Old Nov 26, 2012, 10:57 PM
Jim.Thompson is offline
Find More Posts by Jim.Thompson
Entropy is happening!
Jim.Thompson's Avatar
Australia, NSW, Bellingen
Joined Aug 2008
Originally Posted by AUSELECTRIC View Post
That shed need a build thread of it own
I think we should all gang up and pressure Steve into posting one!
Jim.Thompson is offline Find More Posts by Jim.Thompson
Old Nov 27, 2012, 01:09 AM
flyonline is offline
Find More Posts by flyonline
Twisted and Confused
flyonline's Avatar
Joined May 2003
It might take a while to get finished, but I'll give it a go
flyonline is offline Find More Posts by flyonline
Old Dec 01, 2012, 11:24 PM
Joined Aug 2008
Wing roots fitted.
I have splooge filled and block sanded the roots of both fuselage and wings to provide a good fit. I used a .005 inch feeler guage to do the last sanding/filling. The final adjustment to the mating surfaces can be done with the primer/filler.
I've also started to shape the tapered cone and former for the pressure hose at the tail end of the fuselage. This tapered section is to support the aft end of the bladder where it is collapsed and crunched up on the hose. Details of this was provided courtesy of Adam of WWW on the inflation bladder thread. I have used it a couple of time.
See: http://www.rcgroups.com/forums/showthread.php?t=1056468
This is an excellent thread!
Jim.
Looking forward to priming and surfacing soon!
Old Dec 01, 2012, 11:30 PM
Joined Aug 2008
Pics for the previous post.
Old Dec 02, 2012, 09:35 PM
Joined Aug 2008
Ready for first coat of primer!
The five part plug(s) are ready for first coat of primer. Then filling/sanding/priming etc. untill suitably surfaced up for final coat. I've decided on 2 pack. However, it will be over single pack acrylic primer, so I will be leaving the primer for at least a week and preferrably 10 days before painting with 2 pack. This is to allow most of the solvents to offgass and minimise any crazing and cracking in the final coat.
I'm trying to figure out a way to make and use one mould for both tail control surfaces. The main consideration is the position of the pins. If I could build the mould with pins in both positions, then it could be used for both tails.
Any suggestions?
I will wait for better weather before priming. In the meantime, I will get some other modelling chores under way. I need to do a stock take and order any necessary materials before the xmas break. I want to be in the shed during the week between xmas and New Year and don't want to suddenly run out of materials.
Also, I looking at the weather with view to making a road trip down to Wybung, which is about 5 hours south of where I am, for a fly later in the week.
Jim.
Old Dec 02, 2012, 10:31 PM
timbuck is offline
Find More Posts by timbuck
Nothing is easy
timbuck's Avatar
gold coast australia
Joined Aug 2008
Use 2k hi build primer as well. Always ends up in tears.
It will be worth it in the end.
Tim
timbuck is offline Find More Posts by timbuck
Latest blog entry: More colours
Old Dec 02, 2012, 11:42 PM
Joined Aug 2008
Tim,
The wings already have many coats of acrylic 1k primer and filler.
However, I could still do the fuse with 2 k.
What do you use for filler in this case? 2k filler as well?
Jim.
Old Dec 02, 2012, 11:52 PM
timbuck is offline
Nothing is easy
timbuck's Avatar
Joined Aug 2008
Dolphin glaze..
A lot of guys are using it , sands with NO effort, very quick drying , NO sink back etc etc.
I get it 10min from my house....if you can not get it close to you I'm happy to get some and send it to you.
It would be hard to find a better , easy to use product.
Tim
http://www.autobodytoolmart.com/u-po...y-p-15125.aspx
Old Dec 03, 2012, 02:22 AM
Joined Aug 2008
Originally Posted by timbuck View Post
Dolphin glaze..
Tim
What are the compatibility factors Tim? Before and after I mean.
ie: will it go on epoxy fibreglass, acrylic filler/primer etc. and is 2 pack ok on top of it?
Old Dec 14, 2012, 10:08 PM
Joined Aug 2008
Plugs and parting boards.
I've been steadily working on surfacing up the plugs. Meanwhile, I did get the opportunity to go into our local Men's Shed to start work on the parting boards.
The pictures tell the story fairly well I hope!
Old Dec 17, 2012, 05:51 AM
Joined Aug 2008
Wing parting boards.
I framed up and cut out the parting boards for the wings today at our "Men's Shed".
I now have a the small challenge of building a tapered ramp up to the mid-line of the joiner and incidence pins. They are elevated up from the parting board due to the slight dihedral.
Any suggestions as to an easy way to do this?
I'm considering making a flat plane ramp the full width of the parting board with its height determined by the mid-line of the joiner and incidence pin. that will create a small step in the junction of this ramp and the main parting board at the line of the root of the wing. I don't see any problem with this yet, but will sleep on it.
Jim.
Old Dec 21, 2012, 05:07 AM
Joined Aug 2008
More work on the fitting of the plugs to parting boards. Depth templates used to fit the wing plugs.
Sloped wood ramps to bring the parting board up to the mid-line of the joiner and incidence pins.
The red plastic strips on the wing parting boards are to create the channel that functions as a resin trap and fabric trim space. They are spline joiners for particle board flooring I think. I just planed the sides to form a positive draft angle.
Last edited by Jim.Thompson; Dec 21, 2012 at 05:10 AM. Reason: additional information
Old Dec 22, 2012, 09:05 PM
Joined Aug 2008
Fibreglass sheet compared to wood for "Ramps".
I made the first parting board riser or ramp out of some shaped wood. This second wing I decided to try it with pre-made fibreglass sheet and pack it up to height. I had made the sheet yesterday with my first vacuum infusion test sample. See my blog for details.
Anyway, the glass sheet method is easier and quicker. Will require less, if any, surfacing which the wood will.
Old Dec 26, 2012, 09:56 PM
Joined Aug 2008
Final Pre-painting trial fit.
The priming is now finished and I did a final pre-painting fit up today.
The four flying surfaces fit nicely to the root stubs, so all's well so far.
I plan to let the primer cure over 7 to 10 days to make sure the solvent has flashed off fairly thoroughly before spray painting with 2 pack gloss black paint.
This marks one more major stage in the mould production finished!
Old Dec 26, 2012, 10:46 PM
josh18 is offline
Find More Posts by josh18
608 km/h!
josh18's Avatar
Australia, QLD, Toowoomba
Joined Jan 2010
Looking great Jim! What tooling coat are you planning on using?
josh18 is offline Find More Posts by josh18
Build Log Astro Flight Super Monterey: Build Log! hugofly Sailplane Talk 95 Mar 05, 2016 05:53 AM
New Product Nanoshark ARF- Build Log - High Performance Depron Airplane NanoDave Foamies (Kits) 143 Sep 08, 2015 08:29 AM
Question "Modular" EasyStar build... (And log). Incendium Foamies (Kits) 38 Nov 30, 2010 07:13 PM
Build Log Dumas Eindecker build log? mcjustis Scratchbuilt Indoor and Micro Models 17 Nov 26, 2010 08:04 PM
Build Log Slo-mo-shun build log on Scale Boats JeremyBB Racing Boats - Electric 3 Nov 04, 2010 07:18 PM
