
flyonline is offline
Find More Posts by flyonline
Twisted and Confused
flyonline's Avatar
Joined May 2003
4 Made a bit of a rod for my back though!
At least it keeps your posture good
Keep up the good work, though we could do with some of the rain down this way - very, very dry!
flyonline is offline Find More Posts by flyonline
Build Log Astro Flight Super Monterey: Build Log! hugofly Sailplane Talk 93 Jan 29, 2016 01:59 AM
New Product Nanoshark ARF- Build Log - High Performance Depron Airplane NanoDave Foamies (Kits) 143 Sep 08, 2015 09:29 AM
Question "Modular" EasyStar build... (And log). Incendium Foamies (Kits) 38 Nov 30, 2010 08:13 PM
Build Log Dumas Eindecker build log? mcjustis Scratchbuilt Indoor and Micro Models 17 Nov 26, 2010 09:04 PM
Build Log Slo-mo-shun build log on Scale Boats JeremyBB Racing Boats - Electric 3 Nov 04, 2010 08:18 PM
