Latest blog entry: 1940 Megow Models Super Quaker
Bill,
I put a couple videos up in my RCG blog of old sparker engines running on test stand, just to egg you on more than anything ![]() Warren |
Jim,
The ignition battery packs are three AA 2500 maH Nimhs hard wired (soldered) in series as you guessed. Here's the charger: http://www.all-battery.com/smartuniv...ck24v-72v.aspx Warren |
Sparker
Thanks for the helpful advice Warren. I will be installing the engine in an RC model and understand about the possibility of radio interference. Just a couple of questions:
1. Here is NZ we have two different petrol grades. High octane with I understand is around 98 and a low octane of around 92. Are spark ignition engines like lawn mowers that prefer the higher octane? The fuel tank will almost certainly be the original that came with the engine when new. May have to think about a replacement tank to run the methanol mix, we'll see. 2. Understand about clean points etc. Will need to check condition of all the ignition equipment on the model once I pick it up. Don't like the thought of testing the shock with the thumb.....too many memories of having my arm arm shoot up in the air when shorting out the old Morrison motor mower to stop the engine as a kid! Appreciate the quick reply and offer of further help if needed. Will also look up the start up video you spoke of. Kind regards, Allen |
Radio interferance is a thing of the past or can be. Use of a 2.4 ghz radio, a high tension lead with a 10K resistor soldered inline at the spark plug end between the lead and plug clip and one of the available solid state ignition modules will eliminate any worries about radio problems. For additional insurance place the RX as far away as you can get it from the ignition parts, example in a cabin job would be put your ignition setup forward close to the firewall and place the RX as far aft in the cabin as possible. I use both Futaba and Hitec radios with my sparkers and they both work brilliantly. I don't know what you have available to you Down Under for modules but there might be something in use that is readliy accessable. Perhaps look up one of the SAM Chapters in NZ for information on these. There are two listed on the SAM site: 55 Chapter 55- Assoc. of Vintage Aeromodelers, Neil McDougall 60 Heke Street Wellington 6004 NewZ. 1928 SAM- Chapter 1928, Martin Evans 71 Spinella Drive Bayview Auckland NewZ. +64 (9) 444 6204 As to the fuel situation I would go with the lower octane rating,but again there should be more information on your local level to be had from either of these two organizations. Warren |
| Thread Tools | |
| Sold CRRC-PRO Ignition NIB never used 45.00 | anwalker | Aircraft - Fuel - Engines and Accessories (FS/W) | 2 | Nov 07, 2010 06:32 PM |
| Sold OS Max FS-61 Four Stroke W/Electronic Ignition Conversion | stevster | Aircraft - Fuel - Engines and Accessories (FS/W) | 0 | Nov 06, 2010 11:44 PM |
| Sold Saito G60 Marine, vintage gas ignition, NIB | Kmot | Aircraft - Fuel - Engines and Accessories (FS/W) | 4 | Oct 29, 2010 07:47 PM |
| Cool Early Slope History Treasures Unearthed | Paul Naton | Slope | 7 | Jun 11, 2008 09:30 PM |
