Old Jan 25, 2012, 05:27 PM
alexhaben is offline
Find More Posts by alexhaben
alexhaben's Avatar
Eureka, CA
Joined Nov 2008
That sucks about the carbon factor on your radio range limitations. Its starting to make me wonder how my transmitter will handle a carbon enriched fuse, since I have a cheap dx7. Have you looked into the carbon specific receivers for your transmitter? I know they make one for the spektrum but I'm not sure if they are worth their salt in real world. Thanks for sharing your testing, I'm learning something new everyday here on RCG.
Love your moulded idea Jim, it's too bad I don't live closer to you I'd buy one in a second, its a sexy and unique design.
alexhaben is offline Find More Posts by alexhaben
Old Jan 25, 2012, 06:04 PM
Jim.Thompson is offline
Find More Posts by Jim.Thompson
Entropy is happening!
Jim.Thompson's Avatar
Australia, NSW, Bellingen
Joined Aug 2008
The RF section of my tx. is now FrSky. I'm busy reading all I can of the FrSky thread(s). Antenna mods included. I am sure I have not exhausted this matter, not by a long shot!
I have just given up changing rx.'s in the prototype Wompoo, the wiring loom is starting to suffer from all the repositioning required and all the moving.
It will be revealing to see how my plank: "Circa" range tests on full power. I intend to do this as soon as the flooding rain stops here. It has one of my new FrSky rx.'s in it and some carbon in the fuse and spar caps.
Thanks for the favourable comments Alex! It's always good to get feedback. Needless to say, I like the plane sufficiently to commit to full moulded construction of one (or more), I suppose that speaks for itself. It is a delightful performer with no vices.
Jim.
Jim.Thompson is offline Find More Posts by Jim.Thompson
Old Feb 16, 2012, 02:01 AM
Joined Aug 2008
Joiner tube and indicence tubes in wing plug.
I have now set up the bench with accurately positioned MDF panels at the dihedral (19mm per side) with a 110mm wide flat section in the middle to position the centre part of the wing that will be fixed to the fuselage.
The joiner tube can be seen in the accompanying picture. The incidence pin cut out is next.
I discovered an easy way to make the tubes for the incidence pins. I have some 3mm carbon rod that I will use for the pins. Just by chance I had some nylon tube that fits it quite snuggly. I will wrap some glass cloth around that and bind it with carbon tow. The nylon tube will stay in there.
I plan to use these for the tail surfaces. Two per surface.
Jim.
Old Feb 16, 2012, 08:06 PM
josh18 is offline
Find More Posts by josh18
608 km/h!
josh18's Avatar
Australia, QLD, Toowoomba
Joined Jan 2010
HeyJim- looking good! Is this going to be a wing or a plug for another mould?
josh18 is offline Find More Posts by josh18
Old Feb 16, 2012, 08:27 PM
Joined Aug 2008
Plug construction.
Josh,
This going to be a plug, or more accurately, part of a plug. The wings will be glued onto the inner flat section (that eventually becomes part of the fuselage). Between these glued joins will be two pre-made fibreglass sheet ribs each join. These in turn will sandwhich a cartridge paper spacer glued in with spray adhesive.
When the assembled wing is eventually vac bagged, the
entire assembled wing will be glued onto the fuse along with the tail surfaces. Then I will use a thin kerf hacksaw blade to cut off the wings again using the paper spacers as guides and insurance for a clean accurate cut. ie. cut along the paper.
They will have the joiner tube and incidence pin tubes in place to manufacture the moulds from.
The five separate parts will then become the plugs for five separate moulds. I might be able to get away with four - one only tail surface plug.
Jim.
Old Feb 17, 2012, 04:50 PM
josh18 is offline
608 km/h!
josh18's Avatar
Joined Jan 2010
That sounds like a great way to do it Jim!
Old Feb 20, 2012, 12:16 AM
Joined Aug 2008
3 inner panels joined with tubes.
I plugged the tube ends and slotted them in as per the pictures. Then joined up with spray adhesive. Splooge filling of voids.
Old Mar 11, 2012, 06:04 PM
Joined Aug 2008
Delay.
I almost ready to get back to the wings, they are now ready for vacuum bagging.
I've been distracted from this due to repairing and rebuilding damage from last years flying at Manilla during the festival.
I hope to get on with it later this week or early next week.
Jim.
Old Apr 02, 2012, 03:34 AM
Joined Aug 2008
Wings in the bag.
The wing plugs are finally in the vacuum bag. I hope now to get some flow with the project, there's been so many delays.
I had a fly of the prototype out at Mount Borah a couple of weeks ago and it refreshed my enthusiasm for getting on with this moulded version.
Jim.
Old Apr 03, 2012, 09:56 PM
Joined Aug 2008
Glass/epoxy tubes.
I made up a little jig for winding some strips of release sheet plastic onto mandrels which were waxed first. Painters drop sheet actually. I wound it with about 50% overlap and terminated each end with a piece of tape. Then slid the very nice Soller Composites glass sock or sleave over the plastic covered mandrel. Then the glass fabric was wet out with epoxy resin and left in the sun to cure.
The small one is 3 mm and the larger 5 mm.
Jim.
edit:
I just checked the results and they both released easily! Successfull small diameter tube making has been a bit of a challenge for me!
The spiral wound drop sheet plastic came out one end when gently pulled. The resultant clearance is just about right!
Old Apr 04, 2012, 08:33 AM
heliwill10 is offline
Find More Posts by heliwill10
heliwill10's Avatar
Greensburg, PA
Joined Feb 2008
Looks good!
Your work table has that war look too.... I can only take pictures in certain directions in my room
heliwill10 is offline Find More Posts by heliwill10
Old Apr 04, 2012, 04:35 PM
Joined Aug 2008
More tubes.
Encouraged with my tube making of yesterday, I will make the main joiner tube (10mm dia) next, maybe later today. My approach is to first use only one layer of glass fabric sleave untill it proves to release off the mandrel. After that, if required, I'll add another one or two layers.
I plan to get the joiner tubes splooged into the tail surface cores tonight and get onto bagging them this weekend or earlier.
Jim.
Old Apr 05, 2012, 05:17 AM
Joined Aug 2008
Setting tubes in tail surface plugs.
I set the joiner alignment tubes into the tailplane surfaces with "Q" cells and epoxy splooge.
Old Apr 05, 2012, 05:59 PM
Joined Aug 2008
Video tape.
I made the main wing joiner tube (10mm) last night using the 1/2 Soller Composites 1/2 inch light glass sleave. This time I used video tape as the release film. It did work, but not nearly as well as the drop sheet plastic cut into narrow strips. It took more effort to get the tube off the mandrel and then a bit of fuss to get all the tape out of the inside of the tube.
Drop sheet plastic in future for this job!
Jim.
Old Apr 05, 2012, 06:08 PM
Twyl is offline
Find More Posts by Twyl
Silent Flight
Twyl's Avatar
United States, CA, Cypress
Joined Jul 2005
Hi Jim,
I'm guessing you've maybe seen this thread by Target, but just in case not...
http://www.rcgroups.com/forums/showthread.php?t=632908
I'd assume ballast tubes and wing joiners are fairly similar in initial construction so perhaps there might be a few build techniques that could be shared too.
-Jonathan
Twyl is offline Find More Posts by Twyl
Build Log Astro Flight Super Monterey: Build Log! hugofly Sailplane Talk 95 Mar 05, 2016 05:53 AM
New Product Nanoshark ARF- Build Log - High Performance Depron Airplane NanoDave Foamies (Kits) 143 Sep 08, 2015 08:29 AM
Question "Modular" EasyStar build... (And log). Incendium Foamies (Kits) 38 Nov 30, 2010 07:13 PM
Build Log Dumas Eindecker build log? mcjustis Scratchbuilt Indoor and Micro Models 17 Nov 26, 2010 08:04 PM
Build Log Slo-mo-shun build log on Scale Boats JeremyBB Racing Boats - Electric 3 Nov 04, 2010 07:18 PM
